Some questions regarding wtware
hooked888
Post by hooked888 »
I'm new to this software and i did like to ask for some question regarding to its funtionality.
1. From what i understand after some minor reading, we only need to install to SERVER the applications/programs and it will be use for all CLIENTS. Am i right? Do you mean SERVER is just like an real-time image file for all CLIENTS?
2. When the applications/programs run in CLIENT after load from SERVER, the processing resource(Processor, RAM, Video Card, Hard Drive) using is on SERVER or CLIENT?
3. When SERVER upgrade/install/update some applications/programs, does the CLIENTS directly take effect or CLIENTS need to reboot in order to have those updates change?
4. If user on CLIENT PC insert/plug-in their USB flash-drive or CD, can their browse their file on that? Or they need to plug-in in SERVER PC in order to brwose through?
5. Example, I have a gaming/internet cyber-cafe and around 100-200 PCs linked. I going to update some online game patchess and anti-virus update. I not going to move 1 by 1 and update those patches/updates which could took my whole weekend to complete, can wtware save my problems? What i mean is i just update once in SERVER and ALL CLIENTS will take effect after reboot.
Thanks in advance.
Regards,
hooked888
Re: Some questions regarding wtware
hooked888 wrote:Hi,
Yes.
Applications don't load from server, they run on server and are just displayed on client. So client resources are used just to display image sent by server.
Upgrade/install/update of applications should be done without connected clients.
Users can use flash-drives on client PC. For more information see http://wtware.com/docs/config.html#disc
WTware will help you with updates and patches. The other problem is that WTware is not suitable for gaming cyber-cafe. Graphic applications will work very slow on terminals.
