I'm using WTware on a Raspberry PI to connect a Microsoft RDP-Farm.
The Farm is configured to disconnect the Sessions after an Idle-Time of 3 Hours.
This is working correctly an a normal mstsc-Client, but not on the WTware-Raspberry PI.
Is there any configuration for this issue?
Thank you
RDP Idle-Disconnection doesn't work
Re: RDP Idle-Disconnection doesn't work
Try to disconnect mouse and repeat test.
i already tried this. Same effect!
Does the same user on the same server disconnect in mstsc and doesn't disconnect in wtware?
Show me the log, please: https://wtware.ru/logs.html
3+ hours, boot without mouse.
Perhaps, it's easily to reproduce on separate server with timeout for several minutes instead of 3 hours.
the Same user disconnects with mstsc correctly.
I attached the log, after i booted without a mouse and a runtime 3+ hours.
- WTware_B8.27.EB.26.D7.69_2020-09-07_15-10-52.txt
- (89.02 KiB) Downloaded 1184 times
Frozenfire
We have the same problem with a 2 hour lockout policy.
Ran Rasbian with xfreerdp and that timeout just fine. Just WTware that is causing the problem not timing out.
Has anyone an Idea with this Problem?
The Solution was, to set the Montior Poweroff parameter
RDP Idle-Disconnection depends on Monitor Poweroff?? Please, write more details.
