RDP Idle-Disconnection doesn't work
wendla
Post by wendla »
I'm using WTware on a Raspberry PI to connect a Microsoft RDP-Farm.
The Farm is configured to disconnect the Sessions after an Idle-Time of 3 Hours.
This is working correctly an a normal mstsc-Client, but not on the WTware-Raspberry PI.
Is there any configuration for this issue?
Thank you
Re: RDP Idle-Disconnection doesn't work
Try to disconnect mouse and repeat test.
wendla
Post by wendla »
i already tried this. Same effect!
Does the same user on the same server disconnect in mstsc and doesn't disconnect in wtware?
Show me the log, please: https://wtware.ru/logs.html
3+ hours, boot without mouse.
Perhaps, it's easily to reproduce on separate server with timeout for several minutes instead of 3 hours.
wendla
Post by wendla »
the Same user disconnects with mstsc correctly.
I attached the log, after i booted without a mouse and a runtime 3+ hours.
WTware_B8.27.EB.26.D7.69_2020-09-07_15-10-52.txt
(89.02 KiB) Downloaded 1185 times
Frozenfire
Post by Frozenfire »
We have the same problem with a 2 hour lockout policy.
Ran Rasbian with xfreerdp and that timeout just fine. Just WTware that is causing the problem not timing out.
wendla
Post by wendla »
Has anyone an Idea with this Problem?
wendla
Post by wendla »
The Solution was, to set the Montior Poweroff parameter
RDP Idle-Disconnection depends on Monitor Poweroff?? Please, write more details.
