raspberry pi power saving: sleep/wake, display off
ilya
Post by ilya »
Is there a way to enable power saving functions in raspberry pi:
- turn off display after a period of inactivity
- sleep after a period of inactivity
ilya
Re: raspberry pi power saving: sleep/wake, display off
Post by ilya »
I guess my initial question was not detailed enough.
I have tried the below setings with no desired effect (raspberry pi 3)
1) sleep = 5,standby
2) sleep = 5,suspend
result only in screen turing balck in 5 min. But It does not turn off (meaning the backlit if still on and it cosumes energy)
On other words the display shows a black picture, but does not go into standy.
3) sleep=5,poweroff
Also, try to add "hdmi_blanking=1" to config.txt on SD.
https://www.raspberrypi.org/documentati ... t/video.md
ilya
Post by ilya »
hdmi_blanking=1 is what solved it for me
JPD
Post by JPD »
I have the same question, but for a RPI4, I see in the link that was provided that hdmiblanking has not been implemented in RPI4 yet.
I'd like the user to be able to have some way to fully turn off the RPI safely, without having to unplug the power cord.
Currently I have added hdmiBlanking=1 in the config.txt file in the Pi just in case, but that didn't work.
I have the shutoff option turned on in the infobox, but when I click that, the displays go into powersaving mode, but the Pi's fan and LEDs are indicating the device is still on.
Try the latest build: http://wtware.com/testing/202003181227.zip
It should really turn off. But there is no way to turn it on.
This tool works: https://www.amazon.de/dp/B00386RXW6/?smid=AQNTLXYADUQ5X
Here is the user post about it: viewtopic.php?p=81670#p81670
JPD
Post by JPD »
Thanks so much I will test it out :)
