RPI 3B+ smartcard
geefox
RPI 3B+ smartcard
Post by geefox »
hi,
we encountered an issue with a smartcard reader omnikey "omni3021" - a week ago we configured following:
smartcard=omni3021
and installed the safesign software on the server and it recognizes the smartcardreader an also the card. now we wanted to test something else, but we can't get it working anymore.
i've attached you the logfile - thanks
log.txt
(42.44 KiB) Downloaded 1389 times
Re: RPI 3B+ smartcard
Write to config:
smartcard=omni3021,debug
And try to do minimum actions to reproduce wrong behavior. Save log when you see the first wrong behavior.
PS: can you redirect this reader with this card to the same server with the same user from windows computer with mstsc.exe?
geefox
Post by geefox »
I managed to get it working again, there was a driver issue which caused the problem
geefox
Post by geefox »
just a quick question - is it possible that the "ask_password" setting can be configured with 2 parameters?
we need the option to bypass the broker and also to disable the smartcard login with "nopin"
so basically the line should look like this "ask_password = on, nopin"
"ask_password = nopin" should ask password for broker and disable smartcard login. "nopin" is "on,nopin". there is no "off,nopin".
