RDS Devices CAL error with WTware
vincny
Post by vincny »
I like enquire anyone using WTware with RDS Devices CAL and is working properly. I keep getting Event ID 1004 telling me:
"The Remote Desktop Session Host server cannot issue a client license. It was unable to issue the license due to a changed (mismatched) client license, insufficient memory, or an internal error. Further details for this problem may have been reported at the client's computer."
I have no problem with User CAL but it was not the right license to apply for the VDI function.
Thanks,
Ken
Re: RDS Devices CAL error with WTware
Does it work well with mstsc.exe?
Do you get the same error with other wtware terminals?
http://wtware.com/logs.html
vincny
Post by vincny »
Hi Aka,
Thanks for the reply, yes it is working on Windows Machine I am able to receive the Devices CAL license.
All the Raspberry device on WTware software are not getting the Device CAL license. With Event Error 1004 mention. :(
Attach is the log capture.
Thanks,
Ken
Device-CAL-Licesne-Not-Issue.log
(42.6 KiB) Downloaded 1630 times
There are no errors in the Wtware log you attached. Terminal connects to server.
vincny
Post by vincny »
Hi Akatik,
The connection working now but no license being issue.
I will try again when it generate error from the station.
But I confirm that the error was generated from the terminal server:
Thanks,
Ken
vincny wrote:The connection working now but no license being issue.
So it's very userfull, why not?
vincny wrote:But I confirm that the error was generated from the terminal server:
Where did you see this text?
vincny
Post by vincny »
Hi Akatik,
After sometime WTware will prompt cannot connect due to license issue.
The log was capture from windows 2012 R2 RDSH server.
Thanks,
Ken
And where's the log?
vincny
Post by vincny »
Hi Akatik,
I have encounter the error again, when I use Device CAL WTware is generating error that license error.
When I use a windows PC the Device CAL license was issue without a problem.
I have read up that a device require to store a hardware certificate on the device it self is that missing on WTware software?
WTware error - license_error_wtware2
Windows Server error - RDS_Device_CAL license_Error
Thanks,
Ken
Please, save the log when you see error message on client screen. Not after client reboot. Not from another client.
