menu.gif and keyboard issues
Soulphy
Post by Soulphy »
Hello :),
i've got two problems. At first: I would change the connection and the user-login background. I made a picture menu.gif with 1024x768 and BPP=8 and put it in the directory /graphics on the sd-card. If i boot the pi i cant see only the standard blue background. :( Should i write something in the config e.g. where the picture is or somethin else?
The second problem: I've changed the keyboard and the language with: language=de,default and keyboard=de,default, now i can use äöü but the signs (;.-@ and more) are similiar to the english keyboard allocation.
Thank you :)
Re: menu.gif and keyboard issues
Soulphy wrote:Hello :),
In graphic directory create new folder, e.g. "..\Graphic\sample\"
In config file specify
skin=sample
If won't help, please send me terminal log file and all SD contents. To create terminal log enter terminal IP in web-browser from another computer in network.
Soulphy wrote:The second problem: I've changed the keyboard and the language with: language=de,default and keyboard=de,default, now i can use äöü but the signs (;.-@ and more) are similiar to the english keyboard allocation.
Thank you :)
Are you using the latest WTware version?
Soulphy
Post by Soulphy »
Hey thank you for your fast reply! :)
- Keyboard thing is solved (you are right, I've missed an update)
- menu.gif works on server selection screen but not on the user/password screen, should I use another .gif with a different name? Or is it possible to change the whole User-Login theme?
Soulphy wrote:- menu.gif works on server selection screen but not on the user/password screen, should I use another .gif with a different name? Or is it possible to change the whole User-Login theme?
No, menu.gif should be used for both server selection screen and user selection screen. We'll check this. Please, show me the screenshot of the image you see instead of menu.gif.
Soulphy
Post by Soulphy »
I wanna see the same background from the first pic (server) in the second one.
You didn't attached any images.
chris1182
Post by chris1182 »
I'm also having issues getting the custom background to display on the login screen (I don't have a server selection screen)
I have created a menu.png file (1024 x768 8bit colour depth) and copied it to a separate folder within the Graphic directory. i.e. Graphic\sample
I then edited the config file to include the line i.e. skin=sample
However when I boot up the Pi I just see a blue screen and login prompt but no logo.
Any suggestions?
Do you want to see your image on this screen?
P.S. Here is what Dropbox shows me when I try to open your image:
Chris1182
Post by Chris1182 »
Thanks for the reply. Yes I want to put a custom background on that screen to show the company logo if possible.
Ok, will be in the next version.
Please, try 5.4.44 wtware version.
Chris1182
Post by Chris1182 »
Hi aka,
My Raspberry Pi 3 will not boot with the new version. I have written the files to the SD card multiple times with no modification to the config files and I only get one brief flash on the activity light and then nothing on the screen etc..
Can you confirm that testing of the new version has been completed on a Raspberry Pi 3?
Chris1182
Post by Chris1182 »
Please ignore the last post it was a problem with the VGA to HDMI adapter.
Chris1182
Post by Chris1182 »
Logo is working and looking great on the login screen now thanks for the update :)
Great :)
