Can't force portuguese keyboard in login screen
andrenoites
Post by andrenoites »
Hi all!
WTware 6.0.86/RPi running in a Pi 3B connected to Windows server 2019
I have this options in the config.wtc file:
language = pt
keyboard = pt
But when I write the password in the login screeen it is not using the PT keyboard
Anyone else had a similar issue?
Re: Can't force portuguese keyboard in login screen
Try new version. And send screenshot if it won't work. There are more than ten different login screens.
And log: http://wtware.com/logs.html
andrenoites
Hi again, thanks for the reply
In this case we are using wtware version 6.2.20:
We wrote: “#$%&/()=ç
and in the display is shown: @#$%^&*();
log in attachment
Log WTWare.txt
(33.48 KiB) Downloaded 3479 times
Please look at that: http://kbdlayout.info/kbdpo
Is that the correct layout?
andrenoites
akatik wrote: Sat Apr 27, 2024 5:37 am Please look at that: http://kbdlayout.info/kbdpo
Yes, I can confirm that is the correct layout
This layout is not implemented now. We will make it after wtware for Raspberry 5 release. Sorry, but I can not build testing version just now.
andrenoites
Ok no problem, looking forward for the future updates :)
Please try wtware 6.2.24 or later version. In terminal config:
language=pt-pt,default
andrenoites
Thanks a lot! I will test it and report back.
See you soon
andrenoites
Problem solved. Thanks
