USB Printer
psdksalam
USB Printer
Post by psdksalam »
hi
i set : printer = usb and printer = on
connect printer direct to thin client usb ( hp 2015)
then configure printer same documentation (http://www.wtware.com/win2k3/printer.html)
but when sent print not work and no message to fail print ?
help
tnx
Re: USB Printer
Please, remove "printer=on" line. Only one line should be specified in config file for USB printer: "printer=usb"
If it won't help, create terminal log file http://wtware.com/docs/config.html#syslog and send it to support@wtware.com.
