I was trying to find a suitable driver for a HP T5145 thin client under WTware.
Until now i was not able to get a resolution of 1280x1024.
The driver intelfb, suggested by the wizard, does not work.
The driver vesa(s) is working fine for a resolution up to 1024x768,
but if configured @ 1280x1024 the desktop is only partially visible . . . i see 1024x768 pixels of the 1280x1024 pixel desktop.
The graphic chip of the HP T5145 should be VIA chrome 9 HC3, at least it says so here.
If someone knows how to run this piece of hardware properly with WTware @ 1280x1024, i would be glad to read about it.
With greetings from Austria,
Paul
