New suggestions
sboucher
New suggestions
Post by sboucher »
I use version 4.5.14 in production with Windows 2008 Terminal servers.
Here's some suggestions that could help us in our environment.
*Support for Canadian Multilingual Keyboards. (laws in Quebec province forces us to use this keyboard)
*Support for Windows Aero through terminal sessions. (when using 6.1 rdp client, it works. Through WTware, it disables Aero)
These are the two suggestions for you right now.
thanks
dbrookes
Additional request.
Post by dbrookes »
I know you can just press the power button, but it would be nice to have a power off option on the Terminal server selection screen where win2kIP is present in the wtc file for multiple connections.
Regards,
David
Currently WTware supports Russian and Brazil Multilingual Keyboards. We can try to add Canadian if you describe, how should I set up my 2003 to see it works.
roy.decaestecker
Re: New suggestions
Post by roy.decaestecker »
Are there any plans to implement acceleration for transfer rates regarding latency on watching flash movies eg from you tube?
cnfr eop by quest; tcx by wyse ?
regards
Roy
Re: New suggestions
Just as soon as Microsoft implements it. PDP6 protocol allows lossy compression, but 2008R2 server still doesn't use it.
roy.decaestecker
Re: New suggestions
In stead of waiting for microsoft;
Is there any posibility for integration of 3th party compression such as ericom blaze?
Will this be posible in the future?
with regards
Roy
roy.decaestecker
Re: New suggestions
Any plans to implement ICA protocol, which uses compression?
grtz
roy
Re: New suggestions
Sorry, i don't think it will be done in resonable terms.
