WTware on eBox - 2300 ?
cortexLT
Post by cortexLT »
I have ebox2300 and I'm trying to install wtware software.
First of all I get error mountBootMedia (by using usb-cdrom), so I solved it by downloading 4.5.8 version (rus version).
Now I have these errors:
CPU: Vendor unknow using generic unit.
CPU: Your system may be unstable.
ACPI: Unable to load The System Description Tables
Fatal internal error in file preinit-main.cpp error line 278, errorno 22
I would like to know if ebox2300 will be supported in the future, because I'm thinking about building a workgroup of those.
4.5.8 version boots from usb-cdrom??? 8-0
About the "line 278, errorno 22" - please, try another keyboard. This bug will be fixed a bit later.
cortexLT
Post by cortexLT »
aka wrote:4.5.8 version boots from usb-cdrom??? 8-0
Yes it does. I found about it somewhere in russian forums.
aka wrote:About the "line 278, errorno 22" - please, try another keyboard. This bug will be fixed a bit later.
Ok, this time I connected the same keyboard but through ps/2 adapter(usb keyboards doesnt work at all), so it continued booting until this error:
Internal error
File: parserd.cpp
Line: 1487
Function: mountBootMedia
I also tryied booting from usb, but then it says:
Could not find kernel image: linux.
Network boot isn't supported by ebox2300.
CF boot isn't supported by wtware.
amarao
eBOX PC 2300 && eBOX PC 2300 SX - р&#1
Post by amarao »
Обнаружил, что eBOX PC 2300 и eBOX PC 2300 SX - совершенно разные платформы. WTWare (триальная версия) не грузится на SX. Говорит, "boot media not found", уже после появления логотипа. Подскажите, что делать дальше?
