USB Flash drives do not connect....
kldomino
Post by kldomino »
I have entered lines in my config file for usb1=on, usb2=on, etc. for usb1-8, and when I put my mouse in the lower right corner to get the connect window, all usb options just beep, and don't "connect" to access my drive.
Does anyone have any ideas? We are evaluating, and all else works great, but the client uses flash drives often....
Thank you,
Kelly :)
Send us terminal log-file (http://www.wtware.com/docs/config.html#syslog)
1. Start the terminal.
2. Insert USB flash.
3. Press several times "Connect" button.
Log send us to support@wtware.com
