Terminal Boot CD
Shuino
Terminal Boot CD
Post by Shuino »
I'm looking to make a set of WTware CD's that will be able to boot Hard Drive less computers to a Windows 2003 DHCP sever to run Windows XP.
I’m looking to get the IP parameters from a DHCP server and have the Terminal Configuration saved on the CD.
I have gotten as far as, setting up my WTware boot CD with a Configuration file.
win2kip = x.x.x.x (My Server IP)
video = vesa(x)
resolution = 1024x768
bpp = 32
mouse = usb
Though when running my CD Image, it will try to load WTware then go straight to a "Can Not Display This Mode" error even though the current setting worked while running the display test.
I’m using WTware Version 4.2.1 and so far I have had no success booting from a Generated CD image and connecting to my DHCP sever. I have run out of ideas how to get this to work, and any help on this would be fantastic.
Robb_Robson
Post by Robb_Robson »
Try adding
refresh = 60
to the config
Also you can try to use the latest version 4.3.61 beta
