VirtuelHere license won't register
drouven
Post by drouven »
Hi
We purchased 3 virtualHere licenses (2 for HP thin client & 1 for PI4 thin client). The license code for the PI4 uses as last character = and that seems to be not compatible with WeTware version 6.2.58.
Some help would be appreciated.
Re: VirtuelHere license won't register
Yes, I see this issue. Will fix this in the next version. Till then you may in configurator switch to "text" tab and enter your license with "=" character. Press "Save", ignore warning. Terminal will process this line without problems.
