Microphone jack is not recognized
Kauan
Post by Kauan »
I am using a WTware 5.6.24 and I am with a problem with my Microphone Jack. My microphone is not recognized.
I am using the following parameter:
sound=on, amixer:cset numid=3 1
microphone=hw:1:0
Parameter as "microphone=on or microphone=hw:2:0" is not recognize.
I need your help, please.
Re: Microphone jack is not recognized
What is your Microphone Jack? There is no microphone input in Raspberry Pi sound jack. Not implemented in hardware. You should use USB microphone or USB headset for Raspberry Pi.
WTware sound manual:
https://wtware.com/docs5/sound.html
Logging manual (when you add log, tech support asks less question):
http://wtware.com/logs.html
Kauan
Post by Kauan »
I can hear audio normally with these headphones, but I can't use the microphone. I'd like to know if there's any way to use this microphone. I don't have USB headphones.
You can not connect microphone to Raspberry 3.5mm jack. There is no hardware for microphone input in Raspberry. You should use USB microphone or USB headset.
