BCM2835 Headphone (aka AUX jack) not found with 6.2.54
Posted: Mon Apr 28, 2025 2:44 pm
by ITaluone
Hi
Has something changed in this area between 6.2.52 and 6.2.54? Because if I upgrade to 54 it cannot detect the jack anymore, only lists the two HDMI screens as source, but cannot play sound over this sources, meaning it stays completely silent, regardless what configured in the terminal config file.
The boot logs look the same on both versions.
What can I do to tackle this problem?
Re: BCM2835 Headphone (aka AUX jack) not found with 6.2.54
Posted: Tue Apr 29, 2025 3:00 pm
Kernel version upgraded from 6.6.x to 6.12.x. Sound device file name has been changed in new kernel 🙁
Will be fixed in the next wtware version, thank you.
Posted: Tue May 06, 2025 12:43 pm
Please try 6.2.56 wtware version.
Posted: Tue May 13, 2025 3:20 pm
by ITaluone
Hi
Works! thank you!
