BCM2835 Headphone (aka AUX jack) not found with 6.2.54
ITaluone
Post by ITaluone »
Hi
Has something changed in this area between 6.2.52 and 6.2.54? Because if I upgrade to 54 it cannot detect the jack anymore, only lists the two HDMI screens as source, but cannot play sound over this sources, meaning it stays completely silent, regardless what configured in the terminal config file.
The boot logs look the same on both versions.
What can I do to tackle this problem?
Re: BCM2835 Headphone (aka AUX jack) not found with 6.2.54
Kernel version upgraded from 6.6.x to 6.12.x. Sound device file name has been changed in new kernel 🙁
Will be fixed in the next wtware version, thank you.
Please try 6.2.56 wtware version.
ITaluone
Post by ITaluone »
Hi
Works! thank you!
