Bluetooth HID Scanner with Chrome Modus
How it works in WTware without terminal server
IT_GT
Post by IT_GT »
We want to use a Bluetooth Scanner HID in Chrome mode. The connection is established, unfortunately he doesn't write anything in the input field. Here is the log.
[EVDEV] Unknown key 374 (0x00000176) from 'Barcode ScannerHID', '/dev/input/event8'
Re: Bluetooth HID Scanner with Chrome Modus
Logging manual:
http://wtware.com/logs.html
There is no "delete everything important and leave only single line". Log should be full, from boot to first wrong behavior. Send it to support@wtware.com if there is something personal.
IT_GT
Post by IT_GT »
I have sent you the log file to support@wtware.com
Sorry, we can't use bluetooth HID in Chrome. Bluetooth HID works only in WTware RDP client.
IT_GT
Post by IT_GT »
Will Bluetooth be implemented in Chrome mode in the next versions?
WTware is too limited. We cut off many standard linux features to be small. Related to this topic: there is no udev in wtware. We only statically configure input devices detected on boot for Chromium. Input devices connected after boot (even USB mouse) will not work in Chromium (but work in wtware RDP client).
I can make workaround: tell wtware to wait until user scans something. Stop booting at black screen with "please scan one code or press Esc to boot without scanner" text and wait for input from scanner. After we see input device connected, we can run Chromium with Bluetooth HID. Will it work for you?
IT_GT
Post by IT_GT »
"I can make workaround: tell wtware to wait until user scans something. Stop booting at black screen with "please scan one code or press Esc to boot without scanner" text and wait for input from scanner. After we see input device connected, we can run Chromium with Bluetooth HID. Will it work for you?"
That would be good if you could farm that
Please try this:
http://wtware.com/testing/202412231241/ ... ry.img.zip
In Raspberry Pi Imager CHOOSE OS -> Use custom -> Choose downloaded zip file.
In terminal config file "bluetooth=wait" instead of "bluetooth=on"
