Second display forced resolution not working
foc
Post by foc »
I have a Raspberry pi 4 with two displays, (Both HDMI) i want to force the resolution to 1280x1024 on both as that is the size the application I'm running uses.
The configuration line
display = 1280x1024
Works fine on the first display, but the second
M2_display = 1280x1024
has no effect and the resolution goes to the standard 1920x1080.
Thanks in advance for any help
Re: Second display forced resolution not working
foc wrote: Tue Sep 03, 2024 12:35 pm The configuration line
display = 1280x1024
Really? Show me the log please:
http://wtware.com/logs.html
Also, take a look at config.txt on boot SD. By design, Raspberry should look here to set resolution. But sometimes it does not.
foc
Post by foc »
Hi akatik
Configuring the config.txt resolved my issue, thank you.
