Lenovo Thinkpad and Synaptics Touchpad
Posted: Thu Jun 20, 2024 5:28 pm
by edilpali
Good morning.
In my RDS enviroment, we are introducing some laptops.
System does'nt recognize the touchpad (Synaptics) meanwhile it recognizes the Elan Trackpoint.
It could be that there's no driver?
It's possible to introduce it?
I attach the log file.
Paolo
Re: Lenovo Thinkpad and Synaptics Touchpad
Posted: Sat Jun 22, 2024 12:20 pm
It is possible to add driver if we know which one to add. There are too many chips and drivers...
1. Please try the latest wtware version and show me the same log. It should dump some more information about input devices.
2. If some other linux works with this touchpad, run:
And show me 1.txt file
PS: "extra=WTFW_i915_adlp_dmc_ver2_16.bin.zip" does not work for firmware. Write "firmware=WTFW_i915_adlp_dmc_ver2_16.bin.zip" instead of extra=
Posted: Mon Jun 24, 2024 1:06 pm
by edilpali
I've done the update.
I set up all the firmwares needed.
I send the new log.
I don't have a linux installation working, but if I could make a setup to find a path.
Is there a preferred version? Ubuntu?
Posted: Mon Jun 24, 2024 5:11 pm
by edilpali
I've done the setup of the Debian 12.
Without installing all the system, I got the log of the bootstrap.
I send it in attachments.
Posted: Mon Jun 24, 2024 6:24 pm
i2c bus
Please, run in Debian 12:
And show me /tmp/2.txt
Posted: Mon Jun 24, 2024 6:50 pm
by edilpali
Here the log
Posted: Mon Jun 24, 2024 7:07 pm
Ubuntu, yes.
Also, why are you sure there is Synaptics touchpad? Recognized the Elan Trackpoint does not work, no reaction at touchpad?
PS: physical display mode is "display=1920x1200". With "display=1600x900" image on screen becomes smooth. Perhaps, those two lines will make fonts large enough with clear picture:
display=1920x1200
scale_factor = 125
Posted: Mon Jun 24, 2024 7:15 pm
by edilpali
Trackpoint works, and also the buttons left/right of the touchpad.
On another identical laptop there's a Windows 11 OS. It recognized the touchpad as a synaptics
Posted: Tue Jul 02, 2024 1:43 am
Posted: Tue Jul 02, 2024 10:19 am
by edilpali
IT WORKS!! the pad respondes.
But the movement is very slowly. For each total-pad move, it moves on the screen about 1 cm
Posted: Tue Jul 02, 2024 12:33 pm
1. Write into config:
2. Show me log after reboot and some movements.
Posted: Tue Jul 02, 2024 1:03 pm
by edilpali
I set the parameter "mouse_accel_mult=16".
But now, the other mouse I attached and the trackpoint are gone crazy.
I send the current log.
Posted: Mon Jul 08, 2024 8:44 am
Please try 6.2.30 version from
https://wtware.com
Now it should understand:
For touchpad only, not for mouse.
Posted: Mon Jul 08, 2024 11:52 am
by edilpali
I put on the new version and all works well.
I deleted the mouse_accel_mult parameter. It's works fine.
Thankyou very much!!! You're the best!
