Lenovo Thinkpad and Synaptics Touchpad
edilpali
Post by edilpali »
Good morning.
In my RDS enviroment, we are introducing some laptops.
System does'nt recognize the touchpad (Synaptics) meanwhile it recognizes the Elan Trackpoint.
It could be that there's no driver?
It's possible to introduce it?
I attach the log file.
Paolo
LENOVO log file.txt
(172.83 KiB) Downloaded 7983 times
Re: Lenovo Thinkpad and Synaptics Touchpad
It is possible to add driver if we know which one to add. There are too many chips and drivers...
1. Please try the latest wtware version and show me the same log. It should dump some more information about input devices.
2. If some other linux works with this touchpad, run:
sudo dmesg > /tmp/1.txt
And show me 1.txt file
PS: "extra=WTFW_i915_adlp_dmc_ver2_16.bin.zip" does not work for firmware. Write "firmware=WTFW_i915_adlp_dmc_ver2_16.bin.zip" instead of extra=
edilpali
Post by edilpali »
I've done the update.
I set up all the firmwares needed.
I send the new log.
I don't have a linux installation working, but if I could make a setup to find a path.
Is there a preferred version? Ubuntu?
WTware_log_240624.zip
(36.46 KiB) Downloaded 8173 times
edilpali
Post by edilpali »
I've done the setup of the Debian 12.
Without installing all the system, I got the log of the bootstrap.
I send it in attachments.
log-1.txt
(62.32 KiB) Downloaded 8183 times
i2c bus :?
Please, run in Debian 12:
sudo lsmod > /tmp/2.txt
And show me /tmp/2.txt
edilpali
Post by edilpali »
Here the log
log2.txt
(3.98 KiB) Downloaded 8040 times
Ubuntu, yes.
Also, why are you sure there is Synaptics touchpad? Recognized the Elan Trackpoint does not work, no reaction at touchpad?
PS: physical display mode is "display=1920x1200". With "display=1600x900" image on screen becomes smooth. Perhaps, those two lines will make fonts large enough with clear picture:
display=1920x1200
scale_factor = 125
edilpali
Post by edilpali »
Trackpoint works, and also the buttons left/right of the touchpad.
On another identical laptop there's a Windows 11 OS. It recognized the touchpad as a synaptics
edilpali
Post by edilpali »
IT WORKS!! the pad respondes.
But the movement is very slowly. For each total-pad move, it moves on the screen about 1 cm
1. Write into config:
mouse_accel_mult=16
2. Show me log after reboot and some movements.
edilpali
Post by edilpali »
I set the parameter "mouse_accel_mult=16".
But now, the other mouse I attached and the trackpoint are gone crazy.
I send the current log.
WTware_D4.E9.8A.5B.C2.78_2024-07-02_11-59-44.zip
(40.76 KiB) Downloaded 7862 times
Please try 6.2.30 version from https://wtware.com
Now it should understand:
mouse_accel_mult=touch:12
For touchpad only, not for mouse.
edilpali
Post by edilpali »
I put on the new version and all works well.
I deleted the mouse_accel_mult parameter. It's works fine.
Thankyou very much!!! You're the best!
