issues accessing RemoteApp's via "shell" parameter
lee.hill.1987
Post by lee.hill.1987 »
tested everything prior to posting natively, so i know things work through the native windows methods.
the issue is when trying to launch published RemoteApps using the parameter:
shell=||MyRemoteApp
i am able to connect to the TS session fine, without the "shell" parameter and i can access the published remoteapp's via the new "server=rdweb;ts.plu......" method.
i have 4 remoteapps published, all work when being launched using RDP file. I've tried to launch all of then using the shell parameter, but unfortunately i consistently get the error
the system cannot find the file specified. this initial program cannot be started
Wtware version 6.2.20
Server OS 2019
what am i doing wrong?
thanks!
Lee
Re: issues accessing RemoteApp's via "shell" parameter
Remote app works with "server=rdweb.." but does not work if you set remote app name in "shell="?
Show me both logs (first with working remote app and second with not working) to aka@wtware.com
http://wtware.com/logs.html
