802.1x Support for wired connection
thiagopramos
Post by thiagopramos »
Please provide one way use Wtware in environments with 802.1x in wired network
Re: 802.1x Support for wired connection
WTware does not support 802.1x now.
thiagopramos
Don´t have a plan to support in future???
We can make it if someone familiar with wired 802.1x in regular linux tells us what should we do.
thiagopramos
Yep, i´m familiar with linux, let´s go!
thiagopramos
Hi, can you provider the way to do?
Sorry, too busy now. I'll answer here after we upload next version.
Sorry for a delay.
As far as I understand, we should prepare wpa_supplicant.conf and run wpa_supplicant as we do for Wi-Fi, but on Ethernet interface. Before asking DHCP or apply static IP to interface. Right?
Should we generate default wpa_supplicant.conf or always require user-provided wpa_supplicant.conf ? If we should generate default, please write it to me.
For Wi-Fi we use such minimal default wpa_supplicant.conf if user doesn't provide another :
network={
    ssid="MYSSID"
    psk="passphrase"
With wpa_supplicant.conf prepared, we should run:
/sbin/wpa_supplicant -B -c /etc/wpa_supplicant.conf -i eth0
Right?
thiagopramos
Hello, we used dhcp with guest vlan.
We can work with default suplicant.
ap_scan=0
network={
              key_mgmt=IEEE8021X
              eap=MD5
              identity="login"
              password="password"
Now is the question, why i can run /sbin/wpa_supplicant -B -c /etc/wpa_supplicant.conf -i eth0, because a only have accces to shell before Wtware booting ???
Jakemoran
Post by Jakemoran »
hi
I also have this problem like you
Sorry for delay...
Here I made some code for 802.1x:
http://wtware.com/testing/202411100232/ ... .45.en.zip
1. Install on local disk. Network boot is incompatible with 802.1x, right?
2. Press Del to enter black-gray setup.
3. Switch "Network media" to "Ethernet 802.1x". Read text on screen. Write your wpa_supplicant.conf to FAT-formatted USB flash, upload it to terminal. Reboot.
Example wpa_supplicant.conf (ctrl_interface=... line is needed):
ap_scan=0
network={
  key_mgmt=IEEE8021X
  eap=MD5
  identity="login"
  password="password"
4. It will wait for a minute in "Please wait" screen. After message "Failed to log in to 802.1x..." press Esc to get command line.
5. From command line:
less /tmp/all.log
Press PageDown or End key to see the latest log lines. Any idea why it does not work?
