Wireguard Documentation
Discussions, remarks
buzz2912
Post by buzz2912 »
Can you please add a documentation how to add wireguard VPN?
wg.conf file is clear to me.
Anything else to do?
Thanks, Sebastian
Re: Wireguard Documentation
It should just work with trivial wg.conf.
0.0.0.0/0 doesn't work.
buzz2912
Post by buzz2912 »
For everybody else:
Two ways:
first:
but your wg.conf file in the config Folder of the sd-card. It will work as described with openvpn just by doing that.
By doing this, the first boot with the assistant for the network connection stays in place for the user.
second:
boot the terminal and enter setup. Config network connection and choose Wireguard VPN. As described in the displayed help text, add an usb device with the wg.conf file in root directory. The file will then be added.
Con: The Network Assistant for the user on first boot at home is gone.
Cheers, Sebastian
