TightVNC Connection with no Username
Bitpusher
Post by Bitpusher »
I am trying to supply the password for this cconnection to a tight vnc server in the configuration file.
The connection works with no "user = user:pass" specified and will prompt only for the password.
If I specify "user = :pass" it says invalid user. to my knowledge there is no user name I can pass so how do I tell WTware to only send the password component?
Thanks,
Bit...
Re: TightVNC Connection with no Username
user = anything:pass
Syntax checker will be happy. Password will be used. User name will be ignored.
Bitpusher
Post by Bitpusher »
This worked perfectly
antda
Post by antda »
Works perfectly
