Using connection with template
mckinnonsc
Post by mckinnonsc »
In WTware Center, if I try to create a template with the "connection" parameter, the file gets flagged as broken (renamed .broken)
connection
server=192.168.1.1
connection
server=192.168.1.2
This same config, if applied through the terminal's web interface, works fine.
How can I use "connection" within a template?
Re: Using connection with template
No way to create template with connection. Included files may contain only options and their values.
