IOT PC - Audio only on HDMI
skynetto
Post by skynetto »
Hello there.
I'm struggling with a problem with audio redirection.
I have 5 terminals (all the same) that cannot get the audio out of audio jack for the life of me, no matter what parameters i set on config.
I do have audio redirection only if i connect a HDMI monitor with integrated speakers.
But i want to use the audio jack for speakers and i cannot force my customer to buy 5 monitor with integrated sperakers just because of this issue.
The PC's looks like this:
https://sicomputer.com/activa/activa-iot/
If you need the log file, i'm happy to provide one.
Thank you in advance
Re: IOT PC - Audio only on HDMI
Yes, I need the log. Mail it to support@wtware.com
skynetto
Post by skynetto »
Log sent. Thank you.
Sorry, I have no ideas. We have no driver for this sound device now. Perhaps, USB sound will work?
skynetto
Post by skynetto »
Need to try. Will keep you informed
skynetto
Post by skynetto »
External USB soundcard did the trick. Problem solved. Thank you.
