IBM 5250 client
FarmaRinaldi1
IBM 5250 client
Post by FarmaRinaldi1 »
I need to convert some thin clients to allow connection to IBM as400 system through client 5250.
As IBM officialy releases a 5250 client software for Linux, is it possible to install it on WTWare and use your software as connection client to IBM as400?
Re: IBM 5250 client
We have no console client in wtware. Thinstation should do.
FarmaRinaldi1
Re: IBM 5250 client
ok you have no console, but is it possible to install the official IBM 5250 Linux client in WTWare?
Re: IBM 5250 client
WTware is a lightweight linux. Linux today is a few megabytes of kernel and several hundred megabytes of libraries. So we can run linux application if we have enough libraries for this application.
You can not install in wtware. We can try to add required libraries and run.
Why not thinstation?
FarmaRinaldi1
Re: IBM 5250 client
I never used Thinstation but thanks for the suggest, I'm making a test with it.
