Bluetooth headphones not connecting
ziejacode
Post by ziejacode »
Hi. I am new user of WTware. I have a problem with connecting my bluetooth headphones. I use WTware on raspberry pi connected to Win10 VM running on Proxmox. When I try to pair Headphones on startup it says it's paired but not conneced and there is no zip-archive file stored in /config directory. I followed the steps from this manual: https://wtware.com/docs5/bluetooth.html. I anyone had similar problem please help. Thanks.
Re: Bluetooth headphones not connecting
ziejacode wrote: Sun Nov 28, 2021 10:57 am I followed the steps from this manual: https://wtware.com/docs5/bluetooth.html.
Manual:
On Raspberry Pi WTware is able to use Bluetooth mouses, keyboards and barcode scanners in HID mode, keyboard emulation.
Sound devices are not supported, sorry.
ziejacode
Post by ziejacode »
But it would work fine in any HP nuc right?
It should work if operating system supports it. WTware is operating system and WTware does not support Bluetooth audio.
