USB Printer redirection not working
chris@tagsol.co.za
Post by chris@tagsol.co.za »
Printer redirection not working, added the line printer=usb to the WTware configuration file.
Nothing showing on the RDS server, other Windows users redirected printers showing.
What can I do to troubleshoot the problem?
Created the Pi terminal with the latest version of the WTware software, using a Brother HL-6180DW laser printer, Windows Server 2016.
Chris
Re: USB Printer redirection not working
chris@tagsol.co.za
I have read the manual, can't see what I am missing.
Where do I find the log file that will provide me with more info?
https://wtware.com/logs.html
For printer= parameter, nothing should appear on server. You should add network printer on server, manually.
chris@tagsol.co.za
Thank you very much, sorted working on LAN and WAN.
