I am testing WTware to see I I will buy licences:
- First, in Office : works perfectly
=> Network on 10.138.0.0/22 : Raspberry 10.138.1.50 and Remote Computer 10.138.2.100 : OK Boot direct windows logon
- Second, HomeOffice : ouch
=> HomeOffice Network 10.172.17.1/24 : Raspberry 10.172.17.151 (eth)
=> OpenVpn enable and connection OK : Raspberry, VPN_IP : 192.168.110.54 (wifi)
=> But after vpnconnection, nothing happened, blocked on image "Please wait"
FYI : company network (10.138.0.1/22 and for VPN 192.168.110.1/24) : all rules are done and works perfectly with computer, phone, tablet from HomeOffice with OpenVPN
Any idea to have the next step ? Only miss the RDP connection
[Solved]WTware on Raspberry Pi 3B+ / HomeOffice : please wait after openvpn connection
- initrd.wtc.txt
- (124 Bytes) Downloaded 1047 times
- config.wtc.txt
- (258 Bytes) Downloaded 1062 times
- WTware_B8.27.EB.2E.F5.7B_2021-11-05_15-56-14.txt
- (79.38 KiB) Downloaded 1059 times
Re: WTware on Raspberry Pi 3B+ / HomeOffice : please wait after openvpn connection
1. I don't see "OpenVpn enable and connection OK" in this log.
2. http://wtware.com/docs5/openvpn.html
It's about openvpn configuratin file openvpn.cfgIn configuration file must be such line:
daemon
On the office I saw the Raspberry and the ping was also OK so the conection seems OK.
I add deamon and MANY THANKS, it is working ^_^
