Cannot connect
Cannot connect
Hello, at first I want to say, I am totally new to this SW and also I am really bad at networking. My main objective is to mirror my computers desktop to smart LG TV, both my PC and the TV are connected by ethernet cable to router. I installed WTware to Raspberry Pi, connected it to the TV (HDMI) and to ethernet. Everything booted just fine, but when I want to connect to desktop, it doesnt work, well I am not sure which IP address to use so.. When I look to the WTware app at my PC, I can see the raspberry icon and mac adress. Can you please help me?
Re: Cannot connect
18-06-44-071| [wtc.exe] Failed to connect to 192.168.1.109:779.
18-13-50-620| [DHCP] Processing DHCPDISCOVER package...
18-13-50-620| [DHCP] Determine IP for DISCOVER...
18-13-50-620| [DHCP] Sending ARP to check if IP 192.168.1.109 is busy...
18-13-50-932| [DHCP] IP 192.168.1.109 for MAC B8:27:EB:9D:34:A7 determined from terminalDHCP parameters.
18-13-50-932| [DHCP] Stored in catalog IP 192.168.1.109 for MAC B8:27:EB:9D:34:A7
18-13-50-948| [DHCP] Send DHCPOFFER IP: 192.168.1.109.
18-13-50-948| [DHCP] Sent 315 bytes to 192.168.1.109:68.
18-19-59-785| WTware 6.0.56/RPi supervisor.
18-19-59-785| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
18-19-59-785| [ KERNEL] [ 0.000000] Linux version 5.10.50-v7 (aka@c22) (arm-linux-gnueabihf-gcc (Debian 8.3.0-2) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #7 SMP Tue Jul 20 19:46:08 UTC 2021
18-19-59-785| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
18-19-59-785| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
18-19-59-785| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
18-19-59-785| [ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
18-19-59-785| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
18-19-59-785| [ KERNEL] [ 0.000000] Reserved memory: created CMA memory pool at 0x36000000, size 64 MiB
18-19-59-785| [ KERNEL] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
18-19-59-785| [ KERNEL] [ 0.000000] Zone ranges:
18-19-59-785| [ KERNEL] [ 0.000000] DMA [mem 0x0000000000000000-0x0000000039ffffff]
18-19-59-785| [ KERNEL] [ 0.000000] Normal empty
18-19-59-785| [ KERNEL] [ 0.000000] Movable zone start for each node
18-19-59-785| [ KERNEL] [ 0.000000] Early memory node ranges
18-19-59-785| [ KERNEL] [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000039ffffff]
18-19-59-785| [ KERNEL] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000039ffffff]
18-19-59-785| [ KERNEL] [ 0.000000] On node 0 totalpages: 237568
18-19-59-785| [ KERNEL] [ 0.000000] DMA zone: 1856 pages used for memmap
18-19-59-785| [ KERNEL] [ 0.000000] DMA zone: 0 pages reserved
18-19-59-785| [ KERNEL] [ 0.000000] DMA zone: 237568 pages, LIFO batch:63
18-19-59-785| [ KERNEL] [ 0.000000] percpu: Embedded 15 pages/cpu s29580 r8192 d23668 u61440
18-19-59-785| [ KERNEL] [ 0.000000] pcpu-alloc: s29580 r8192 d23668 u61440 alloc=15*4096
18-19-59-785| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
18-19-59-785| [ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 235712
18-19-59-785| [ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
18-19-59-785| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
18-19-59-785| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
18-19-59-785| [ KERNEL] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
18-19-59-785| [ KERNEL] [ 0.000000] Memory: 865888K/950272K available (5120K kernel code, 572K rwdata, 736K rodata, 3072K init, 355K bss, 18848K reserved, 65536K cma-reserved)
18-19-59-785| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
18-19-59-785| [ KERNEL] [ 0.000000] rcu: Hierarchical RCU implementation.
18-19-59-785| [ KERNEL] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
18-19-59-785| [ KERNEL] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
18-19-59-785| [ KERNEL] [ 0.000000] random: get_random_bytes called from 0x80700bac with crng_init=0
18-19-59-785| [ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
18-19-59-785| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
18-19-59-785| [ KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
18-19-59-785| [ KERNEL] [ 0.000027] Switching to timer-based delay loop, resolution 52ns
18-19-59-785| [ KERNEL] [ 0.000247] Console: colour dummy device 80x30
18-19-59-785| [ KERNEL] [ 0.000319] printk: console [tty0] enabled
18-19-59-785| [ KERNEL] [ 0.000373] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
18-19-59-785| [ KERNEL] [ 0.000398] pid_max: default: 32768 minimum: 301
18-19-59-785| [ KERNEL] [ 0.000640] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
18-19-59-785| [ KERNEL] [ 0.000664] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
18-19-59-785| [ KERNEL] [ 0.001535] CPU: Testing write buffer coherency: ok
18-19-59-785| [ KERNEL] [ 0.001933] CPU0: update cpu_capacity 1024
18-19-59-785| [ KERNEL] [ 0.001948] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
18-19-59-785| [ KERNEL] [ 0.002640] Setting up static identity map for 0x100000 - 0x10003c
18-19-59-785| [ KERNEL] [ 0.002780] rcu: Hierarchical SRCU implementation.
18-19-59-785| [ KERNEL] [ 0.003255] smp: Bringing up secondary CPUs ...
18-19-59-785| [ KERNEL] [ 0.004197] CPU1: update cpu_capacity 1024
18-19-59-785| [ KERNEL] [ 0.004210] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
18-19-59-785| [ KERNEL] [ 0.005229] CPU2: update cpu_capacity 1024
18-19-59-785| [ KERNEL] [ 0.005241] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
18-19-59-785| [ KERNEL] [ 1.040598] CPU3: failed to come online
18-19-59-785| [ KERNEL] [ 1.040688] smp: Brought up 1 node, 3 CPUs
18-19-59-785| [ KERNEL] [ 1.040700] SMP: Total of 3 processors activated (115.20 BogoMIPS).
18-19-59-785| [ KERNEL] [ 1.040708] CPU: All CPU(s) started in HYP mode.
18-19-59-785| [ KERNEL] [ 1.040715] CPU: Virtualization extensions available.
18-19-59-785| [ KERNEL] [ 1.041434] devtmpfs: initialized
18-19-59-785| [ KERNEL] [ 1.055607] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
18-19-59-785| [ KERNEL] [ 1.056175] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
18-19-59-785| [ KERNEL] [ 1.056210] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.059280] pinctrl core: initialized pinctrl subsystem
18-19-59-785| [ KERNEL] [ 1.061352] NET: Registered protocol family 16
18-19-59-785| [ KERNEL] [ 1.064213] DMA: preallocated 1024 KiB pool for atomic coherent allocations
18-19-59-785| [ KERNEL] [ 1.071978] thermal_sys: Registered thermal governor 'step_wise'
18-19-59-785| [ KERNEL] [ 1.073015] Serial: AMBA PL011 UART driver
18-19-59-785| [ KERNEL] [ 1.088392] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
18-19-59-785| [ KERNEL] [ 1.100897] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-04-21T15:49:36, variant start
18-19-59-785| [ KERNEL] [ 1.110880] raspberrypi-firmware soc:firmware: Firmware hash is a48d332c35ee1c1c1ab433228e23317f62dcc5fb
18-19-59-785| [ KERNEL] [ 1.174061] cryptd: max_cpu_qlen set to 1000
18-19-59-785| [ KERNEL] [ 1.178381] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
18-19-59-785| [ KERNEL] [ 1.182216] usbcore: registered new interface driver usbfs
18-19-59-785| [ KERNEL] [ 1.182404] usbcore: registered new interface driver hub
18-19-59-785| [ KERNEL] [ 1.182511] usbcore: registered new device driver usb
18-19-59-785| [ KERNEL] [ 1.185399] clocksource: Switched to clocksource arch_sys_counter
18-19-59-785| [ KERNEL] [ 1.205261] NET: Registered protocol family 2
18-19-59-785| [ KERNEL] [ 1.205736] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.207408] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.207450] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.207566] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.207755] TCP: Hash tables configured (established 8192 bind 8192)
18-19-59-785| [ KERNEL] [ 1.207941] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.208004] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
18-19-59-785| [ KERNEL] [ 1.208283] NET: Registered protocol family 1
18-19-59-785| [ KERNEL] [ 2.457354] Initialise system trusted keyrings
18-19-59-785| [ KERNEL] [ 2.457524] workingset: timestamp_bits=30 max_order=18 bucket_order=0
18-19-59-785| [ KERNEL] [ 2.631921] Key type asymmetric registered
18-19-59-785| [ KERNEL] [ 2.631945] Asymmetric key parser 'x509' registered
18-19-59-785| [ KERNEL] [ 2.632084] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
18-19-59-785| [ KERNEL] [ 2.634390] bcm2708_fb soc:fb: FB found 1 display(s)
18-19-59-785| [ KERNEL] [ 2.683854] Console: switching to colour frame buffer device 240x67
18-19-59-785| [ KERNEL] [ 2.723024] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
18-19-59-785| [ KERNEL] [ 2.730392] bcm2835-rng 3f104000.rng: hwrng registered
18-19-59-785| [ KERNEL] [ 2.731168] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
18-19-59-785| [ KERNEL] [ 2.739931] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
18-19-59-785| [ KERNEL] [ 2.745563] zram: Added device: zram0
18-19-59-785| [ KERNEL] [ 2.748732] libphy: Fixed MDIO Bus: probed
18-19-59-785| [ KERNEL] [ 2.748839] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
18-19-59-785| [ KERNEL] [ 3.477288] Core Release: 2.80a
18-19-59-785| [ KERNEL] [ 3.477309] Setting default values for core params
18-19-59-785| [ KERNEL] [ 3.477353] Finished setting default values for core params
18-19-59-785| [ KERNEL] [ 3.677717] Using Buffer DMA mode
18-19-59-785| [ KERNEL] [ 3.677729] Periodic Transfer Interrupt Enhancement - disabled
18-19-59-785| [ KERNEL] [ 3.677737] Multiprocessor Interrupt Enhancement - disabled
18-19-59-785| [ KERNEL] [ 3.677752] OTG VER PARAM: 0, OTG VER FLAG: 0
18-19-59-785| [ KERNEL] [ 3.677807] Dedicated Tx FIFOs mode
18-19-59-785| [ KERNEL] [ 3.678747]
18-19-59-785| [ KERNEL] [ 3.678777] WARN::dwc_otg_hcd_init
FIQ DMA bounce buffers: virt = b6114000 dma = 0xf6114000 len=9024
18-19-59-785| [ KERNEL] [ 3.678817] FIQ FSM acceleration enabled for :
18-19-59-785| [ KERNEL] [ 3.678817] Non-periodic Split Transactions
18-19-59-785| [ KERNEL] [ 3.678817] Periodic Split Transactions
18-19-59-785| [ KERNEL] [ 3.678817] High-Speed Isochronous Endpoints
18-19-59-785| [ KERNEL] [ 3.678817] Interrupt/Control Split Transaction hack enabled
18-19-59-785| [ KERNEL] [ 3.678829] dwc_otg: Microframe scheduler enabled
18-19-59-785| [ KERNEL] [ 3.678883]
18-19-59-785| [ KERNEL] [ 3.678895] WARN::hcd_init_fiq:457: FIQ on core 1
18-19-59-785| [ KERNEL] [ 3.678902]
18-19-59-785| [ KERNEL] [ 3.678913] WARN::hcd_init_fiq:458: FIQ ASM at 80426308 length 36
18-19-59-785| [ KERNEL] [ 3.678922]
18-19-59-785| [ KERNEL] [ 3.678932] WARN::hcd_init_fiq:497: MPHI regs_base at ba810000
18-19-59-785| [ KERNEL] [ 3.678962] dwc_otg 3f980000.usb: DWC OTG Controller
18-19-59-785| [ KERNEL] [ 3.679006] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
18-19-59-785| [ KERNEL] [ 3.679066] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
18-19-59-785| [ KERNEL] [ 3.679122] Init: Port Power? op_state=1
18-19-59-785| [ KERNEL] [ 3.679130] Init: Power Port (0)
18-19-59-785| [ KERNEL] [ 3.679396] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
18-19-59-785| [ KERNEL] [ 3.679411] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
18-19-59-785| [ KERNEL] [ 3.679424] usb usb1: Product: DWC OTG Controller
18-19-59-785| [ KERNEL] [ 3.679436] usb usb1: Manufacturer: Linux 5.10.50-v7 dwc_otg_hcd
18-19-59-785| [ KERNEL] [ 3.679446] usb usb1: SerialNumber: 3f980000.usb
18-19-59-785| [ KERNEL] [ 3.680450] hub 1-0:1.0: USB hub found
18-19-59-785| [ KERNEL] [ 3.680539] hub 1-0:1.0: 1 port detected
18-19-59-785| [ KERNEL] [ 3.682170] dwc_otg: FIQ enabled
18-19-59-785| [ KERNEL] [ 3.682188] dwc_otg: NAK holdoff enabled
18-19-59-785| [ KERNEL] [ 3.682196] dwc_otg: FIQ split-transaction FSM enabled
18-19-59-785| [ KERNEL] [ 3.682304] Module dwc_common_port init
18-19-59-785| [ KERNEL] [ 3.690936] usbcore: registered new interface driver usbtouchscreen
18-19-59-785| [ KERNEL] [ 3.693579] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
18-19-59-785| [ KERNEL] [ 3.694698] sdhci: Secure Digital Host Controller Interface driver
18-19-59-785| [ KERNEL] [ 3.694714] sdhci: Copyright(c) Pierre Ossman
18-19-59-785| [ KERNEL] [ 3.695881] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
18-19-59-785| [ KERNEL] [ 3.696146] sdhci-pltfm: SDHCI platform and OF driver helper
18-19-59-785| [ KERNEL] [ 3.696706] hid: raw HID events driver (C) Jiri Kosina
18-19-59-785| [ KERNEL] [ 3.699619] usbcore: registered new interface driver usbhid
18-19-59-785| [ KERNEL] [ 3.699644] usbhid: USB HID core driver
18-19-59-785| [ KERNEL] [ 3.746978] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
18-19-59-785| [ KERNEL] [ 3.747010] [vc_sm_connected_init]: start
18-19-59-785| [ KERNEL] [ 3.756148] [vc_sm_connected_init]: installed successfully
18-19-59-785| [ KERNEL] [ 3.756773] NET: Registered protocol family 17
18-19-59-785| [ KERNEL] [ 3.757309] Registering SWP/SWPB emulation handler
18-19-59-785| [ KERNEL] [ 3.761415] Loading compiled-in X.509 certificates
18-19-59-785| [ KERNEL] [ 3.764184] uart-pl011 3f201000.serial: cts_event_workaround enabled
18-19-59-785| [ KERNEL] [ 3.764332] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
18-19-59-785| [ KERNEL] [ 3.768000] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
18-19-59-785| [ KERNEL] [ 3.782160] sdhost: log_buf @ (ptrval) (f6113000)
18-19-59-785| [ KERNEL] [ 3.805727] Indeed it is in host mode hprt0 = 00021501
18-19-59-785| [ KERNEL] [ 3.879257] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
18-19-59-785| [ KERNEL] [ 3.885841] of_cfs_init
18-19-59-785| [ KERNEL] [ 3.886080] of_cfs_init: OK
18-19-59-785| [ KERNEL] [ 3.891682] random: fast init done
18-19-59-785| [ KERNEL] [ 3.905694] Freeing unused kernel memory: 3072K
18-19-59-785| [ KERNEL] [ 3.955858] Run /init as init process
18-19-59-785| [ KERNEL] [ 3.955873] with arguments:
18-19-59-785| [ KERNEL] [ 3.955880] /init
18-19-59-785| [ KERNEL] [ 3.955887] with environment:
18-19-59-785| [ KERNEL] [ 3.955896] HOME=/
18-19-59-785| [ KERNEL] [ 3.955902] TERM=linux
18-19-59-785| [ KERNEL] [ 3.955912] wtboot=mmc
18-19-59-785| [ KERNEL] [ 3.969185] mmc0: host does not support reading read-only switch, assuming write-enable
18-19-59-785| [ KERNEL] [ 3.972946] mmc0: new high speed SDHC card at address aaaa
18-19-59-785| [ KERNEL] [ 3.974099] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
18-19-59-785| [ KERNEL] [ 3.976967] mmcblk0: p1
18-19-59-785| [ KERNEL] [ 4.015525] usb 1-1: new high-speed USB device number 2 using dwc_otg
18-19-59-785| [ KERNEL] [ 4.015760] Indeed it is in host mode hprt0 = 00001101
18-19-59-785| [ KERNEL] [ 4.255800] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
18-19-59-785| [ KERNEL] [ 4.255828] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
18-19-59-785| [ KERNEL] [ 4.256844] hub 1-1:1.0: USB hub found
18-19-59-785| [ KERNEL] [ 4.257031] hub 1-1:1.0: 5 ports detected
18-19-59-785| [ pfac] [ 4.313379] Run /sbin/initrd.
18-19-59-785| [ pfac] [ 4.313839] Ok, PID 662.
18-19-59-785| [ initrd] [ 4.319749] WTware 6.0.56/RPi shell.
18-19-59-785| [ initrd] [ 4.320592] Load font 'ter-c32b.psf', console 120x33.
18-19-59-785| [ initrd] [ 4.370526] HDD/MMC/SD boot.
18-19-59-785| [ initrd] [ 4.370773] No device '/dev/fb1'.
18-19-59-785| [ initrd] [ 4.443032] Success: /dev/mmcblk0p1 mounted to /bootmedia.
18-19-59-785| /--- FILE "/bootmedia/config.txt" -----------------------
18-19-59-785| | # For more options and information see:
18-19-59-785| | #
18-19-59-785| | # https://www.raspberrypi.org/documentati ... /README.md
18-19-59-785| | #
18-19-59-785| | disable_overscan=1
18-19-59-785| | # Uncomment if hdmi display is not detected and composite is being output.
18-19-59-785| | #hdmi_force_hotplug=1
18-19-59-785| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
18-19-59-785| | #hdmi_drive=2
18-19-59-785| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
18-19-59-785| | # no display.
18-19-59-785| | #config_hdmi_boost=4
18-19-59-785| | # Uncomment to overclock the arm. 700 MHz is the default.
18-19-59-785| | #arm_freq=800
18-19-59-785| | gpu_mem=96
18-19-59-785| | disable_splash=1
18-19-59-785| | framebuffer_depth=32
18-19-59-785| | # Uncomment for 16-bit color.
18-19-59-785| | #framebuffer_depth=16
18-19-59-785| | # Enable onboard audio (HDMI or jack).
18-19-59-785| | dtparam=audio=on
18-19-59-785| | # Removes the warning overlay.
18-19-59-785| | #avoid_warnings=1
18-19-59-785| | # Additionally allows turbo when low-voltage is present.
18-19-59-785| | #avoid_warnings=2
18-19-59-785| | [pi4]
18-19-59-785| | max_framebuffers=2
18-19-59-785| | [all]
18-19-59-785| | # Uncomment these two lines to set display resolution:
18-19-59-785| | #hdmi_group=2
18-19-59-785| | #hdmi_mode=58
18-19-59-785| | #
18-19-59-785| | # Specify correct value in hdmi_mode= line from the list of valid values:
18-19-59-785| | # 800x600: hdmi_mode=9
18-19-59-785| | # 1024x768: hdmi_mode=16
18-19-59-785| | # 1280x1024: hdmi_mode=35
18-19-59-785| | # 1360x768: hdmi_mode=39
18-19-59-785| | # 1400x1050: hdmi_mode=42
18-19-59-785| | # 1440x900: hdmi_mode=47
18-19-59-785| | # 1600x1200: hdmi_mode=51
18-19-59-785| | # 1680x1050: hdmi_mode=58
18-19-59-785| | # 1366x768: hdmi_mode=81
18-19-59-785| | # 1920x1080: hdmi_mode=82
18-19-59-785| | # 1920x1200: hdmi_mode=69
18-19-59-785| | #
18-19-59-785| | # Find more resolutions in manual:
18-19-59-785| | # https://www.raspberrypi.org/documentati ... t/video.md
18-19-59-785| | #
18-19-59-785| | # Uncomment six lines with such syntax and right hdmi_mode= values for
18-19-59-785| | # dual displays on Raspberry Pi 4:
18-19-59-785| | #
18-19-59-785| | #[HDMI:0]
18-19-59-785| | # hdmi_group=2
18-19-59-785| | # hdmi_mode=42
18-19-59-785| | #[HDMI:1]
18-19-59-785| | # hdmi_mode=58
18-19-59-785| \----------------------------------------------------
18-19-59-785| [ KERNEL] [ 4.575438] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
18-19-59-785| [ KERNEL] [ 4.705786] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
18-19-59-785| [ KERNEL] [ 4.705808] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
18-19-59-785| [ KERNEL] [ 4.805436] usb 1-1.5: new low-speed USB device number 4 using dwc_otg
18-19-59-785| [ KERNEL] [ 4.946755] usb 1-1.5: New USB device found, idVendor=1bcf, idProduct=05cf, bcdDevice= 6.0b
18-19-59-785| [ KERNEL] [ 4.946775] usb 1-1.5: New USB device strings: Mfr=0, Product=2, SerialNumber=0
18-19-59-785| [ KERNEL] [ 4.946787] usb 1-1.5: Product: Si lverCrest STMS 2219 A1
18-19-59-785| [ KERNEL] [ 4.962824] input: Si lverCrest STMS 2219 A1 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:1BCF:05CF.0001/input/input0
18-19-59-785| [ KERNEL] [ 5.027152] hid-generic 0003:1BCF:05CF.0001: input,hidraw0: USB HID v1.00 Keyboard [Si lverCrest STMS 2219 A1] on usb-3f980000.usb-1.5/input0
18-19-59-785| [ KERNEL] [ 5.045801] input: Si lverCrest STMS 2219 A1 Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1BCF:05CF.0002/input/input1
18-19-59-785| [ KERNEL] [ 5.046404] input: Si lverCrest STMS 2219 A1 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1BCF:05CF.0002/input/input2
18-19-59-785| [ KERNEL] [ 5.047009] input: Si lverCrest STMS 2219 A1 Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1BCF:05CF.0002/input/input3
18-19-59-785| [ KERNEL] [ 5.126136] input: Si lverCrest STMS 2219 A1 System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.1/0003:1BCF:05CF.0002/input/input4
18-19-59-785| [ KERNEL] [ 5.127269] hid-generic 0003:1BCF:05CF.0002: input,hiddev96,hidraw1: USB HID v1.00 Mouse [Si lverCrest STMS 2219 A1] on usb-3f980000.usb-1.5/input1
18-19-59-785| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
18-19-59-785| | clientIP = *
18-19-59-785| | config = network
18-19-59-785| [ initrd] [ 5.286353] Do not cache package files.
18-19-59-785| [ initrd] [ 5.286527] WTpassword empty.
18-19-59-785| [ initrd] [ 5.286646] Unpack /bootmedia/packages/pi2-lib.
18-19-59-785| [ initrd] [ 7.674159] USB: 1bcf:05cf Sunplus Innovation Technology Inc. Micro keyboard & mouse receiver.
18-19-59-785| [ initrd] [ 7.674515] USB: 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter.
18-19-59-785| [ initrd] [ 7.674718] USB: 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub.
18-19-59-785| [ initrd] [ 7.718146] Load Ethernet drivers.
18-19-59-785| [ initrd] [ 7.718456] modprobe lan78xx.
18-19-59-785| [ initrd] [ 7.732464] modprobe smsc95xx.
18-19-59-785| [ KERNEL] [ 7.736135] usbcore: registered new interface driver lan78xx
18-19-59-785| [ KERNEL] [ 7.752382] smsc95xx v2.0.0
18-19-59-785| [ KERNEL] [ 7.835245] libphy: smsc95xx-mdiobus: probed
18-19-59-785| [ KERNEL] [ 7.837252] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:9d:34:a7
18-19-59-785| [ KERNEL] [ 7.837586] usbcore: registered new interface driver smsc95xx
18-19-59-785| [ initrd] [ 7.895328] WTpassword empty.
18-19-59-785| [ KERNEL] [ 7.899141] Generic PHY usb-001:003:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
18-19-59-785| [ KERNEL] [ 7.899733] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
18-19-59-785| [ KERNEL] [ 7.905352] smsc95xx 1-1.1:1.0 eth0: Link is Down
18-19-59-785| [ KERNEL] [ 9.996667] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
18-19-59-785| [ initrd] [ 10.212941] dhcp: 576 bytes from 192.168.1.1.
18-19-59-785| [ initrd] [ 10.213110] 00000000:0000022C0000000000110000C0A80101C0A8016D00430044022C000002010600 ...,..............m.C.D.,......
18-19-59-785| [ initrd] [ 10.213261] 00000020:67458B6B0000000000000000C0A8016D0000000000000000B827EB9D34A70000 gE.k...........m.........'..4...
18-19-59-785| [ initrd] [ 10.213375] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213481] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213585] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213689] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213792] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213895] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.213998] 00000100:0000000000000000638253633501023604C0A801013304000138A70104FFFFFF ........c.Sc5..6.....3...8......
18-19-59-785| [ initrd] [ 10.214101] 00000120:000304C0A801010604C0A80101FF000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.449032] dhcp: 343 bytes from 192.168.1.101.
18-19-59-785| [ initrd] [ 10.449174] 00000000:000001430000000000110000C0A80165C0A8016D004300440143000002010600 ...C..........e...m.C.D.C......
18-19-59-785| [ initrd] [ 10.449284] 00000020:67458B6B0000000000000000C0A8016DC0A8016500000000B827EB9D34A70000 gE.k...........m...e.....'..4...
18-19-59-785| [ initrd] [ 10.449395] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.449502] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.449609] 00000080:0000000000000000362E302E35365C6B65726E656C372E696D67000000000000 ........6.0.56\kernel7.img......
18-19-59-785| [ initrd] [ 10.449712] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.449815] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.449918] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 10.450064] 00000100:0000000000000000638253633501023604C0A801650104FFFFFF000604C0A801 ........c.Sc5..6....e...........
18-19-59-785| [ initrd] [ 10.450183] 00000120:011A0205DC420E3139322E3136382E312E313031004313362E302E35365C6B65 ....B.192.168.1.101.C6.0.56\ke
18-19-59-785| [ initrd] [ 10.450289] Discard second offer for 192.168.1.109.
18-19-59-785| [ initrd] [ 11.982665] dhcp: 576 bytes from 192.168.1.1.
18-19-59-785| [ initrd] [ 11.982832] 00000000:0000022C0000000000110000C0A80101C0A8016D00430044022C000002010600 ...,..............m.C.D.,......
18-19-59-785| [ initrd] [ 11.982952] 00000020:67458B6B0000000000000000C0A8016D0000000000000000B827EB9D34A70000 gE.k...........m.........'..4...
18-19-59-785| [ initrd] [ 11.983064] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983168] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983272] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983377] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983480] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983583] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 11.983689] 00000100:0000000000000000638253633501053604C0A801013304000151800104FFFFFF ........c.Sc5..6.....3...Q......
18-19-59-785| [ initrd] [ 11.983819] 00000120:000304C0A801010604C0A80101FF000000000000000000000000000000000000 ................................
18-19-59-785| [ initrd] [ 12.020152] [DHCP] DHCP server address 192.168.1.1.
18-19-59-785| [ initrd] [ 12.020284] [DHCP] IP 192.168.1.109 mask 255.255.255.0.
18-19-59-785| [ initrd] [ 12.020400] [DHCP] Default gateway 192.168.1.1.
18-19-59-785| [ initrd] [ 12.020515] [DHCP] DNS 192.168.1.1.
18-19-59-785| [ initrd] [ 12.020637] [DHCP] TFTP = DHCP 192.168.1.1.
18-19-59-785| [ initrd] [ 12.020755] [DHCP] TFTP 192.168.1.1.
18-19-59-785| [ initrd] [ 12.020869] [DHCP] No boot file from DHCP.
18-19-59-785| [ initrd] [ 12.020987] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
18-19-59-785| WTC listener is active.
18-19-59-785| WTC broadcast listener is active.
18-19-59-785| Send broadcast WTCU discover.
18-19-59-785| [ pfac] [ 12.024723] Run /sbin/httpd.
18-19-59-785| [ initrd] [ 12.024881] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
18-19-59-785| [ pfac] [ 12.025040] Ok, PID 717.
18-19-59-785| [ initrd] [ 12.025117] [TFTP] Download config file Everyone/source.wtc from 192.168.1.1.
18-19-59-785| [ httpd] [ 12.040088] Internal HTTP Server, WTware 6.0.56/RPi
18-19-59-785| [ initrd] [ 12.530230] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 13.040181] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 13.550151] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ KERNEL] [ 14.055481] random: crng init done
18-19-59-785| [ initrd] [ 14.070293] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 14.580165] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 15.090140] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 15.600141] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 16.110135] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 16.620138] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 17.130126] [TFTP] Got EAGAIN, resend wtware hello.
18-19-59-785| [ initrd] [ 17.640143] [TFTP] recv() return -1, errno 11.
18-19-59-785| [ initrd] [ 30.350184] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 30.350440] [TFTP] Download config file Everyone/list.wtc from 192.168.1.1.
18-19-59-785| [ initrd] [ 43.060166] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 43.060403] [TFTP] Download config file Terminals/B8.27.EB.9D.34.A7/config.wtc from 192.168.1.1.
18-19-59-785| [ initrd] [ 55.770167] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 55.770354] [TFTP] Download config file Terminals/B8.27.EB.9D.34.A7.wtc from 192.168.1.1.
18-19-59-785| [ initrd] [ 68.480150] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 68.480319] [TFTP] Download config file Everyone/default.wtc from 192.168.1.1.
18-19-59-785| [ initrd] [ 81.190157] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 81.190320] [TFTP] Download config file Everyone/all.wtc from 192.168.1.1.
18-19-59-785| [ initrd] [ 93.900158] tftp.cpp ( 942): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 93.901202] Local config not found. Fatal error.
18-19-59-785| [ initrd] [ 98.210466] globalConfig.cpp ( 1157): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ initrd] [ 98.210652] [NTP] 42 DHCP option is not set.
18-19-59-785| Everyone can control terminal by RSH.
18-19-59-785| RSH: listener is active.
18-19-59-785| [ initrd] [ 98.217697] Start video wizard.
18-19-59-785| [ initrd] [ 98.217890] globalConfig.cpp ( 1157): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ httpd] [ 98.217986] Reread settings.
18-19-59-785| [ initrd] [ 98.218120] Unpack /bootmedia/packages/pi2-f.
18-19-59-785| [ httpd] [ 98.218199] Everyone can control terminal by HTTP.
18-19-59-785| [ gm] [ 98.759694] WTware 6.0.56/RPi session manager.
18-19-59-785| [ gm] [ 98.760686] Create empty config file.
18-19-59-785| [ gm] [ 98.761333] Keys found. Add event4: Si lverCrest STMS 2219 A1 System Control.
18-19-59-785| [ gm] [ 98.761490] EV_REL flag found. Add event3: Si lverCrest STMS 2219 A1 Consumer Control.
18-19-59-785| [ gm] [ 98.761631] EV_ABS flag found. Add event2: Si lverCrest STMS 2219 A1.
18-19-59-785| [ gm] [ 98.761762] EV_REL flag found. Add event1: Si lverCrest STMS 2219 A1 Mouse.
18-19-59-785| [ gm] [ 98.761908] Keys found. Add event0: Si lverCrest STMS 2219 A1.
18-19-59-785| [ gm] [ 98.762056] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
18-19-59-785| [ gm] [ 100.339937] Framebuffer device found.
18-19-59-785| [ gm] [ 100.340235] LINELENBYTES 7680
18-19-59-785| [ gm] [ 100.340376] VLEN 8294400
18-19-59-785| [ gm] [ 100.345548] Use /lib/ui32.so.
18-19-59-785| [ gm] [ 100.346430] Wizard mode, choose server.
18-19-59-785| [ gm] [ 110.844765] Run '/sbin/resolver 0x1acebf0 dns [192.168.1.101]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 110.845491] Run /sbin/resolver 0x1acebf0 dns [192.168.1.101].
18-19-59-785| [ pfac] [ 110.845858] Ok, PID 718.
18-19-59-785| [ pfac] [ 110.857775] Process pid 718 terminated, status 00000000.
18-19-59-785| [ gm] [ 110.861905] 192.168.1.101 => 192.168.1.101.
18-19-59-785| [ gm] [ 110.874778] Free ram before fork terminal client /sbin/rdpclient (session 1): 895404 Kb.
18-19-59-785| [ pfac] [ 110.875752] Run /sbin/rdpclient 1.
18-19-59-785| [ gm] [ 110.875884] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
18-19-59-785| [ pfac] [ 110.876047] Ok, PID 719.
18-19-59-785| [ rdpclient 719] [ 110.901793] RDP Terminal Client, WTware 6.0.56/RPi, pipe 1, pid 719.
18-19-59-785| [ rdpclient 719] [ 110.902310] Use /lib/ui32.so.
18-19-59-785| [ rdpclient 719] [ 110.903428] tsclient-main.cpp ( 757): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 719] [ 110.904478] Make RDP session with 192.168.1.101, port 3389.
18-19-59-785| [ rdpclient 719] [ 110.904952] No username.
18-19-59-785| [ rdpclient 719] [ 110.905444] No password.
18-19-59-785| [ rdpclient 719] [ 110.905814] No PIN.
18-19-59-785| [ rdpclient 719] [ 110.906152] No domain.
18-19-59-785| [ rdpclient 719] [ 110.906456] No shell.
18-19-59-785| [ rdpclient 719] [ 110.906750] No directory.
18-19-59-785| [ rdpclient 719] [ 110.907059] Window: 1856x1080@24.
18-19-59-785| [ rdpclient 719] [ 110.907311] PFlags 0x0000002F.
18-19-59-785| [ rdpclient 719] [ 110.907574] Keyboard 00000409:00000000.
18-19-59-785| [ rdpclient 719] [ 110.907805] My hostname "ERROR".
18-19-59-785| [ rdpclient 719] [ 110.908054] TCP: connecting to 192.168.1.101:3389.
18-19-59-785| [ rdpclient 719] [ 140.936100] select () timed out.
18-19-59-785| [ rdpclient 719] [ 140.936363] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 719] [ 140.936526] Server 192.168.1.101, port 3389: connection rejected.
18-19-59-785| Make sure that terminal service works on this server.
18-19-59-785| Try to connect using mstsc.exe.
18-19-59-785| [ gm] [ 140.937142] Session is over. Final message: Server 192.168.1.101, port 3389: connection rejected.
18-19-59-785| [ pfac] [ 140.939194] Process pid 719 terminated, status 00000009.
18-19-59-785| [ gm] [ 152.920357] Run '/sbin/resolver 0x1acebf0 dns [192.168.1.1]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 152.921090] Run /sbin/resolver 0x1acebf0 dns [192.168.1.1].
18-19-59-785| [ pfac] [ 152.921572] Ok, PID 720.
18-19-59-785| [ pfac] [ 152.932240] Process pid 720 terminated, status 00000000.
18-19-59-785| [ gm] [ 152.937611] 192.168.1.1 => 192.168.1.1.
18-19-59-785| [ gm] [ 152.949823] Free ram before fork terminal client /sbin/rdpclient (session 2): 894908 Kb.
18-19-59-785| [ pfac] [ 152.950235] Run /sbin/rdpclient 2.
18-19-59-785| [ gm] [ 152.950370] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
18-19-59-785| [ pfac] [ 152.950576] Ok, PID 721.
18-19-59-785| [ rdpclient 721] [ 152.976269] RDP Terminal Client, WTware 6.0.56/RPi, pipe 2, pid 721.
18-19-59-785| [ rdpclient 721] [ 152.976932] Use /lib/ui32.so.
18-19-59-785| [ rdpclient 721] [ 152.978075] tsclient-main.cpp ( 757): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 721] [ 152.983146] Make RDP session with 192.168.1.1, port 3389.
18-19-59-785| [ rdpclient 721] [ 152.983914] No username.
18-19-59-785| [ rdpclient 721] [ 152.984353] No password.
18-19-59-785| [ rdpclient 721] [ 152.984698] No PIN.
18-19-59-785| [ rdpclient 721] [ 152.985026] No domain.
18-19-59-785| [ rdpclient 721] [ 152.985321] No shell.
18-19-59-785| [ rdpclient 721] [ 152.985607] No directory.
18-19-59-785| [ rdpclient 721] [ 152.985894] Window: 1856x1080@24.
18-19-59-785| [ rdpclient 721] [ 152.986189] PFlags 0x0000002F.
18-19-59-785| [ rdpclient 721] [ 152.986477] Keyboard 00000409:00000000.
18-19-59-785| [ rdpclient 721] [ 152.986762] My hostname "ERROR".
18-19-59-785| [ rdpclient 721] [ 152.987047] TCP: connecting to 192.168.1.1:3389.
18-19-59-785| [ rdpclient 721] [ 152.987864] Connection failed with errno 111.
18-19-59-785| [ rdpclient 721] [ 153.988035] Got errno: 103.
18-19-59-785| [ rdpclient 721] [ 154.988863] Connection failed with errno 111.
18-19-59-785| [ rdpclient 721] [ 155.989323] Got errno: 103.
18-19-59-785| [ gm] [ 155.990374] Session is over. Final message: Server 192.168.1.1, port 3389: connection rejected.
18-19-59-785| [ rdpclient 721] [ 155.990535] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 721] [ 155.990723] Server 192.168.1.1, port 3389: connection rejected.
18-19-59-785| [ pfac] [ 155.991992] Process pid 721 terminated, status 00000009.
18-19-59-785| [ gm] [ 167.100569] Run '/sbin/resolver 0x1acebf0 dns [192.168.1.107]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 167.101313] Run /sbin/resolver 0x1acebf0 dns [192.168.1.107].
18-19-59-785| [ pfac] [ 167.101699] Ok, PID 722.
18-19-59-785| [ pfac] [ 167.113081] Process pid 722 terminated, status 00000000.
18-19-59-785| [ gm] [ 167.117610] 192.168.1.107 => 192.168.1.107.
18-19-59-785| [ gm] [ 167.129904] Free ram before fork terminal client /sbin/rdpclient (session 3): 894648 Kb.
18-19-59-785| [ pfac] [ 167.130969] Run /sbin/rdpclient 3.
18-19-59-785| [ gm] [ 167.131096] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
18-19-59-785| [ pfac] [ 167.131248] Ok, PID 723.
18-19-59-785| [ rdpclient 723] [ 167.156879] RDP Terminal Client, WTware 6.0.56/RPi, pipe 3, pid 723.
18-19-59-785| [ rdpclient 723] [ 167.157321] Use /lib/ui32.so.
18-19-59-785| [ rdpclient 723] [ 167.158405] tsclient-main.cpp ( 757): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 723] [ 167.159138] Make RDP session with 192.168.1.107, port 3389.
18-19-59-785| [ rdpclient 723] [ 167.159587] No username.
18-19-59-785| [ rdpclient 723] [ 167.159933] No password.
18-19-59-785| [ rdpclient 723] [ 167.160424] No PIN.
18-19-59-785| [ rdpclient 723] [ 167.160787] No domain.
18-19-59-785| [ rdpclient 723] [ 167.161106] No shell.
18-19-59-785| [ rdpclient 723] [ 167.161409] No directory.
18-19-59-785| [ rdpclient 723] [ 167.161690] Window: 1856x1080@24.
18-19-59-785| [ rdpclient 723] [ 167.161973] PFlags 0x0000002F.
18-19-59-785| [ rdpclient 723] [ 167.162239] Keyboard 00000409:00000000.
18-19-59-785| [ rdpclient 723] [ 167.162496] My hostname "ERROR".
18-19-59-785| [ rdpclient 723] [ 167.162714] TCP: connecting to 192.168.1.107:3389.
18-19-59-785| [ rdpclient 723] [ 170.310662] Connection failed with errno 113.
18-19-59-785| [ rdpclient 723] [ 171.310787] Got errno: 103.
18-19-59-785| [ rdpclient 723] [ 171.310971] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 723] [ 171.311128] Server 192.168.1.107, port 3389: connection rejected.
18-19-59-785| [ gm] [ 171.311796] Session is over. Final message: Server 192.168.1.107, port 3389: connection rejected.
18-19-59-785| [ pfac] [ 171.313331] Process pid 723 terminated, status 00000009.
18-19-59-785| [ gm] [ 209.870475] Run '/sbin/resolver 0x1acebf0 dns [pol]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 209.871204] Run /sbin/resolver 0x1acebf0 dns [pol].
18-19-59-785| [ pfac] [ 209.871679] Ok, PID 724.
18-19-59-785| [ resolver ebf0] [ 209.905611] Lookup for "pol" failed, errors 0 -2.
18-19-59-785| [ gm] [ 209.905930] Failed to resolve pol.
18-19-59-785| [ gm] [ 209.906181] Message: 'Failed to convert pol to IP address.
18-19-59-785| Possibly, DNS-server doesn't work or is not specified.', timer 0.
18-19-59-785| [ pfac] [ 209.906679] Process pid 724 terminated, status 00000000.
18-19-59-785| [ gm] [ 229.275474] Run '/sbin/resolver 0x1acebf0 dns [192.168.1.108]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 229.276017] Run /sbin/resolver 0x1acebf0 dns [192.168.1.108].
18-19-59-785| [ pfac] [ 229.276777] Ok, PID 725.
18-19-59-785| [ pfac] [ 229.291469] Process pid 725 terminated, status 00000000.
18-19-59-785| [ gm] [ 229.293966] 192.168.1.108 => 192.168.1.108.
18-19-59-785| [ gm] [ 229.306291] Free ram before fork terminal client /sbin/rdpclient (session 4): 894664 Kb.
18-19-59-785| [ pfac] [ 229.306616] Run /sbin/rdpclient 4.
18-19-59-785| [ gm] [ 229.306735] Run '/sbin/rdpclient 4', log '/tmp/rdpclient.out', env '', pid ''.
18-19-59-785| [ pfac] [ 229.306989] Ok, PID 726.
18-19-59-785| [ rdpclient 726] [ 229.332626] RDP Terminal Client, WTware 6.0.56/RPi, pipe 4, pid 726.
18-19-59-785| [ rdpclient 726] [ 229.333260] Use /lib/ui32.so.
18-19-59-785| [ rdpclient 726] [ 229.334438] tsclient-main.cpp ( 757): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 726] [ 229.341326] Make RDP session with 192.168.1.108, port 3389.
18-19-59-785| [ rdpclient 726] [ 229.342113] No username.
18-19-59-785| [ rdpclient 726] [ 229.342700] No password.
18-19-59-785| [ rdpclient 726] [ 229.343276] No PIN.
18-19-59-785| [ rdpclient 726] [ 229.345444] No domain.
18-19-59-785| [ rdpclient 726] [ 229.346028] No shell.
18-19-59-785| [ rdpclient 726] [ 229.346352] No directory.
18-19-59-785| [ rdpclient 726] [ 229.346595] Window: 1856x1080@24.
18-19-59-785| [ rdpclient 726] [ 229.347142] PFlags 0x0000002F.
18-19-59-785| [ rdpclient 726] [ 229.347494] Keyboard 00000409:00000000.
18-19-59-785| [ rdpclient 726] [ 229.347921] My hostname "ERROR".
18-19-59-785| [ rdpclient 726] [ 229.348352] TCP: connecting to 192.168.1.108:3389.
18-19-59-785| [ rdpclient 726] [ 232.470643] Connection failed with errno 113.
18-19-59-785| [ rdpclient 726] [ 233.471047] Got errno: 103.
18-19-59-785| [ rdpclient 726] [ 233.471246] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 726] [ 233.471388] Server 192.168.1.108, port 3389: connection rejected.
18-19-59-785| [ gm] [ 233.473568] Session is over. Final message: Server 192.168.1.108, port 3389: connection rejected.
18-19-59-785| [ pfac] [ 233.474008] Process pid 726 terminated, status 00000009.
18-19-59-785| [ gm] [ 247.379465] Run '/sbin/resolver 0x1acebf0 dns [192.168.56.1]', log '', env '', pid ''.
18-19-59-785| [ pfac] [ 247.380409] Run /sbin/resolver 0x1acebf0 dns [192.168.56.1].
18-19-59-785| [ pfac] [ 247.380997] Ok, PID 727.
18-19-59-785| [ pfac] [ 247.392243] Process pid 727 terminated, status 00000000.
18-19-59-785| [ gm] [ 247.397453] 192.168.56.1 => 192.168.56.1.
18-19-59-785| [ gm] [ 247.409741] Free ram before fork terminal client /sbin/rdpclient (session 5): 894640 Kb.
18-19-59-785| [ pfac] [ 247.410165] Run /sbin/rdpclient 5.
18-19-59-785| [ gm] [ 247.410299] Run '/sbin/rdpclient 5', log '/tmp/rdpclient.out', env '', pid ''.
18-19-59-785| [ pfac] [ 247.410508] Ok, PID 728.
18-19-59-785| [ rdpclient 728] [ 247.436083] RDP Terminal Client, WTware 6.0.56/RPi, pipe 5, pid 728.
18-19-59-785| [ rdpclient 728] [ 247.436729] Use /lib/ui32.so.
18-19-59-785| [ rdpclient 728] [ 247.437827] tsclient-main.cpp ( 757): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 728] [ 247.441339] Make RDP session with 192.168.56.1, port 3389.
18-19-59-785| [ rdpclient 728] [ 247.441932] No username.
18-19-59-785| [ rdpclient 728] [ 247.442524] No password.
18-19-59-785| [ rdpclient 728] [ 247.442855] No PIN.
18-19-59-785| [ rdpclient 728] [ 247.443114] No domain.
18-19-59-785| [ rdpclient 728] [ 247.443346] No shell.
18-19-59-785| [ rdpclient 728] [ 247.443601] No directory.
18-19-59-785| [ rdpclient 728] [ 247.444098] Window: 1856x1080@24.
18-19-59-785| [ rdpclient 728] [ 247.444505] PFlags 0x0000002F.
18-19-59-785| [ rdpclient 728] [ 247.444824] Keyboard 00000409:00000000.
18-19-59-785| [ rdpclient 728] [ 247.445128] My hostname "ERROR".
18-19-59-785| [ rdpclient 728] [ 247.445530] TCP: connecting to 192.168.56.1:3389.
18-19-59-785| [ rdpclient 728] [ 277.472284] select () timed out.
18-19-59-785| [ rdpclient 728] [ 277.472548] rdpclient-tcp.cpp ( 260): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
18-19-59-785| [ rdpclient 728] [ 277.472705] Server 192.168.56.1, port 3389: connection rejected.
18-19-59-785| [ gm] [ 277.473334] Session is over. Final message: Server 192.168.56.1, port 3389: connection rejected.
18-19-59-785| [ pfac] [ 277.474645] Process pid 728 terminated, status 00000009.
18-19-59-785| Connection from wtc.exe at 192.168.1.101.
18-25-02-742| [WTRC] [15.09.2021 18:25:02] Conection with 192.168.1.109:789 failed.
18-25-04-076| [WTRC] [15.09.2021 18:25:04] Conection with 192.168.1.109:789 failed.
18-19-59-785| | #
18-19-59-785| | #
18-19-59-785| | #
18-19-59-785| | #
18-19-59-785| | #
18-19-59-785| | #
Re: Cannot connect
WTware is only the client for RDP protocol server. No RDP server code is installed with WTware. Make sure your desktop answers on RDP. Run mstsc.exe (it comes with every Windows) on another Windows machine and try to mirror your computer's desktop. WTware will not connect until Microsoft mstsc.exe will connect.Gat wrote: Wed Sep 15, 2021 2:44 pm My main objective is to mirror my computers desktop to smart LG TV
Re: Cannot connect
It seems that remote desktop service is not working. I am not sure how to configure it.
I tried enabling it by these two commands:
" reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server" /v fDenyTSConnections /t REG_DWORD /d 0 /f "
"netsh advfirewall firewall set rule group="remote desktop" new enable=Yes"
Re: Cannot connect
Also I wanted to say I have Windows 10 Pro, so remote desktop should work, i really dont know how to fix it
Re: Cannot connect
Why not enable it from GUI?
Picture:
- Untitled.png (39.37 KiB) Viewed 142705 times
Re: Cannot connect
Yes, I am also not sure if its configufred correctly, sending screenshot
- wtware.png (71.58 KiB) Viewed 142703 times
Re: Cannot connect
192.168.1.101 is my PC and then there is 192.168.1.109 which is Raspberry
