Multi ARGOX redirection
edunicacio
Post by edunicacio »
Hello!
We have been using usb redirection to print from a w2003 rdp to an ARGOX OS-214-PLUS connected to a Raspberry PI 4B board with success for more than an year with the settings below:
printer=usb
rdp_printer=Argox OS-214 plus PPLA:usb 1664:019a
Now i need to use 2 usb printers on the same Raspberry PI 4B terminal to print different tags. The printers are both ARGOX OS-214-PLUS.
How would i do that????
Thanks in advance!
Re: Multi ARGOX redirection
This config is wrong:
printer=usb
These are two different methods to share the same printer. Remove one line and try. If it won't work, remove another line.
After you find one line that works for you, connect both printers and send me log: https://wtware.com/logs.html
