does not recognize the USB device
DaniJD
Post by DaniJD »
Good evening,
doing tests for the installation of the software for an academy, I found a problem for the installation or recognition of a USB mic. After making the respective configurations for the detection of the device and testing it by windows mstsc.exe, I check and add parameters for perfect operation, in the mstsc.exe software the microphone recognizes me if "record from this computer" is activated, but It does not detect it on my device in windows with its respective driver.
In the USB bus section it recognizes it but does not support it, (https://thronmax.com/?product=thronmax-fireball)
[2] USB ID: 0d8c:0134, bus ID: 1-1, serial: 20200409, class: 0x00, subclass: 0x00, C-Media Electronics, Inc.
can't get debug descriptor: Resource temporarily unavailable
gth                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        16
  idVendor           0x0d8c
  idProduct          0x0134
  bcdDevice            1.00
  iManufacturer           1 Fireball Usb Microphone
  iProduct                2 Fireball Usb Microphone
  iSerial                 3 20200409
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0098
    bNumInterfaces          3
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      bInterfaceSubClass      1
      bInterfaceProtocol      0
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               1.00
        wTotalLength       0x0027
        bInCollection           1
        baInterfaceNr(0)        1
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bNrChannels             1
        wChannelConfig     0x0001
          Left Front (L)
        iChannelNames           0
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             7
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bSourceID              10
        iTerminal               0
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bControlSize            1
        bmaControls(0)       0x03
          Mute Control
          Volume Control
        bmaControls(1)       0x00
        iFeature                0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      bInterfaceSubClass      2
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         1
      iInterface              0
      AudioStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           7
        bDelay                  1 frames
        wFormatTag         0x0001 PCM
        bLength                29
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bNrChannels             1
        bSubframeSize           2
        bBitResolution         16
        bSamFreqType            7 Discrete
        tSamFreq[ 0]         8000
        tSamFreq[ 1]        11025
        tSamFreq[ 2]        16000
        tSamFreq[ 3]        22050
        tSamFreq[ 4]        32000
        tSamFreq[ 5]        44100
        tSamFreq[ 6]        48000
      Endpoint Descriptor:
        bLength                 9
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes           13
          Transfer Type            Isochronous
          Synch Type               Synchronous
          Usage Type               Data
        wMaxPacketSize     0x0064  1x 100 bytes
        bInterval               1
        bRefresh                0
        bSynchAddress           0
        AudioStreaming Endpoint Descriptor:
          bLength                 7
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x01
            Sampling Frequency
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3
      bInterfaceSubClass      0
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      26
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               1
Device Status:     0x0000
  (Bus Powered)
I would like you to help me with this since in the situation we are in, the PCs should have the zoom app and this leads to having devices for recording (camera, mic, audio, etc)
DaniJD
Re: does not recognize the USB device
Post by DaniJD »
WTware 6.0.34/UEFI supervisor.
[        KERNEL] [    0.000000] Linux version 5.4.96 (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-6)) #4 SMP Tue Feb 9 20:30:11 UTC 2021
[        KERNEL] [    0.000000] Command line:
[        KERNEL] [    0.000000] x86/fpu: x87 FPU will use FXSAVE
[        KERNEL] [    0.000000] BIOS-provided physical RAM map:
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000003efff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000000003f000-0x000000000003ffff] ACPI NVS
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000000040000-0x000000000009dfff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001effffff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000001f000000-0x00000000201fffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000020200000-0x000000007a84cfff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007a84d000-0x000000007a8c6fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007a8c7000-0x000000007a8d8fff] ACPI data
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007a8d9000-0x000000007b22ffff] ACPI NVS
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007b230000-0x000000007b57ffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x000000007b580000-0x000000007bffffff] usable
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000feafffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed03000-0x00000000fed03fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed06000-0x00000000fed06fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed08000-0x00000000fed09fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fedbffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[        KERNEL] [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[        KERNEL] [    0.000000] NX (Execute Disable) protection: active
[        KERNEL] [    0.000000] e820: update [mem 0x7612f018-0x7613f057] usable ==> usable
[        KERNEL] [    0.000000] extended physical RAM map:
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x0000000000000000-0x000000000003efff] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000000003f000-0x000000000003ffff] ACPI NVS
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x0000000000040000-0x000000000009dfff] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000000009e000-0x000000000009ffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x0000000000100000-0x000000001effffff] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000001f000000-0x00000000201fffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x0000000020200000-0x000000007612f017] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007612f018-0x000000007613f057] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007613f058-0x000000007a84cfff] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007a84d000-0x000000007a8c6fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007a8c7000-0x000000007a8d8fff] ACPI data
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007a8d9000-0x000000007b22ffff] ACPI NVS
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007b230000-0x000000007b57ffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x000000007b580000-0x000000007bffffff] usable
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fea00000-0x00000000feafffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed03000-0x00000000fed03fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed06000-0x00000000fed06fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed08000-0x00000000fed09fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fed80000-0x00000000fedbffff] reserved
[          pfac] [    0.981856] Run /sbin/initrd.
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[        KERNEL] [    0.000000] reserve setup_data: [mem 0x0000000100000000-0x000000017fffffff] usable
[        KERNEL] [    0.000000] efi: EFI v2.40 by Acer Inc.
[        KERNEL] [    0.000000] efi:  ESRT=0x7b503098  ACPI=0x7a8ca000  ACPI 2.0=0x7a8ca000  SMBIOS=0x7b444c98  TPMEventLog=0x76141018
[        KERNEL] [    0.000000] [Firmware Bug]: TPM Final Events table missing or invalid
[        KERNEL] [    0.000000] SMBIOS 2.8 present.
[        KERNEL] [    0.000000] DMI: Acer Aspire XC-704/Aspire XC-704, BIOS R01-B2 06/08/2016
[        KERNEL] [    0.000000] tsc: Detected 1600.000 MHz processor
[        KERNEL] [    0.000031] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[        KERNEL] [    0.000036] e820: remove [mem 0x000a0000-0x000fffff] usable
[        KERNEL] [    0.000053] last_pfn = 0x180000 max_arch_pfn = 0x400000000
[        KERNEL] [    0.000058] MTRR default type: uncachable
[        KERNEL] [    0.000060] MTRR fixed ranges enabled:
[        KERNEL] [    0.000062]   00000-9FFFF write-back
[        KERNEL] [    0.000064]   A0000-FFFFF uncachable
[        KERNEL] [    0.000065] MTRR variable ranges enabled:
[        KERNEL] [    0.000068]   0 base 000000000 mask F80000000 write-back
[        KERNEL] [    0.000070]   1 base 07C000000 mask FFC000000 uncachable
[        KERNEL] [    0.000072]   2 base 100000000 mask F80000000 write-back
[        KERNEL] [    0.000074]   3 base 090000000 mask FF0000000 write-through
[        KERNEL] [    0.000076]   4 base 0A0000000 mask FFFF00000 write-through
[        KERNEL] [    0.000077]   5 disabled
[        KERNEL] [    0.000078]   6 disabled
[        KERNEL] [    0.000079]   7 disabled
[        KERNEL] [    0.000181] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[        KERNEL] [    0.000290] last_pfn = 0x7c000 max_arch_pfn = 0x400000000
[        KERNEL] [    0.007570] esrt: Reserving ESRT space from 0x000000007b503098 to 0x000000007b5030d0.
[        KERNEL] [    0.008057] Secure boot disabled
[        KERNEL] [    0.008065] ACPI: Early table checksum verification disabled
[        KERNEL] [    0.008071] ACPI: RSDP 0x000000007A8CA000 000024 (v02 ACRSYS)
[        KERNEL] [    0.008080] ACPI: XSDT 0x000000007A8CA088 000094 (v01 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008090] ACPI: FACP 0x000000007A8D7B90 00010C (v05 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008099] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/32 (20190816/tbfadt-569)
[          pfac] [    0.982161] Ok, PID 876.
[        KERNEL] [    0.008106] ACPI: DSDT 0x000000007A8CA1B0 00D9DC (v02 ACRSYS ACRPRDCT 01072009 INTL 20120913)
[        KERNEL] [    0.008113] ACPI: FACS 0x000000007B20CE80 000040
[        KERNEL] [    0.008118] ACPI: APIC 0x000000007A8D7CA0 000068 (v03 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008124] ACPI: FPDT 0x000000007A8D7D08 000044 (v01 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008130] ACPI: FIDT 0x000000007A8D7D50 00009C (v01 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008135] ACPI: MCFG 0x000000007A8D7DF0 00003C (v01 ACRSYS ACRPRDCT 01072009 MSFT 00000097)
[        KERNEL] [    0.008141] ACPI: MSDM 0x000000007A8D7E30 000055 (v03 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008147] ACPI: SSDT 0x000000007A8D7E88 000763 (v01 PmRef  CpuPm    00003000 INTL 20061109)
[        KERNEL] [    0.008154] ACPI: SSDT 0x000000007A8D85F0 000290 (v01 PmRef  Cpu0Tst  00003000 INTL 20061109)
[        KERNEL] [    0.008161] ACPI: SSDT 0x000000007A8D8880 00017A (v01 PmRef  ApTst    00003000 INTL 20061109)
[        KERNEL] [    0.008168] ACPI: UEFI 0x000000007A8D8A00 000042 (v01 ACRSYS ACRPRDCT 00000000      00000000)
[        KERNEL] [    0.008174] ACPI: LPIT 0x000000007A8D8A48 000104 (v01 ACRSYS ACRPRDCT 00000005 MSFT 0100000D)
[        KERNEL] [    0.008181] ACPI: TPM2 0x000000007A8D8B50 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
[        KERNEL] [    0.008187] ACPI: CSRT 0x000000007A8D8B88 00014C (v00 INTEL  LANFORDC 00000005 MSFT 0100000D)
[        KERNEL] [    0.008194] ACPI: BGRT 0x000000007A8D8CD8 000038 (v01 ACRSYS ACRPRDCT 01072009 AMI  00010013)
[        KERNEL] [    0.008208] ACPI: Local APIC address 0xfee00000
[        KERNEL] [    0.008252] Zone ranges:
[        KERNEL] [    0.008253]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[        KERNEL] [    0.008256]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[        KERNEL] [    0.008260]   Normal   [mem 0x0000000100000000-0x000000017fffffff]
[        KERNEL] [    0.008264] Movable zone start for each node
[        KERNEL] [    0.008265] Early memory node ranges
[        KERNEL] [    0.008267]   node   0: [mem 0x0000000000001000-0x000000000003efff]
[        KERNEL] [    0.008270]   node   0: [mem 0x0000000000040000-0x000000000009dfff]
[        KERNEL] [    0.008272]   node   0: [mem 0x0000000000100000-0x000000001effffff]
[        KERNEL] [    0.008274]   node   0: [mem 0x0000000020200000-0x000000007a84cfff]
[        KERNEL] [    0.008276]   node   0: [mem 0x000000007b580000-0x000000007bffffff]
[        KERNEL] [    0.008278]   node   0: [mem 0x0000000100000000-0x000000017fffffff]
[        KERNEL] [    0.008852] Zeroed struct page in unavailable ranges: 24471 pages
[        KERNEL] [    0.008855] Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
[        KERNEL] [    0.008860] On node 0 totalpages: 1024105
[        KERNEL] [    0.008862]   DMA zone: 64 pages used for memmap
[        KERNEL] [    0.008863]   DMA zone: 21 pages reserved
[        KERNEL] [    0.008865]   DMA zone: 3996 pages, LIFO batch:0
[        KERNEL] [    0.008969]   DMA32 zone: 7748 pages used for memmap
[        KERNEL] [    0.008971]   DMA32 zone: 495821 pages, LIFO batch:63
[        KERNEL] [    0.027775]   Normal zone: 8192 pages used for memmap
[        KERNEL] [    0.027777]   Normal zone: 524288 pages, LIFO batch:63
[        KERNEL] [    0.040485] Reserving Intel graphics memory at [mem 0x7ce00000-0x7edfffff]
[        KERNEL] [    0.040612] ACPI: PM-Timer IO Port: 0x408
[        KERNEL] [    0.040615] ACPI: Local APIC address 0xfee00000
[        KERNEL] [    0.040626] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[        KERNEL] [    0.040628] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[        KERNEL] [    0.040648] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-114
[        KERNEL] [    0.040652] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[        KERNEL] [    0.040655] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[        KERNEL] [    0.040658] ACPI: IRQ0 used by override.
[        KERNEL] [    0.040660] ACPI: IRQ9 used by override.
[        KERNEL] [    0.040665] Using ACPI (MADT) for SMP configuration information
[        KERNEL] [    0.040681] e820: update [mem 0x795f7000-0x79672fff] usable ==> reserved
[        KERNEL] [    0.040701] TSC deadline timer available
[        KERNEL] [    0.040703] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[        KERNEL] [    0.040778] [mem 0x7ee00000-0xdfffffff] available for PCI devices
[        KERNEL] [    0.040781] Booting paravirtualized kernel on bare hardware
[        KERNEL] [    0.040787] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[        KERNEL] [    0.194936] setup_percpu: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:2 nr_node_ids:1
[        KERNEL] [    0.195734] percpu: Embedded 42 pages/cpu s132440 r8192 d31400 u1048576
[        KERNEL] [    0.195753] pcpu-alloc: s132440 r8192 d31400 u1048576 alloc=1*2097152
[        KERNEL] [    0.195755] pcpu-alloc: [0] 0 1
[        KERNEL] [    0.195815] Built 1 zonelists, mobility grouping on.  Total pages: 1008080
[        KERNEL] [    0.195818] Kernel command line: quiet
[        KERNEL] [    0.197225] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[        KERNEL] [    0.197919] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[        KERNEL] [    0.197970] mem auto-init: stack:off, heap alloc:off, heap free:off
[        KERNEL] [    0.252516] Memory: 3881984K/4096420K available (8194K kernel code, 387K rwdata, 1780K rodata, 3116K init, 440K bss, 214436K reserved, 0K cma-reserved)
[        KERNEL] [    0.252662] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[        KERNEL] [    0.252754] rcu: Hierarchical RCU implementation.
[        KERNEL] [    0.252757] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[        KERNEL] [    0.252759] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[        KERNEL] [    0.252761] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[        KERNEL] [    0.252778] NR_IRQS: 4352, nr_irqs: 512, preallocated irqs: 16
[        KERNEL] [    0.253295] random: crng done (trusting CPU's manufacturer)
[        KERNEL] [    0.253343] Console: colour dummy device 80x25
[        KERNEL] [    0.253351] printk: console [tty0] enabled
[        KERNEL] [    0.253361] ACPI: Core revision 20190816
[        KERNEL] [    0.253581] APIC: Switch to symmetric I/O mode setup
[        KERNEL] [    0.254896] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
[        KERNEL] [    0.254906] Calibrating delay loop (skipped), value calculated using timer frequency.. 3200.00 BogoMIPS (lpj=6400000)
[        KERNEL] [    0.254911] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.258900] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.258900] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.258900] mce: CPU0: Thermal monitoring enabled (TM1)
[        KERNEL] [    0.258900] process: using mwait in idle threads
[        KERNEL] [    0.258900] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
[        KERNEL] [    0.258900] Last level dTLB entries: 4KB 256, 2MB 16, 4MB 16, 1GB 0
[        KERNEL] [    0.258900] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[        KERNEL] [    0.258900] Spectre V2 : Spectre mitigation: kernel not compiled with retpoline; no mitigation available!
[        KERNEL] [    0.258900] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[        KERNEL] [    0.258900] Freeing SMP alternatives memory: 20K
[        KERNEL] [    0.258900] smpboot: CPU0: Intel(R) Celeron(R) CPU  J3060  @ 1.60GHz (family: 0x6, model: 0x4c, stepping: 0x4)
[        KERNEL] [    0.258900] Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, 8-deep LBR, full-width counters, Intel PMU driver.
[        KERNEL] [    0.258900] ... version:                3
[        KERNEL] [    0.258900] ... bit width:              40
[        KERNEL] [    0.258900] ... generic registers:      2
[        KERNEL] [    0.258900] ... value mask:             000000ffffffffff
[        KERNEL] [    0.258900] ... max period:             0000007fffffffff
[        KERNEL] [    0.258900] ... fixed-purpose events:   3
[        KERNEL] [    0.258900] ... event mask:             0000000700000003
[        KERNEL] [    0.258900] rcu: Hierarchical SRCU implementation.
[        KERNEL] [    0.258900] smp: Bringing up secondary CPUs ...
[        KERNEL] [    0.258900] x86: Booting SMP configuration:
[        KERNEL] [    0.258900] .... node  #0, CPUs:      #1
[        KERNEL] [    0.258900] smp: Brought up 1 node, 2 CPUs
[        KERNEL] [    0.258900] smpboot: Max logical packages: 1
[        KERNEL] [    0.258900] smpboot: Total of 2 processors activated (6400.00 BogoMIPS)
[        KERNEL] [    0.258900] devtmpfs: initialized
[        KERNEL] [    0.258900] PM: Registering ACPI NVS region [mem 0x0003f000-0x0003ffff] (4096 bytes)
[        KERNEL] [    0.258900] PM: Registering ACPI NVS region [mem 0x7a8d9000-0x7b22ffff] (9793536 bytes)
[        KERNEL] [    0.258900] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[        KERNEL] [    0.258900] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[        KERNEL] [    0.258900] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.258900] NET: Registered protocol family 16
[        KERNEL] [    0.258900] cpuidle: using governor ladder
[        KERNEL] [    0.258900] cpuidle: using governor menu
[        KERNEL] [    0.258900] ACPI: bus type PCI registered
[        KERNEL] [    0.258900] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[        KERNEL] [    0.258900] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[        KERNEL] [    0.258900] PCI: Using configuration type 1 for base access
[        KERNEL] [    0.258900] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[        KERNEL] [    0.267077] ACPI: Added _OSI(Module Device)
[        KERNEL] [    0.267080] ACPI: Added _OSI(Processor Device)
[        KERNEL] [    0.267082] ACPI: Added _OSI(3.0 _SCP Extensions)
[        KERNEL] [    0.267083] ACPI: Added _OSI(Processor Aggregator Device)
[        KERNEL] [    0.267086] ACPI: Added _OSI(Linux-Dell-Video)
[        KERNEL] [    0.267088] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[        KERNEL] [    0.267091] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[        KERNEL] [    0.283371] ACPI: 4 ACPI AML tables successfully acquired and loaded
[        KERNEL] [    0.286172] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[        KERNEL] [    0.288399] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.288412] ACPI: SSDT 0xFFFF9B7E7A919800 0005F2 (v01 PmRef  Cpu0Ist  00003000 INTL 20061109)
[        KERNEL] [    0.290174] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.290186] ACPI: SSDT 0xFFFF9B7E7B236C00 0003A5 (v01 PmRef  Cpu0Cst  00003001 INTL 20061109)
[        KERNEL] [    0.292082] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.292091] ACPI: SSDT 0xFFFF9B7E7B231400 00015F (v01 PmRef  ApIst    00003000 INTL 20061109)
[        KERNEL] [    0.293473] ACPI: Dynamic OEM Table Load:
[        KERNEL] [    0.293481] ACPI: SSDT 0xFFFF9B7E7A9A6900 00008D (v01 PmRef  ApCst    00003000 INTL 20061109)
[        KERNEL] [    0.296357] ACPI: Interpreter enabled
[        KERNEL] [    0.296401] ACPI: (supports S0 S3 S5)
[        KERNEL] [    0.296404] ACPI: Using IOAPIC for interrupt routing
[        KERNEL] [    0.296481] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[        KERNEL] [    0.297399] ACPI: Enabled 7 GPEs in block 00 to 3F
[        KERNEL] [    0.300348] ACPI: Power Resource [ID3C] (off)
[        KERNEL] [    0.302463] ACPI: Power Resource [USBC] (on)
[        KERNEL] [    0.312573] ACPI: Power Resource [CLK0] (off)
[        KERNEL] [    0.313131] ACPI: Power Resource [CLK0] (off)
[        KERNEL] [    0.313226] ACPI: Power Resource [CLK1] (off)
[        KERNEL] [    0.322478] ACPI: Power Resource [FN00] (off)
[        KERNEL] [    0.323644] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[        KERNEL] [    0.323656] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[        KERNEL] [    0.324157] acpi PNP0A08:00: _OSC: OS now controls [PME PCIeCapability LTR]
[        KERNEL] [    0.324458] PCI host bridge to bus 0000:00
[        KERNEL] [    0.324464] pci_bus 0000:00: root bus resource [io  0x0070-0x0077]
[        KERNEL] [    0.324469] pci_bus 0000:00: root bus resource [io  0x0000-0x006f window]
[        KERNEL] [    0.324473] pci_bus 0000:00: root bus resource [io  0x0078-0x0cf7 window]
[        KERNEL] [    0.324476] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[        KERNEL] [    0.324479] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[        KERNEL] [    0.324482] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[        initrd] [    0.983486] WTware 6.0.34/UEFI shell.
[        KERNEL] [    0.324485] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff window]
[        KERNEL] [    0.324489] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[        KERNEL] [    0.324492] pci_bus 0000:00: root bus resource [bus 00-ff]
[        KERNEL] [    0.324516] pci 0000:00:00.0: [8086:2280] type 00 class 0x060000
[        KERNEL] [    0.324907] pci 0000:00:02.0: [8086:22b1] type 00 class 0x030000
[        KERNEL] [    0.324934] pci 0000:00:02.0: reg 0x10: [mem 0x80000000-0x80ffffff 64bit]
[        KERNEL] [    0.324948] pci 0000:00:02.0: reg 0x18: [mem 0x90000000-0x9fffffff 64bit pref]
[        KERNEL] [    0.324957] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[        KERNEL] [    0.324988] pci 0000:00:02.0: BAR 2: assigned to efifb
[        KERNEL] [    0.325291] pci 0000:00:13.0: [8086:22a3] type 00 class 0x010601
[        KERNEL] [    0.325357] pci 0000:00:13.0: reg 0x20: [io  0xf060-0xf07f]
[        KERNEL] [    0.325370] pci 0000:00:13.0: reg 0x24: [mem 0x81315000-0x813157ff]
[        KERNEL] [    0.325437] pci 0000:00:13.0: PME# supported from D3hot
[        KERNEL] [    0.325698] pci 0000:00:14.0: [8086:22b5] type 00 class 0x0c0330
[        KERNEL] [    0.325731] pci 0000:00:14.0: reg 0x10: [mem 0x81300000-0x8130ffff 64bit]
[        KERNEL] [    0.325828] pci 0000:00:14.0: PME# supported from D3hot D3cold
[        KERNEL] [    0.326120] pci 0000:00:1a.0: [8086:2298] type 00 class 0x108000
[        KERNEL] [    0.326149] pci 0000:00:1a.0: reg 0x10: [mem 0x81100000-0x811fffff]
[        KERNEL] [    0.326161] pci 0000:00:1a.0: reg 0x14: [mem 0x81000000-0x810fffff]
[        KERNEL] [    0.326251] pci 0000:00:1a.0: PME# supported from D0 D3hot
[        KERNEL] [    0.326549] pci 0000:00:1b.0: [8086:2284] type 00 class 0x040300
[        KERNEL] [    0.326587] pci 0000:00:1b.0: reg 0x10: [mem 0x81310000-0x81313fff 64bit]
[        KERNEL] [    0.326690] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[        KERNEL] [    0.326957] pci 0000:00:1c.0: [8086:22c8] type 01 class 0x060400
[        KERNEL] [    0.327092] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[        KERNEL] [    0.327378] pci 0000:00:1c.3: [8086:22ce] type 01 class 0x060400
[        KERNEL] [    0.327508] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[        KERNEL] [    0.327816] pci 0000:00:1f.0: [8086:229c] type 00 class 0x060100
[        KERNEL] [    0.328200] pci 0000:00:1f.3: [8086:2292] type 00 class 0x0c0500
[        KERNEL] [    0.328271] pci 0000:00:1f.3: reg 0x10: [mem 0x81314000-0x8131401f]
[        KERNEL] [    0.328388] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[        KERNEL] [    0.328874] pci 0000:00:1c.0: PCI bridge to [bus 01]
[        initrd] [    0.983761] Load font 'ter-c28b.psf', console 97x27.
[        KERNEL] [    0.328983] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[        KERNEL] [    0.329026] pci 0000:02:00.0: reg 0x10: [io  0xe000-0xe0ff]
[        KERNEL] [    0.329067] pci 0000:02:00.0: reg 0x18: [mem 0x81200000-0x81200fff 64bit]
[        KERNEL] [    0.329093] pci 0000:02:00.0: reg 0x20: [mem 0xa0000000-0xa0003fff 64bit pref]
[        KERNEL] [    0.329254] pci 0000:02:00.0: supports D1 D2
[        KERNEL] [    0.329257] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[        KERNEL] [    0.329488] pci 0000:00:1c.3: PCI bridge to [bus 02]
[        KERNEL] [    0.329494] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[        KERNEL] [    0.329500] pci 0000:00:1c.3:   bridge window [mem 0x81200000-0x812fffff]
[        KERNEL] [    0.329508] pci 0000:00:1c.3:   bridge window [mem 0xa0000000-0xa00fffff 64bit pref]
[        KERNEL] [    0.329532] pci_bus 0000:00: on NUMA node 0
[        KERNEL] [    0.331763] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.331911] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332056] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332205] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332342] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332479] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332616] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.332752] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[        KERNEL] [    0.333821] iommu: Default domain type: Translated
[        KERNEL] [    0.333913] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[        KERNEL] [    0.333917] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[        KERNEL] [    0.333923] pci 0000:00:02.0: vgaarb: bridge control possible
[        KERNEL] [    0.333925] vgaarb: loaded
[        KERNEL] [    0.334001] ACPI: bus type USB registered
[        KERNEL] [    0.334041] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.334060] usbcore: registered new interface driver hub
[        KERNEL] [    0.334079] usbcore: registered new device driver usb
[        KERNEL] [    0.334144] pps_core: LinuxPPS API ver. 1 registered
[        KERNEL] [    0.334146] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[        KERNEL] [    0.334155] PTP clock support registered
[        KERNEL] [    0.334212] Registered efivars operations
[        KERNEL] [    0.334235] PCI: Using ACPI for IRQ routing
[        KERNEL] [    0.345459] PCI: pci_cache_line_size set to 64 bytes
[        KERNEL] [    0.345530] e820: reserve RAM buffer [mem 0x0003f000-0x0003ffff]
[        KERNEL] [    0.345533] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[        KERNEL] [    0.345535] e820: reserve RAM buffer [mem 0x1f000000-0x1fffffff]
[        KERNEL] [    0.345537] e820: reserve RAM buffer [mem 0x7612f018-0x77ffffff]
[        KERNEL] [    0.345540] e820: reserve RAM buffer [mem 0x795f7000-0x7bffffff]
[        KERNEL] [    0.345543] e820: reserve RAM buffer [mem 0x7a84d000-0x7bffffff]
[        KERNEL] [    0.346235] clocksource: Switched to clocksource tsc-early
[        KERNEL] [    0.346348] pnp: PnP ACPI init
[        KERNEL] [    0.346439] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[        KERNEL] [    0.346728] system 00:01: [io  0x0680-0x069f] has been reserved
[        KERNEL] [    0.346733] system 00:01: [io  0x0400-0x047f] has been reserved
[        KERNEL] [    0.346736] system 00:01: [io  0x0500-0x05fe] has been reserved
[        KERNEL] [    0.346752] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.346900] system 00:02: [io  0x0a00-0x0a1f] has been reserved
[        KERNEL] [    0.346900] system 00:02: [io  0x0a20-0x0a2f] has been reserved
[        KERNEL] [    0.346900] system 00:02: [io  0x0a30-0x0a3f] has been reserved
[        KERNEL] [    0.346900] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.346900] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.346900] system 00:04: [mem 0xe0000000-0xefffffff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfea00000-0xfeafffff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed01000-0xfed01fff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed03000-0xfed03fff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed06000-0xfed06fff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed08000-0xfed09fff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed80000-0xfedbffff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfed1c000-0xfed1cfff] has been reserved
[        KERNEL] [    0.346900] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[        KERNEL] [    0.346900] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[        KERNEL] [    0.346998] pnp: PnP ACPI: found 5 devices
[        KERNEL] [    0.351755] thermal_sys: Registered thermal governor 'step_wise'
[        KERNEL] [    0.356279] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[        KERNEL] [    0.356323] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[        KERNEL] [    0.356330] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[        KERNEL] [    0.356334] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[        KERNEL] [    0.356352] pci 0000:00:1c.0: BAR 8: assigned [mem 0x81400000-0x815fffff]
[        KERNEL] [    0.356362] pci 0000:00:1c.0: BAR 9: assigned [mem 0x81600000-0x817fffff 64bit pref]
[        KERNEL] [    0.356370] pci 0000:00:1c.0: BAR 7: assigned [io  0x1000-0x1fff]
[        KERNEL] [    0.356377] pci 0000:00:1c.0: PCI bridge to [bus 01]
[        KERNEL] [    0.356384] pci 0000:00:1c.0:   bridge window [io  0x1000-0x1fff]
[        KERNEL] [    0.356393] pci 0000:00:1c.0:   bridge window [mem 0x81400000-0x815fffff]
[        KERNEL] [    0.356399] pci 0000:00:1c.0:   bridge window [mem 0x81600000-0x817fffff 64bit pref]
[        KERNEL] [    0.356409] pci 0000:00:1c.3: PCI bridge to [bus 02]
[        KERNEL] [    0.356414] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[        KERNEL] [    0.356421] pci 0000:00:1c.3:   bridge window [mem 0x81200000-0x812fffff]
[        KERNEL] [    0.356427] pci 0000:00:1c.3:   bridge window [mem 0xa0000000-0xa00fffff 64bit pref]
[        KERNEL] [    0.356436] pci_bus 0000:00: resource 4 [io  0x0070-0x0077]
[        KERNEL] [    0.356440] pci_bus 0000:00: resource 5 [io  0x0000-0x006f window]
[        KERNEL] [    0.356443] pci_bus 0000:00: resource 6 [io  0x0078-0x0cf7 window]
[        KERNEL] [    0.356446] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[        KERNEL] [    0.356449] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[        KERNEL] [    0.356452] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[        KERNEL] [    0.356456] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000fffff window]
[        KERNEL] [    0.356459] pci_bus 0000:00: resource 11 [mem 0x80000000-0xdfffffff window]
[        KERNEL] [    0.356463] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[        KERNEL] [    0.356466] pci_bus 0000:01: resource 1 [mem 0x81400000-0x815fffff]
[        KERNEL] [    0.356469] pci_bus 0000:01: resource 2 [mem 0x81600000-0x817fffff 64bit pref]
[        KERNEL] [    0.356472] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[        KERNEL] [    0.356475] pci_bus 0000:02: resource 1 [mem 0x81200000-0x812fffff]
[        KERNEL] [    0.356478] pci_bus 0000:02: resource 2 [mem 0xa0000000-0xa00fffff 64bit pref]
[        KERNEL] [    0.356733] NET: Registered protocol family 2
[        KERNEL] [    0.356959] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[        KERNEL] [    0.356983] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[        KERNEL] [    0.357098] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[        KERNEL] [    0.357289] TCP: Hash tables configured (established 32768 bind 32768)
[        KERNEL] [    0.357375] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.357416] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[        KERNEL] [    0.357530] NET: Registered protocol family 1
[        KERNEL] [    0.357571] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[        KERNEL] [    0.358034] PCI: CLS 64 bytes, default 64
[        KERNEL] [    0.868903] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[        KERNEL] [    0.868909] software IO TLB: mapped [mem 0x7212d000-0x7612d000] (64MB)
[        KERNEL] [    0.868948] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
[        KERNEL] [    0.868975] clocksource: Switched to clocksource tsc
[        KERNEL] [    0.869188] simple-framebuffer simple-framebuffer.0: framebuffer at 0x90000000, 0x408000 bytes, mapped to 0x00000000d3a44fce
[        KERNEL] [    0.869193] simple-framebuffer simple-framebuffer.0: format=a8r8g8b8, mode=1366x768x32, linelength=5504
[        KERNEL] [    0.869379] Console: switching to colour frame buffer device 170x48
[        KERNEL] [    0.877288] simple-framebuffer simple-framebuffer.0: fb0: simplefb registered!
[        KERNEL] [    0.877796] Initialise system trusted keyrings
[        KERNEL] [    0.877977] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[        KERNEL] [    0.888974] Key type asymmetric registered
[        KERNEL] [    0.888977] Asymmetric key parser 'x509' registered
[        KERNEL] [    0.889007] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[        KERNEL] [    0.889461] pcieport 0000:00:1c.0: PME: Signaling with IRQ 115
[        KERNEL] [    0.889883] pcieport 0000:00:1c.3: PME: Signaling with IRQ 116
[        KERNEL] [    0.890038] intel_idle: MWAIT substates: 0x33000020
[        KERNEL] [    0.890040] intel_idle: v0.4.1 model 0x4C
[        KERNEL] [    0.890247] intel_idle: lapic_timer_reliable_states 0xffffffff
[        KERNEL] [    0.890412] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[        KERNEL] [    0.890512] ACPI: Power Button [PWRB]
[        KERNEL] [    0.890598] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[        KERNEL] [    0.890646] ACPI: Sleep Button [SLPB]
[        KERNEL] [    0.890732] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[        KERNEL] [    0.890805] ACPI: Power Button [PWRF]
[        KERNEL] [    0.894752] thermal LNXTHERM:00: registered as thermal_zone0
[        KERNEL] [    0.894755] ACPI: Thermal Zone [TZ01] (27 C)
[        KERNEL] [    0.895255] Linux agpgart interface v0.103
[        KERNEL] [    0.895257] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[        KERNEL] [    0.895258] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[        KERNEL] [    0.895682] zram: Added device: zram0
[        KERNEL] [    0.896062] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[        KERNEL] [    0.896064] ehci-pci: EHCI PCI platform driver
[        KERNEL] [    0.896085] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[        KERNEL] [    0.896086] ohci-pci: OHCI PCI platform driver
[        KERNEL] [    0.896104] uhci_hcd: USB Universal Host Controller Interface driver
[        KERNEL] [    0.896412] xhci_hcd 0000:00:14.0: xHCI Host Controller
[        KERNEL] [    0.896425] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[        KERNEL] [    0.897549] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081509810
[        KERNEL] [    0.897623] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[        KERNEL] [    0.897796] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[        KERNEL] [    0.897799] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    0.897804] usb usb1: Product: xHCI Host Controller
[        KERNEL] [    0.897807] usb usb1: Manufacturer: Linux 5.4.96 xhci-hcd
[        KERNEL] [    0.897809] usb usb1: SerialNumber: 0000:00:14.0
[        KERNEL] [    0.898063] hub 1-0:1.0: USB hub found
[        KERNEL] [    0.898089] hub 1-0:1.0: 7 ports detected
[        KERNEL] [    0.899148] xhci_hcd 0000:00:14.0: xHCI Host Controller
[        KERNEL] [    0.899155] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[        KERNEL] [    0.899163] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[        KERNEL] [    0.899234] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[        KERNEL] [    0.899238] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    0.899240] usb usb2: Product: xHCI Host Controller
[        KERNEL] [    0.899243] usb usb2: Manufacturer: Linux 5.4.96 xhci-hcd
[        KERNEL] [    0.899246] usb usb2: SerialNumber: 0000:00:14.0
[        KERNEL] [    0.899463] hub 2-0:1.0: USB hub found
[        KERNEL] [    0.899491] hub 2-0:1.0: 6 ports detected
[        KERNEL] [    0.900432] i8042: PNP: No PS/2 controller found.
[        KERNEL] [    0.900434] i8042: Probing ports directly.
[        KERNEL] [    0.901357] i8042: No controller found
[        KERNEL] [    0.901359] hv_vmbus: registering driver hyperv_keyboard
[        KERNEL] [    0.901456] mousedev: PS/2 mouse device common for all mice
[        KERNEL] [    0.901775] usbcore: registered new interface driver synaptics_usb
[        KERNEL] [    0.901830] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    0.901919] input: PC Speaker as /devices/platform/pcspkr/input/input3
[        KERNEL] [    0.902146] rtc_cmos 00:00: RTC can wake from S4
[        KERNEL] [    0.902512] rtc_cmos 00:00: registered as rtc0
[        KERNEL] [    0.902555] rtc_cmos 00:00: alarms up to one day, y3k, 242 bytes nvram
[        KERNEL] [    0.903028] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[        KERNEL] [    0.907655] intel_pstate: Intel P-state driver initializing
[        KERNEL] [    0.908237] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    0.908559] hv_vmbus: registering driver hid_hyperv
[        KERNEL] [    0.909094] usbcore: registered new interface driver usbhid
[        KERNEL] [    0.909099] usbhid: USB HID core driver
[        KERNEL] [    0.912573] NET: Registered protocol family 17
[        KERNEL] [    0.913162] IPI shorthand broadcast: enabled
[        KERNEL] [    0.913188] sched_clock: Marking stable (911353487, 1753850)->(921813225, -8705888)
[        KERNEL] [    0.913460] Loading compiled-in X.509 certificates
[        KERNEL] [    0.914423] rtc_cmos 00:00: setting system clock to 2021-03-10T11:23:44 UTC (1615375424)
[        KERNEL] [    0.918861] Freeing unused kernel image memory: 3116K
[        KERNEL] [    0.936863] Write protecting the kernel read-only data: 12288k
[        KERNEL] [    0.938132] Freeing unused kernel image memory: 2020K
[        KERNEL] [    0.938330] Freeing unused kernel image memory: 268K
[        KERNEL] [    0.938332] Run /init as init process
[        initrd] [    0.996810] [UEFI] Boot0001.
[        initrd] [    0.997109] 00000000:0700000001000000380055004500460049003A002000470065006E0065007200  ........8.U.E.F.I.:. .G.e.n.e.r.
[        initrd] [    0.997287] 00000020:61006C00200055004400690073006B00200035002E0030003000000002010C00  a.l. .U.D.i.s.k. .5...0.0.......
[        initrd] [    0.997325] 00000040:D041030A000000000101060000140305060002007FFF040001041800EF47642D  .A........................Gd-
[        initrd] [    0.997366] 00000060:C93BA041AC194D51D01B4CE6090400007FFF04000000424F                  .;.A.MQ.L..........BO
[        initrd] [    0.997398] [UEFI] UEFI: General UDisk 5.00.
[        initrd] [    0.997430] [UEFI] Skip type 0x02, subtype 0x01, length 12.
[        initrd] [    0.997465] [UEFI] Skip type 0x01, subtype 0x01, length 6.
[        initrd] [    0.997491] [UEFI] Looks like USB boot.
[        initrd] [    0.997516] USB boot.
[        KERNEL] [    1.235327] usb 1-2: new low-speed USB device number 2 using xhci_hcd
[        KERNEL] [    1.393113] usb 1-2: New USB device found, idVendor=04ca, idProduct=007d, bcdDevice= 1.07
[        KERNEL] [    1.393130] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    1.393141] usb 1-2: Product: USB wired keyboard
[        KERNEL] [    1.393151] usb 1-2: Manufacturer: Liteon Technology Corp.
[        KERNEL] [    1.399857] input: Liteon Technology Corp. USB wired keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:04CA:007D.0001/input/input4
[        KERNEL] [    1.460603] hid-generic 0003:04CA:007D.0001: input,hidraw0: USB HID v1.11 Keyboard [Liteon Technology Corp. USB wired keyboard] on usb-0000:00:14.0-2/input0
[        KERNEL] [    1.464415] input: Liteon Technology Corp. USB wired keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:04CA:007D.0002/input/input5
[        KERNEL] [    1.524075] input: Liteon Technology Corp. USB wired keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.1/0003:04CA:007D.0002/input/input6
[        KERNEL] [    1.524499] hid-generic 0003:04CA:007D.0002: input,hidraw1: USB HID v1.11 Device [Liteon Technology Corp. USB wired keyboard] on usb-0000:00:14.0-2/input1
[        KERNEL] [    1.651388] usb 1-3: new high-speed USB device number 3 using xhci_hcd
[        initrd] [    1.930420] Load ISO 9660 and UDF CDROM filesystem drivers.
[        initrd] [    1.930597] modprobe udf.
[        initrd] [    1.938943] modprobe isofs.
[        initrd] [    1.941019] Load VFAT filesystem driver.
[        initrd] [    1.941101] modprobe fat.
[        initrd] [    1.944112] modprobe vfat.
[        initrd] [    1.946586] Load usb storage driver.
[        initrd] [    1.946671] modprobe scsi_mod.
[        initrd] [    1.950476] modprobe usb-storage.
[        KERNEL] [    1.951921] SCSI subsystem initialized
[        initrd] [    1.953876] modprobe uas.
[        KERNEL] [    1.955315] usbcore: registered new interface driver usb-storage
[        initrd] [    1.955875] modprobe sd_mod.
[        KERNEL] [    1.957436] usbcore: registered new interface driver uas
[        KERNEL] [    7.007718] usb 1-3: device descriptor read/64, error -110
[        KERNEL] [    7.265661] usb 1-3: New USB device found, idVendor=abcd, idProduct=1234, bcdDevice= 1.00
[        KERNEL] [    7.265677] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    7.265687] usb 1-3: Product: UDisk
[        KERNEL] [    7.265696] usb 1-3: Manufacturer: General
[        KERNEL] [    7.265704] usb 1-3: SerialNumber: Љ
[        KERNEL] [    7.267974] usb-storage 1-3:1.0: USB Mass Storage device detected
[        KERNEL] [    7.269454] scsi host0: usb-storage 1-3:1.0
[        KERNEL] [    7.395370] usb 1-4: new low-speed USB device number 4 using xhci_hcd
[        KERNEL] [    7.550433] usb 1-4: New USB device found, idVendor=046d, idProduct=c05a, bcdDevice=54.00
[        KERNEL] [    7.550449] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    7.550460] usb 1-4: Product: USB Optical Mouse
[        KERNEL] [    7.550470] usb 1-4: Manufacturer: Logitech
[        KERNEL] [    7.556114] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/0003:046D:C05A.0003/input/input7
[        KERNEL] [    7.556750] hid-generic 0003:046D:C05A.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:14.0-4/input0
[        KERNEL] [    7.683287] usb 1-5: new high-speed USB device number 5 using xhci_hcd
[        KERNEL] [    7.844168] usb 1-5: New USB device found, idVendor=0bda, idProduct=0153, bcdDevice=57.13
[        KERNEL] [    7.844184] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[        KERNEL] [    7.844195] usb 1-5: Product: USB2.0-CRW
[        KERNEL] [    7.844205] usb 1-5: Manufacturer: Generic
[        KERNEL] [    7.844214] usb 1-5: SerialNumber: 20120926571200000
[        KERNEL] [    7.851430] usb-storage 1-5:1.0: USB Mass Storage device detected
[        KERNEL] [    7.852182] scsi host1: usb-storage 1-5:1.0
[        KERNEL] [    8.288896] scsi 0:0:0:0: Direct-Access     General  UDisk            5.00 PQ: 0 ANSI: 2
[        KERNEL] [    8.290602] sd 0:0:0:0: [sda] 30720000 512-byte logical blocks: (15.7 GB/14.6 GiB)
[        KERNEL] [    8.291256] sd 0:0:0:0: [sda] Write Protect is off
[        KERNEL] [    8.291269] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[        KERNEL] [    8.291729] sd 0:0:0:0: [sda] No Caching mode page found
[        KERNEL] [    8.291743] sd 0:0:0:0: [sda] Assuming drive cache: write through
[        KERNEL] [    8.345613]  sda:
[        KERNEL] [    8.348797] sd 0:0:0:0: [sda] Attached SCSI removable disk
[        initrd] [    8.462049] Success: /dev/sda mounted to /bootmedia.
| clientIP=172.16.0.53
| config=local
| setupPassword=df997d272221a81c8231ebc305de2ecc
| routerIP=172.16.0.1
| nameserverIP=172.16.0.1
[        initrd] [    8.469202] Do not cache package files.
[        initrd] [    8.469262] WTpassword present: df997d272221a81c8231ebc305de2ecc.
[        initrd] [    8.469361] Unpack /bootmedia/packages/uefi-lib.
[        KERNEL] [    8.865373] scsi 1:0:0:0: Direct-Access     Generic- SD/MMC/MS PRO    1.00 PQ: 0 ANSI: 4
[        KERNEL] [    8.870515] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[        initrd] [    9.386220] PCI: C 06:04 8086:22c8 Bridge PCI bridge Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI .
[        initrd] [    9.386395] PCI: C 06:01 8086:229c Bridge ISA bridge Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU.
[        initrd] [    9.386509] PCI: C 02 10ec:8168 Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller.
[        initrd] [    9.386616] PCI: C 01:06 8086:22a3 Mass storage controller SATA controller Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA.
[        initrd] [    9.386724] PCI: C 04:03 8086:2284 Multimedia controller Audio device Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High.
[        initrd] [    9.386830] PCI: C 06:04 8086:22ce Bridge PCI bridge Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI .
[        initrd] [    9.386936] PCI: C 0c:05 8086:2292 Serial bus controller SMBus Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Contr.
[        initrd] [    9.387043] PCI: C 06 8086:2280 Bridge Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC .
[        initrd] [    9.387147] PCI: C 10:80 8086:2298 Encryption controller Encryption controller Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trus.
[        initrd] [    9.387254] PCI: C 03 8086:22b1 Display controller Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated .
[        initrd] [    9.387362] PCI: C 0c:03 8086:22b5 Serial bus controller USB controller Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB .
[        initrd] [    9.403205] USB: 0bda:0153 Realtek Semiconductor Corp. 3-in-1 (SD/SDHC/SDXC) Card Reader.
[        initrd] [    9.403381] USB: abcd:1234 LogiLink UDisk flash drive.
[        initrd] [    9.403494] USB: 046d:c05a Logitech, Inc. M90/M100 Optical Mouse.
[        initrd] [    9.403619] USB: 04ca:007d Lite-On Technology Corp..
[        initrd] [    9.409113] Load Ethernet drivers.
[        initrd] [    9.410315] modprobe r8169.
[        initrd] [    9.434915] NIC module r8169.ko loaded.
[        KERNEL] [    9.434899] libphy: r8169: probed
[        KERNEL] [    9.435464] r8169 0000:02:00.0 eth0: RTL8168g/8111g, 98:ee:cb:56:51:9c, XID 4c0, IRQ 118
[        KERNEL] [    9.435477] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[        KERNEL] [    9.449455] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[        KERNEL] [    9.572223] r8169 0000:02:00.0 eth0: Link is Down
[        KERNEL] [   11.941668] r8169 0000:02:00.0 eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[        initrd] [   11.985673] WTpassword present: df997d272221a81c8231ebc305de2ecc.
[          pfac] [   11.987795] Run /sbin/httpd.
[        initrd] [   11.987869] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   11.987998] Ok, PID 1001.
[        initrd] [   11.988068] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   11.988531] /bootmedia/configs/config.wtc -> /tmp/config.wtc, 666 bytes copied.
[        initrd] [   11.988663] Common local disk config:
| server=172.16.0.15
| microphone=on
| smartcard=auto
| clienthostname=Boot_01
| autoshutdown=15
| language=es,default
| turnoffmenu=on, msg: Apagar:Esc - Desbloquear:Enter
| sleep=5,poweroff
| infobox=always, shutdown, reboot
| screenswitch=Win-Ctrl-N
| background=ffffff
| menu_colors=942424,a6a6a6
| keyboard=es
| graphic=ag
| disk=usb
| sound=on
1. This log is incomplete. There should be many lines in the end.
2. Also try this line:
microphone = on, hw:1:0
DaniJD
Post by DaniJD »
akatik wrote: Wed Mar 10, 2021 5:50 pm 1. This log is incomplete. There should be many lines in the end.
this was correct, this should be on the settings page
