Page 1 of 2
				Request: Language = hr (Croatian)
				Posted: Tue Nov 24, 2020 5:36 pm
				by Kic
				Hello team,
any chance to add support for Croatian (can also be used for Slovenian, Bosnian and Serbian/Latin) language?
The closest language (Keyboard) as of now is Hungarian but there is a difference in the "0" and "ΒΈ" positions an missing diacritic letters.
BR
				Re: Request: Language = hr (Croatian)
				Posted: Tue Nov 24, 2020 7:46 pm
				1. Find keyboard layout here:
http://kbdlayout.info/
2. Show me photo of terminal screen where you expect to see working keyboard.
				Posted: Wed Nov 25, 2020 12:26 pm
				by Kic
				Hi akatik,
this is the layout:
http://kbdlayout.info/kbdcr
KLID	0000041a (hr-HR)
and this is the login screen on the WTware interface:
				Posted: Fri Nov 27, 2020 5:31 pm
				Please try wtware version 6.0.26. In config:
				Posted: Mon Nov 30, 2020 12:08 pm
				by Kic
				Thank you team, hr keyboard is working properly now. BR
				Posted: Fri Dec 11, 2020 1:02 pm
				by Kic
				Hi team, we found a bug in the 6.0.26 release.
We are unable to input a capital letter N in the login screen for some reason!?
Both Shit+n or Caps Lock result in a lowercase n on the logon screen input.
				Posted: Fri Dec 11, 2020 5:17 pm
				Send me to
support@wtware.com log with such line in config:
keyboard_log = on
Press only incorrect key and save log immediately.
				Posted: Fri Dec 11, 2020 5:38 pm
				by Kic
				Sent
				Posted: Fri Dec 11, 2020 8:56 pm
				Posted: Mon Dec 14, 2020 4:45 pm
				by Kic
				Hi, this version fails to boot to RDS login screen. Log sent via mail
				Posted: Thu Dec 17, 2020 1:25 pm
				by Kic
				Update: Terminal boots when setting "sound=off" and then you can enter the letter "N"
I presume this sound error will be sorted in the final release?
Logs sent, please use your gmail address for reply
				Posted: Fri Dec 18, 2020 2:08 pm
				There is no error. Sound configuration has been changed. Not by us, but by Raspberry kernel maintainers. There is no more "mixer" keyword. "sound=on" for hdmi, "sound=on,hw:1:0" for audio jack.
http://wtware.com/docs5/sound.html
				Posted: Fri Dec 18, 2020 5:12 pm
				by Kic
				Hi, I understand but with "sound=on,hw:1:0" set on the v6.0.27 the terminal does not connect to RD Session host. It gets stuck on "Please wait..." screen. There is nothing in the terminal log when this happens. only this lines:
11-02-11-491| [HTTP] WTware v.6.0.27 found at host [], mac B8:27:EB:76:4A:20.
11-02-11-560| [HTTP] '/wtware/Everyone\list.wtc' => 'C:\ProgramData\WTware\Everyone\list.wtc'.
11-02-11-575| [HTTP] '/wtware/Terminals\B8.27.EB.76.4A.20\config.wtc' => 'C:\ProgramData\WTware\Terminals\B8.27.EB.76.4A.20\config.wtc'.
11-02-11-575| [HTTP] '/wtware/Terminals\B8.27.EB.76.4A.20\wtware.lic' => 'C:\ProgramData\WTware\Terminals\B8.27.EB.76.4A.20\wtware.lic'.
11-02-11-575| [HTTP] Failed to open file.
11-02-11-575| [HTTP] '/wtware/Everyone\all.wtc' => 'C:\ProgramData\WTware\Everyone\all.wtc'.
11-02-11-575| [HTTP] '/wtware/Everyone\wtware.lic' => 'C:\ProgramData\WTware\Everyone\wtware.lic'.
11-02-11-575| [HTTP] '/wtware/Templates\TCZ-RDS-Balanced.wtc' => 'C:\ProgramData\WTware\Templates\TCZ-RDS-Balanced.wtc'.
I sent you this log yesterday.
Reverting back to v6.0.26 with setting "sound=on,hw:1:0" the terminal boots normally.
				Posted: Sat Dec 19, 2020 3:14 pm
				There is no hardware microphone input on Raspberry. "microphone=on" can not work. But can add troubles. So, Remove. All. Lines. From. Config.
Then add what you really need.
Also, there are no "6.0.27" digits in log you sent yesterday. You sent log from 6.0.26.
				Posted: Thu Dec 24, 2020 2:14 pm
				by Kic
				New logs sent
