Request: Language = hr (Croatian)
Kic
Post by Kic »
Hello team,
any chance to add support for Croatian (can also be used for Slovenian, Bosnian and Serbian/Latin) language?
The closest language (Keyboard) as of now is Hungarian but there is a difference in the "0" and "¸" positions an missing diacritic letters.
BR
Re: Request: Language = hr (Croatian)
1. Find keyboard layout here: http://kbdlayout.info/
2. Show me photo of terminal screen where you expect to see working keyboard.
Kic
Post by Kic »
Hi akatik,
this is the layout: http://kbdlayout.info/kbdcr
KLID 0000041a (hr-HR)
and this is the login screen on the WTware interface:
Please try wtware version 6.0.26. In config:
language=hr,default
Kic
Post by Kic »
Thank you team, hr keyboard is working properly now. BR
Kic
Post by Kic »
Hi team, we found a bug in the 6.0.26 release.
We are unable to input a capital letter N in the login screen for some reason!?
Both Shit+n or Caps Lock result in a lowercase n on the logon screen input.
Send me to support@wtware.com log with such line in config:
keyboard_log = on
Press only incorrect key and save log immediately.
Kic
Post by Kic »
Sent
Kic
Post by Kic »
Hi, this version fails to boot to RDS login screen. Log sent via mail
Kic
Post by Kic »
Update: Terminal boots when setting "sound=off" and then you can enter the letter "N"
I presume this sound error will be sorted in the final release?
Logs sent, please use your gmail address for reply
There is no error. Sound configuration has been changed. Not by us, but by Raspberry kernel maintainers. There is no more "mixer" keyword. "sound=on" for hdmi, "sound=on,hw:1:0" for audio jack.
http://wtware.com/docs5/sound.html
Kic
Post by Kic »
Hi, I understand but with "sound=on,hw:1:0" set on the v6.0.27 the terminal does not connect to RD Session host. It gets stuck on "Please wait..." screen. There is nothing in the terminal log when this happens. only this lines:
11-02-11-491| [HTTP] WTware v.6.0.27 found at host [], mac B8:27:EB:76:4A:20.
11-02-11-560| [HTTP] '/wtware/Everyone\list.wtc' => 'C:\ProgramData\WTware\Everyone\list.wtc'.
11-02-11-575| [HTTP] '/wtware/Terminals\B8.27.EB.76.4A.20\config.wtc' => 'C:\ProgramData\WTware\Terminals\B8.27.EB.76.4A.20\config.wtc'.
11-02-11-575| [HTTP] '/wtware/Terminals\B8.27.EB.76.4A.20\wtware.lic' => 'C:\ProgramData\WTware\Terminals\B8.27.EB.76.4A.20\wtware.lic'.
11-02-11-575| [HTTP] Failed to open file.
11-02-11-575| [HTTP] '/wtware/Everyone\all.wtc' => 'C:\ProgramData\WTware\Everyone\all.wtc'.
11-02-11-575| [HTTP] '/wtware/Everyone\wtware.lic' => 'C:\ProgramData\WTware\Everyone\wtware.lic'.
11-02-11-575| [HTTP] '/wtware/Templates\TCZ-RDS-Balanced.wtc' => 'C:\ProgramData\WTware\Templates\TCZ-RDS-Balanced.wtc'.
I sent you this log yesterday.
Reverting back to v6.0.26 with setting "sound=on,hw:1:0" the terminal boots normally.
There is no hardware microphone input on Raspberry. "microphone=on" can not work. But can add troubles. So, Remove. All. Lines. From. Config.
Then add what you really need.
Also, there are no "6.0.27" digits in log you sent yesterday. You sent log from 6.0.26.
Kic
Post by Kic »
New logs sent
