USB WiFi Dongle causes boot loop
JPD
Post by JPD »
Good day!
I am having some problems with the WiFi in my RPi4, as it doesn't reach the router and causes errors while connecting to my remote workstation, causing a failure to connect.
I purchased this item on Amazon -https://www.amazon.com/gp/product/B00H95C0A2
WiFi for Raspberry Pi - Antenna and Instructions Included - Plug and Play by Detroit DIY Electronics
Upon inserting the USB dongle prior to boot, at first I got an error message asking me to download a firmware update (I can't remember the site now, but it was something like wtware.com/fm), I went there and got the suggested zip file (I believe it was numbered 2780), and installed via USB drive.
Now when the dongle is inserted and I try to boot, it gets past the "Press DEL to Enter Setup" and then stays on "Please Wait..." and doesn't boot. If I remove the dongle and reboot, the boot completes.
What should I do to make the dongle work?
Re: USB WiFi Dongle causes boot loop
Press Del when it writes "Press DEL to Enter Setup" and try this quest: https://wtware.com/docs5/wifi.html
When will it hung?
