6.0.16 - Wireguard
6.0.16 - Wireguard
For now Wireguard works only on x86 computers. Not on UEFI, not on Raspberry. In the next version it will work also for UEFI and Raspberry.
WTware reads configuration file from USB flash, file name must be wg.conf. Or you may write wg.conf file into configs directory using terminal web-interface.
In terminal Setup menu there's item - edit wg.conf .
Wireguard doesn't perform connection, i.e. it after terminal boot it won't wait for connection to Wireguard server.
