two monitors - main screen
eckholt
Post by eckholt »
Hello.
Some of our users are using two screens in the RDP session to a Windows 2019 terminal server. This works fine. But some of them want to change the main monitor. So the monitor on which Windows puts the icons and opens new windows. Unfortunately, in a remote session you cannot change the order of the monitors (i.e. which one is left and which one is right) and set the main screen.
So either right and left is correct (--> so the mouse moves correctly between the two monitors) and the main monitor is on the wrong side, or (--> if I change the cables or physically change monitors) the main monitor is on the right side and therefore the mouse moves on the wrong side.
Is there a way to do this in the wtware config or via registry ?
Thanks a lot
Re: two monitors - main screen
M2_position inconfiguration file will determine positions of two displays.
eckholt
Post by eckholt »
perfect. thanks. i'll try this!
