Dual touchscreen configuration
cur4r3
Post by cur4r3 »
Hi there,
we want tu use wtware on raspberrypi4 clients with two touchscreens and rdp-connection. The dual-display setup works like a charm. touchinput only works on the primary display, but the second touchscreen controlls the first display, I cant controll the second display. is there a configuration I can do to map the touch input device to the display?
Thanks a lot
Re: Dual touchscreen configuration
We have never tried two touchscreens. Send us both, and we'll try to support them together.
