Dual channel memory performance
kevin.murilo
Post by kevin.murilo »
I have my terminals set to boot via network and to keep the config in memory, so that I can ditch the HDDs. I'm only running a single 2GB DDR3 stick on each machine, since WTware requires very little space. My question is, if I put a second stick os RAM on each system, would it be more responsive? Or is the RAM only accessed when fetching the config file from the TFTP?
Re: Dual channel memory performance
kevin.murilo wrote: Thu Aug 06, 2020 5:21 pm I'm only running a single 2GB DDR3 stick on each machine, since WTware requires very little space. My question is, if I put a second stick os RAM on each system, would it be more responsive?
It will be more responsive if you run local Chromium. For RDP sessions 1GB is more than enough.
kevin.murilo
akatik wrote: Thu Aug 06, 2020 9:46 pm It will be more responsive if you run local Chromium. For RDP sessions 1GB is more than enough.
I know the space is more than enough, but what about the speed? Would the system be more responsive with 2 sticks of RAM, therefore enabling the use of Dual Channel Memory? Or would I feel no difference?
