OpenVPN windows server
robertvg
Post by robertvg »
Do I understand correctly that the wtware OpenVPN client will not connect to a OpenVPN server on Windows?
https://wtware.com/docs5/openvpn.html
The client connects to the server but then connection is lost, wtware disconnects and the server shows errors 10054
Re: OpenVPN windows server
robertvg wrote: Tue Apr 07, 2020 12:42 pm Do I understand correctly that the wtware OpenVPN client will not connect to a OpenVPN server on Windows?
No, you don't.
wtware will connect to properly configured OpenVPN server on Windows. Did you try our config example ?
http://wtware.com/docs5/openvpn.zip
robertvg
Post by robertvg »
Thanks, I will try that.
Can I also copy openvpn.cfg from a usb stick to the configs folder on a command line? Is the usb automatically mounted ?
Have some problems accessing the web-interface while connected by wifi.
robertvg wrote: Tue Apr 07, 2020 6:37 pm Is the usb automatically mounted ?
No.
It's better to boot from USB flash while testing. Because you can disconnect USB flash and write file into config folder on another computer.
robertvg
Post by robertvg »
robertvg
Post by robertvg »
aka wrote: Tue Apr 07, 2020 7:23 pm No.
Duh, I should have thought about that myself :-(
So if we include the openvpn.cfg we do not need to specify anything further or transfer the 3 client files when starting up ?
The client does not seem to pickup the openvpn settings from the cfg file in the configs directory
robertvg wrote: Wed Apr 08, 2020 2:19 pm The client does not seem to pickup the openvpn settings from the cfg file in the configs directory
https://wtware.com/logs.html
Also, show me screenshot of your "config" directory. File should be named openvpn.cfg
