remote desktop from anywhere
Yaxlei
Post by Yaxlei »
I'v installed wtware on my rpi 3b it works perfectly when connected on my home network
for a few days i try to connect from any wifi , 4g sharing, school wifi, so i change the config file to connect to my public ip , i redirect the 3389 port to my pc on my network provider page, i had the firwall rule to this port , i enabled rdp on windows etc...
when i try to connect i set server:XX.XX.XX.XX:3389 i have a tcp/ip connection lost:Network failure ? error , and i don't kow what to do
ty for your answers
Re: remote desktop from anywhere
Yaxlei
Post by Yaxlei »
i can't access log through configurator due to the connection problem so i tried to access them directly from my rpi but how can i access command line after the error ? because i can only give you the boot logs not the connection error logs
Yaxlei
Post by Yaxlei »
Heres what i got
WTware 5.8.90/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.102-v7 (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #18 SMP Mon Feb 17 08:55:24 UTC 2020
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ KERNEL] [ 0.000000] Normal zone: 1896 pages used for memmap
[ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ KERNEL] [ 0.000000] random: get_random_bytes called from 0x807009cc with crng_init=0
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240792
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:3B:C5:18 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 942060K/970752K available (5120K kernel code, 134K rwdata, 600K rodata, 5120K init, 349K bss, 20500K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (6112 kB)
[ KERNEL] [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (5120 kB)
[ KERNEL] [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 135 kB)
[ KERNEL] [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 350 kB)
[ KERNEL] [ 0.000194] Console: colour dummy device 80x30
[ KERNEL] [ 0.000208] console [tty0] enabled
[ KERNEL] [ 0.000245] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000257] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000408] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000421] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001026] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001403] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001856] Setting up static identity map for 0x100000 - 0x10003c
[ KERNEL] [ 0.001965] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002515] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.003133] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003822] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.004456] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004546] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004555] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.004559] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004563] CPU: Virtualization extensions available.
[ KERNEL] [ 0.005196] devtmpfs: initialized
[ KERNEL] [ 0.016275] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ KERNEL] [ 0.016610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.016627] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.017052] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.018067] NET: Registered protocol family 16
[ KERNEL] [ 0.020333] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.027884] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.050038] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-12-11 15:14, variant start
[ KERNEL] [ 0.060043] raspberrypi-firmware soc:firmware: Firmware hash is 44e6357b14365c3029d973dc32956fc5730dc334
[ KERNEL] [ 0.108396] bcm2835-dma 3f007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.110912] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.111016] usbcore: registered new interface driver hub
[ KERNEL] [ 0.111103] usbcore: registered new device driver usb
[ KERNEL] [ 0.112846] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.125800] NET: Registered protocol family 2
[ KERNEL] [ 0.126356] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.126387] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.126495] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.126679] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.126805] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.126850] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.127022] NET: Registered protocol family 1
[ KERNEL] [ 2.334820] Initialise system trusted keyrings
[ KERNEL] [ 2.335024] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ KERNEL] [ 2.392399] Key type asymmetric registered
[ KERNEL] [ 2.392409] Asymmetric key parser 'x509' registered
[ KERNEL] [ 2.392520] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 2.392536] io scheduler noop registered
[ KERNEL] [ 2.392773] io scheduler cfq registered (default)
[ KERNEL] [ 2.397252] bcm2708_fb soc:fb: FB found 1 display(s)
[ KERNEL] [ 2.457890] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 2.493462] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ KERNEL] [ 2.495682] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 2.496107] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 2.496904] vc-sm: Videocore shared memory driver
[ KERNEL] [ 2.497520] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ KERNEL] [ 2.498670] zram: Added device: zram0
[ KERNEL] [ 2.499700] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.499786] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.527740] dwc_otg 3f980000.usb: base=(ptrval)
[ KERNEL] [ 2.727959] Core Release: 2.80a
[ KERNEL] [ 2.727971] Setting default values for core params
[ KERNEL] [ 2.727995] Finished setting default values for core params
[ KERNEL] [ 2.928293] Using Buffer DMA mode
[ KERNEL] [ 2.928299] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 2.928303] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 2.928311] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 2.928346] Dedicated Tx FIFOs mode
[ KERNEL] [ 2.928925] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = bad04000 dma = 0xfad04000 len=9024
[ KERNEL] [ 2.928951] FIQ FSM acceleration enabled for :
[ KERNEL] [ 2.928951] Non-periodic Split Transactions
[ KERNEL] [ 2.928951] Periodic Split Transactions
[ KERNEL] [ 2.928951] High-Speed Isochronous Endpoints
[ KERNEL] [ 2.928951] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 2.928958] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 2.929008] WARN::hcd_init_fiq:457: FIQ on core 1
[ KERNEL] [ 2.929016] WARN::hcd_init_fiq:458: FIQ ASM at 803b2300 length 36
[ KERNEL] [ 2.929026] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ KERNEL] [ 2.929046] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 2.929080] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.929112] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ KERNEL] [ 2.929160] Init: Port Power? op_state=1
[ KERNEL] [ 2.929165] Init: Power Port (0)
[ KERNEL] [ 2.929357] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.929367] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.929374] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 2.929381] usb usb1: Manufacturer: Linux 4.19.102-v7 dwc_otg_hcd
[ KERNEL] [ 2.929389] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 2.930029] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.930067] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.930780] dwc_otg: FIQ enabled
[ KERNEL] [ 2.930792] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.930796] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.930813] Module dwc_common_port init
[ KERNEL] [ 2.931192] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.932263] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.932558] bcm2835-cpufreq: min=600000 max=1200000
[ KERNEL] [ 2.933406] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.933414] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.934013] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.934637] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ KERNEL] [ 2.934779] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.934870] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.935493] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.935498] usbhid: USB HID core driver
[ KERNEL] [ 2.936313] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.941606] [vc_sm_connected_init]: start
[ KERNEL] [ 2.953177] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.954075] NET: Registered protocol family 17
[ KERNEL] [ 2.954273] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.954661] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.957523] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.957532] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.983564] sdhost: log_buf @ (ptrval) (fad07000)
[ KERNEL] [ 3.018996] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 3.020528] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.022053] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 3.025124] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 3.030643] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 3.030793] of_cfs_init
[ KERNEL] [ 3.030941] of_cfs_init: OK
[ KERNEL] [ 3.054874] Freeing unused kernel memory: 5120K
[ KERNEL] [ 3.109853] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 3.111635] mmc0: Problem switching card into high-speed mode!
[ KERNEL] [ 3.112520] mmc0: new SDHC card at address 0001
[ KERNEL] [ 3.113418] mmcblk0: mmc0:0001 00000 14.9 GiB
[ KERNEL] [ 3.115874] mmcblk0: p1
[ KERNEL] [ 3.120640] random: fast init done
[ KERNEL] [ 3.150033] Run /init as init process
[ KERNEL] [ 3.176058] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 3.182984] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 3.402895] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 3.403066] Indeed it is in host mode hprt0 = 00001101
[ hotplug] [ 3.412269] Block device 254:0. No action.
[ hotplug] [ 3.417593] Block device 179:0. No action.
[ hotplug] [ 3.417987] Block device 179:1. No action.
[ pfac] [ 3.476179] Run /sbin/initrd.
[ pfac] [ 3.476375] Ok, PID 651.
[ initrd] [ 3.481219] WTware 5.8.90/RPi shell.
[ initrd] [ 3.481627] Load font 'ter-c32b.psf', console 120x33.
[ initrd] [ 3.525044] HDD/MMC/SD boot.
[ initrd] [ 3.525172] No device '/dev/fb1'.
[ KERNEL] [ 3.653127] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ KERNEL] [ 3.653141] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 3.653805] hub 1-1:1.0: USB hub found
[ KERNEL] [ 3.653906] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 3.972884] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 4.103089] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ KERNEL] [ 4.103099] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.402882] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ KERNEL] [ 4.544792] usb 1-1.2: New USB device found, idVendor=1bcf, idProduct=0007, bcdDevice= 0.10
[ KERNEL] [ 4.544802] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ KERNEL] [ 4.544810] usb 1-1.2: Product: USB Optical Mouse
[ KERNEL] [ 4.560130] input: USB Optical Mouse Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1BCF:0007.0001/input/input0
[ KERNEL] [ 4.560651] input: USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1BCF:0007.0001/input/input1
[ KERNEL] [ 4.561433] hid-generic 0003:1BCF:0007.0001: input,hiddev96,hidraw0: USB HID v1.10 Mouse [USB Optical Mouse] on usb-3f980000.usb-1.2/input0
[ KERNEL] [ 4.672875] usb 1-1.3: new full-speed USB device number 5 using dwc_otg
[ KERNEL] [ 4.814541] usb 1-1.3: New USB device found, idVendor=1ea7, idProduct=2002, bcdDevice= 1.03
[ KERNEL] [ 4.814552] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.814559] usb 1-1.3: Product: Gaming Keyboard
[ KERNEL] [ 4.814567] usb 1-1.3: Manufacturer: WFDZ
[ KERNEL] [ 4.821168] input: WFDZ Gaming Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1EA7:2002.0002/input/input2
[ KERNEL] [ 4.883807] hid-generic 0003:1EA7:2002.0002: input,hidraw1: USB HID v1.10 Keyboard [WFDZ Gaming Keyboard] on usb-3f980000.usb-1.3/input0
[ KERNEL] [ 4.913299] input: WFDZ Gaming Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input3
[ KERNEL] [ 4.913816] input: WFDZ Gaming Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input4
[ KERNEL] [ 4.983321] input: WFDZ Gaming Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:1EA7:2002.0003/input/input5
[ KERNEL] [ 4.983965] hid-generic 0003:1EA7:2002.0003: input,hiddev97,hidraw2: USB HID v1.10 Mouse [WFDZ Gaming Keyboard] on usb-3f980000.usb-1.3/input1
[ KERNEL] [ 5.092876] usb 1-1.4: new high-speed USB device number 6 using dwc_otg
[ KERNEL] [ 5.224163] usb 1-1.4: New USB device found, idVendor=1609, idProduct=3a04, bcdDevice= 0.00
[ KERNEL] [ 5.224173] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 5.224181] usb 1-1.4: Product: USB Disk
[ KERNEL] [ 5.224189] usb 1-1.4: Manufacturer: Flash
[ KERNEL] [ 5.224197] usb 1-1.4: SerialNumber: 37271106B481573912681
[ initrd] [ 5.684929] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
[ initrd] [ 5.756429] Do not cache package files.
[ initrd] [ 5.756942] WTpassword empty.
[ initrd] [ 5.823830] USB: 1ea7:2002 SHARKOON Technologies GmbH.
[ initrd] [ 5.823967] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 5.824031] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 5.824088] USB: 1609:3a04 .
[ initrd] [ 5.824159] USB: 1bcf:0007 Sunplus Innovation Technology Inc. Optical Mouse.
[ initrd] [ 5.879411] Start Setup.
[ KERNEL] [ 7.275564] random: crng init done
[ KERNEL] [ 363.612284] SCSI subsystem initialized
[ KERNEL] [ 363.624479] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ KERNEL] [ 363.624836] scsi host0: usb-storage 1-1.4:1.0
[ KERNEL] [ 363.625471] usbcore: registered new interface driver usb-storage
[ KERNEL] [ 364.633623] scsi 0:0:0:0: Direct-Access Flash USB Disk 6.80 PQ: 0 ANSI: 2
[ KERNEL] [ 364.635239] sd 0:0:0:0: [sda] 7864320 512-byte logical blocks: (4.03 GB/3.75 GiB)
[ KERNEL] [ 364.635569] sd 0:0:0:0: [sda] Write Protect is off
[ KERNEL] [ 364.635585] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
[ KERNEL] [ 364.635837] sd 0:0:0:0: [sda] No Caching mode page found
[ KERNEL] [ 364.635847] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ KERNEL] [ 364.639002] sda: sda1
[ KERNEL] [ 364.641158] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ KERNEL] [ 368.746028] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
It's small part of log. Not the full log.
Yaxlei
Post by Yaxlei »
Yaxlei wrote: Sat Mar 28, 2020 6:04 pm i can't access log through configurator due to the connection problem so i tried to access them directly from my rpi but how can i access command line after the error ? because i can only give you the boot logs not the connection error logs
Command line needed when there is no network. When terminal connected to network, you can read log in web browser from another computer in the same network as Pi.
Yaxlei
Post by Yaxlei »
I know where the error comes from, my ip is dynamic this is why i couldn't connect :/ here's another question is it possible to connect through a dns like no-ip ?
The server must have static IP. Client can use dynamic IP. We have never tried a dns like no-ip, but I see no problems with this.
