Re: Change the font color?
Posted: Sat Feb 22, 2020 12:53 pm
Please try this:
http://wtware.com/testing/202002220938.zip
In config:
menu_colors=00ff00,ff0000
Posted: Mon Feb 24, 2020 12:14 pm
Sorry, I didn't test configurator :(
Write value in "Text" tab. It will display errors, but save config.
Posted: Mon Feb 24, 2020 2:58 pm
Posted: Mon Mar 16, 2020 6:43 pm
by nicktheclick
Hello
I'm using WTware 5.8.90/RPi on a RB PI 4.
Everything is working fine (openVPN, RDP, etoken) but as I'm "fine tuning" the installation I'm having problems with this parameter.
I'm configuring the RBPI straight from the configuration menu on the device.
Any suggestion ?
Nick
Posted: Mon Mar 16, 2020 7:17 pm
nicktheclick wrote: Mon Mar 16, 2020 6:43 pm I'm using WTware 5.8.90...having problems with this parameter.
Because it's in 5.8.91. Use the link above or today's build: http://wtware.com/testing/202003161523.zip
Posted: Tue Mar 17, 2020 10:44 am
by nicktheclick
Thanks a lot. I'll try it ASAP.
Ciao !
Nick
Posted: Fri Mar 20, 2020 3:17 pm
by nicktheclick
Works just perfect !!!
Thanks !!
