License problems LAN or Wlan
Licensing terms. Copyrights. WTware and GPL.
Re: License problems LAN or Wlan
http://wtware.com/licensing/terms.html
"License is bound to computer network card MAC-address (Ethernet or WiFi MAC-address of the card, that connects terminal to network)."
You need two licenses.
When you find onboard WiFi is too weak and start using external USB WiFi with antenna, it requires third license for same device...
Concurrent licenses may help, but it takes up to a week to release unused MAC after last usage.
Two similar MACs can not live in the same network.
Two similar CPU IDs can.
quocnam
Post by quocnam »
Me too,
i''m using Raspberry PI4 with connnect to WLAN
but ,now i want to change to connect to LAN
I have Problem about active liences follow address MAC
how to active again when i using connect to Lan
i hope Support Team Wtware can help me
thanks so much
Write mail to license@wtware.com
quocnam
Post by quocnam »
akatik wrote: Wed Apr 14, 2021 12:39 pm Write mail to license@wtware.com
i had send mail for support teams
thanks so much
