Logon failes when there already is a disconnected Session
jonathan
Post by jonathan »
Hello, everybody,
We are currently testing WTware with a Raspberry Pi 4B and a Windows Server 2019 Session Broker and two 2019 Session Hosts.
All in all I am absolutely thrilled with the solution. There is only one problem that still prevents us from using WTware Productive:
As soon as a user already has a (disconnected) session, the RDP connection can no longer be established. The message "Logon failed. Wrong username or password" appears, although the login data is entered correctly. When i close the disconnected manually via the Server Manager, I can log on to the ThinClient again.
On the Windows RDP Client this behavior could not be reproduced, so I could not detect a basic server side problem.
I would be very grateful for suggestions for solutions
jonathan
Re: Logon failes when there already is a disconnected Session
Post by jonathan »
WTware v.5.8.88/RPi
WTware 5.8.88/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.86-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #6 SMP Mon Dec 9 16:57:48 UTC 2019
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ KERNEL] [ 0.000000] cma: Reserved 64 MiB at 0x0000000037400000
[ KERNEL] [ 0.000000] On node 0 totalpages: 1012736
[ KERNEL] [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a009e0 with crng_init=0
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011200
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:41:EA:20 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 3937688K/4050944K available (6144K kernel code, 148K rwdata, 664K rodata, 6144K init, 372K bss, 47720K reserved, 65536K cma-reserved, 3198976K highmem)
[ KERNEL] [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ KERNEL] [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ KERNEL] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ KERNEL] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ KERNEL] [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (8160 kB)
[ KERNEL] [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (6144 kB)
[ KERNEL] [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 149 kB)
[ KERNEL] [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 373 kB)
[ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ KERNEL] [ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 18ns
[ KERNEL] [ 0.000194] Console: colour dummy device 80x30
[ KERNEL] [ 0.000211] console [tty0] enabled
[ KERNEL] [ 0.000244] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ KERNEL] [ 0.000260] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000383] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000399] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000894] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001205] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001599] Setting up static identity map for 0x200000 - 0x20003c
[ KERNEL] [ 0.001696] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002201] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.002792] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003460] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.004102] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004190] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004200] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ KERNEL] [ 0.004207] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004212] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004676] devtmpfs: initialized
[ KERNEL] [ 0.012898] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ KERNEL] [ 0.013192] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.013208] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.014730] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.015663] NET: Registered protocol family 16
[ KERNEL] [ 0.017783] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.021670] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.057687] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.059443] vgaarb: loaded
[ KERNEL] [ 0.059685] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.059735] usbcore: registered new interface driver hub
[ KERNEL] [ 0.059799] usbcore: registered new device driver usb
[ KERNEL] [ 0.073620] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-12-05 14:41, variant start
[ KERNEL] [ 0.083552] raspberrypi-firmware soc:firmware: Firmware hash is dfab159feffeba8de79ecb6dc973fab33d07004f
[ KERNEL] [ 0.094762] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.102354] NET: Registered protocol family 2
[ KERNEL] [ 0.102802] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.102819] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.102872] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.102936] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.103052] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103079] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.103210] NET: Registered protocol family 1
[ KERNEL] [ 0.103236] PCI: CLS 0 bytes, default 64
[ KERNEL] [ 1.812586] Initialise system trusted keyrings
[ KERNEL] [ 1.812774] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[ KERNEL] [ 1.852194] Key type asymmetric registered
[ KERNEL] [ 1.852207] Asymmetric key parser 'x509' registered
[ KERNEL] [ 1.852301] bounce: pool size: 64 pages
[ KERNEL] [ 1.852377] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 1.852392] io scheduler noop registered
[ KERNEL] [ 1.852569] io scheduler cfq registered (default)
[ KERNEL] [ 1.920531] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ KERNEL] [ 1.920550] brcm-pcie fd500000.pcie: could not get clock
[ KERNEL] [ 1.920598] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ KERNEL] [ 1.920625] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ KERNEL] [ 1.974681] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ KERNEL] [ 1.974907] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ KERNEL] [ 1.974921] pci_bus 0000:00: root bus resource [bus 00-01]
[ KERNEL] [ 1.974934] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ KERNEL] [ 1.974970] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ KERNEL] [ 1.975060] pci 0000:00:00.0: PME# supported from D0 D3hot
[ KERNEL] [ 1.977961] PCI: bus0: Fast back to back transfers disabled
[ KERNEL] [ 1.977980] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ KERNEL] [ 1.978186] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ KERNEL] [ 1.978296] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ KERNEL] [ 1.978567] pci 0000:01:00.0: PME# supported from D0 D3cold
[ KERNEL] [ 1.981493] PCI: bus1: Fast back to back transfers disabled
[ KERNEL] [ 1.981508] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ KERNEL] [ 1.981546] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.981562] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ KERNEL] [ 1.981623] pci 0000:00:00.0: PCI bridge to [bus 01]
[ KERNEL] [ 1.981635] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.981800] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.981959] pcieport 0000:00:00.0: Signaling PME with IRQ 51
[ KERNEL] [ 1.982100] pcieport 0000:00:00.0: AER enabled with IRQ 51
[ KERNEL] [ 1.982256] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.982739] bcm2708_fb soc:fb: FB found 1 display(s)
[ KERNEL] [ 2.027738] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 2.038686] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ KERNEL] [ 2.040583] iproc-rng200 fe104000.rng: hwrng registered
[ KERNEL] [ 2.040786] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 2.041382] vc-sm: Videocore shared memory driver
[ KERNEL] [ 2.041873] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ KERNEL] [ 2.042855] zram: Added device: zram0
[ KERNEL] [ 2.045233] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.045595] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.045644] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.101725] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ KERNEL] [ 2.102139] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 52
[ KERNEL] [ 2.102504] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.102533] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.102548] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 2.102566] usb usb1: Manufacturer: Linux 4.19.86-v7l xhci-hcd
[ KERNEL] [ 2.102586] usb usb1: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.104108] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.104180] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.104923] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.104951] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 2.104972] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ KERNEL] [ 2.105300] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ KERNEL] [ 2.105312] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.105322] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 2.105330] usb usb2: Manufacturer: Linux 4.19.86-v7l xhci-hcd
[ KERNEL] [ 2.105339] usb usb2: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.106013] hub 2-0:1.0: USB hub found
[ KERNEL] [ 2.106125] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 2.107710] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.107944] dwc_otg: FIQ enabled
[ KERNEL] [ 2.107953] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.107963] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.108058] Module dwc_common_port init
[ KERNEL] [ 2.114080] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.115189] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.115471] bcm2835-cpufreq: min=600000 max=1500000
[ KERNEL] [ 2.116159] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.116165] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.116544] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.116836] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.117800] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.118855] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.118865] usbhid: USB HID core driver
[ KERNEL] [ 2.119902] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.130597] [vc_sm_connected_init]: start
[ KERNEL] [ 2.138610] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.139100] NET: Registered protocol family 17
[ KERNEL] [ 2.139188] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.139425] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.142163] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ KERNEL] [ 2.143194] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ KERNEL] [ 2.143528] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.143532] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.168108] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ KERNEL] [ 2.185311] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 2.186847] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.188383] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.191129] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 2.192658] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.198865] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ KERNEL] [ 2.199075] of_cfs_init
[ KERNEL] [ 2.199151] of_cfs_init: OK
[ KERNEL] [ 2.224117] Freeing unused kernel memory: 6144K
[ KERNEL] [ 2.262217] random: fast init done
[ KERNEL] [ 2.273956] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 2.311408] Run /init as init process
[ KERNEL] [ 2.336332] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ KERNEL] [ 2.336688] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ KERNEL] [ 2.338574] mmcblk0: p1
[ hotplug] [ 2.335538] Block device 179:0. No action.
[ hotplug] [ 2.335707] Block device 179:1. No action.
[ hotplug] [ 2.394477] Block device 254:0. No action.
[ KERNEL] [ 2.474708] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ pfac] [ 2.619027] Run /sbin/initrd.
[ pfac] [ 2.619309] Ok, PID 745.
[ initrd] [ 2.624700] WTware 5.8.88/RPi shell.
[ initrd] [ 2.625069] Load font 'ter-c32b.psf', console 120x33.
[ initrd] [ 2.644241] HDD/MMC/SD boot.
[ initrd] [ 2.644396] No device '/dev/fb1'.
[ KERNEL] [ 2.667322] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ KERNEL] [ 2.667327] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 2.667331] usb 1-1: Product: USB2.0 Hub
[ KERNEL] [ 2.668629] hub 1-1:1.0: USB hub found
[ KERNEL] [ 2.668939] hub 1-1:1.0: 4 ports detected
[ KERNEL] [ 2.994684] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 3.133409] usb 1-1.3: New USB device found, idVendor=045e, idProduct=07fd, bcdDevice= 3.15
[ KERNEL] [ 3.133422] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.133432] usb 1-1.3: Product: Microsoft Nano Transceiver 1.1
[ KERNEL] [ 3.133441] usb 1-1.3: Manufacturer: Microsoft
[ KERNEL] [ 3.144412] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:045E:07FD.0001/input/input0
[ KERNEL] [ 3.205393] hid-generic 0003:045E:07FD.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.3/input0
[ KERNEL] [ 3.213117] input: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:045E:07FD.0002/input/input1
[ KERNEL] [ 3.275048] input: Microsoft Microsoft Nano Transceiver 1.1 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:045E:07FD.0002/input/input2
[ KERNEL] [ 3.275332] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:045E:07FD.0002/input/input3
[ KERNEL] [ 3.275935] hid-generic 0003:045E:07FD.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.3/input1
[ KERNEL] [ 3.281731] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:045E:07FD.0003/input/input4
[ KERNEL] [ 3.282160] hid-generic 0003:045E:07FD.0003: input,hidraw2: USB HID v1.11 Mouse [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.3/input2
[ KERNEL] [ 3.384688] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ initrd] [ 3.402269] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
[ initrd] [ 3.419406] Do not cache package files.
[ initrd] [ 3.419506] WTpassword present: 01ad7dc359caccf3c8de80cb1b9f05a4.
[ initrd] [ 3.462006] USB: 045e:07fd Microsoft Corp. Nano Transceiver 1.1.
[ initrd] [ 3.462063] USB: 2109:3431 VIA Labs, Inc. Hub.
[ KERNEL] [ 3.534099] usb 1-1.4: New USB device found, idVendor=04b3, idProduct=3025, bcdDevice= 1.09
[ KERNEL] [ 3.534112] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.534123] usb 1-1.4: Product: USB NetVista Full Width Keyboard.
[ KERNEL] [ 3.534133] usb 1-1.4: Manufacturer: LITE-ON Technology
[ KERNEL] [ 3.547484] input: LITE-ON Technology USB NetVista Full Width Keyboard. as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:04B3:3025.0004/input/input5
[ KERNEL] [ 3.615392] hid-generic 0003:04B3:3025.0004: input,hidraw3: USB HID v1.10 Keyboard [LITE-ON Technology USB NetVista Full Width Keyboard.] on usb-0000:01:00.0-1.4/input0
| clientIP=*
| config=local
| setupPassword=01ad7dc359caccf3c8de80cb1b9f05a4
| netmedia=ethernet
[ initrd] [ 5.355446] Load Ethernet drivers.
[ initrd] [ 5.355544] modprobe genet.
[ KERNEL] [ 5.368168] bcmgenet fd580000.genet: failed to get enet clock
[ KERNEL] [ 5.368184] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ KERNEL] [ 5.368198] bcmgenet fd580000.genet: failed to get enet-wol clock
[ KERNEL] [ 5.368210] bcmgenet fd580000.genet: failed to get enet-eee clock
[ KERNEL] [ 5.368229] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 5.368464] unimac-mdio unimac-mdio.-19: DMA mask not set
[ KERNEL] [ 5.384655] libphy: bcmgenet MII bus: probed
[ KERNEL] [ 5.437876] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ KERNEL] [ 5.439944] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 5.535031] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ KERNEL] [ 6.564781] bcmgenet fd580000.genet eth0: Link is Down
[ KERNEL] [ 10.724821] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ initrd] [ 10.739207] WTpassword present: 01ad7dc359caccf3c8de80cb1b9f05a4.
[ initrd] [ 11.775804] dhcp: 328 bytes from 192.168.42.1.
[ initrd] [ 11.775907] 00000000:000001340000000000110000C0A80E01C0A80E62004300440134000002010600 ...4..............b.C.D.4......
[ initrd] [ 11.775996] 00000020:67458B6B0000000000000000C0A80E620000000000000000DCA63241EA200000 gE.k...........b..........2A. ..
[ initrd] [ 11.776083] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776169] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776254] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776339] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776443] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776529] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.776614] 00000100:0000000000000000638253633501023604C0A80E01330400012E940104FFFFFF ........c.Sc5..6.....3..........
[ initrd] [ 11.776700] 00000120:000304C0A80E010608C0A80E01C0A80E020F076A6F792E6C616EFF0000000000 ...................xxx.lan......
[ initrd] [ 11.776785] 00000140:0000000000000000 ........
[ initrd] [ 12.950171] dhcp: 328 bytes from 192.168.42.1.
[ initrd] [ 12.950263] 00000000:000001340000000000110000C0A80E01C0A80E62004300440134000002010600 ...4..............b.C.D.4......
[ initrd] [ 12.950350] 00000020:67458B6B0000000000000000C0A80E620000000000000000DCA63241EA200000 gE.k...........b..........2A. ..
[ initrd] [ 12.950435] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950520] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950605] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950690] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950775] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950860] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 12.950945] 00000100:0000000000000000638253633501053604C0A80E01330400012E920104FFFFFF ........c.Sc5..6.....3..........
[ initrd] [ 12.951031] 00000120:000304C0A80E010608C0A80E01C0A80E020F076A6F792E6C616EFF0000000000 ...................xxx.lan......
[ initrd] [ 12.951116] 00000140:0000000000000000 ........
[ initrd] [ 13.000096] [DHCP] DHCP server address 192.168.42.1.
[ initrd] [ 13.000189] [DHCP] IP 192.168.42.98 mask 255.255.255.0.
[ initrd] [ 13.000276] [DHCP] Default gateway 192.168.42.1.
[ initrd] [ 13.000360] [DHCP] DNS 192.168.42.1.
[ initrd] [ 13.000444] [DHCP] DNS 192.168.42.2.
[ initrd] [ 13.000529] [DHCP] Domain xxx.lan.
[ initrd] [ 13.000613] [DHCP] TFTP = DHCP 192.168.42.1.
[ initrd] [ 13.000696] [DHCP] TFTP 192.168.42.1.
[ initrd] [ 13.000779] [DHCP] No boot file from DHCP.
[ initrd] [ 13.000862] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
[ pfac] [ 13.002180] Run /sbin/httpd.
[ initrd] [ 13.002258] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 13.002376] Ok, PID 821.
[ initrd] [ 13.002426] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 13.003746] /bootmedia/configs/config.wtc -> /tmp/config.wtc, 132 bytes copied.
[ initrd] [ 13.003848] Common local disk config:
| server=rds.xxx-xxxxxx.de
| ask_password=nopin
| domain=xxx
| ask_password=nopin
| domain=xxx
[ initrd] [ 13.005024] Hostname: "wtwDCA63241EA20".
[ httpd] [ 13.010875] Internal HTTP Server, WTware 5.8.88/RPi
[ initrd] [ 13.280274] [NTP] 42 DHCP option is not set.
[ httpd] [ 13.285101] Reread settings.
[ initrd] [ 13.285220] Unpack /bootmedia/packages/pi2-f.
[ httpd] [ 13.285323] Everyone can control terminal by HTTP.
[ KERNEL] [ 13.403423] random: crng init done
[ gm] [ 13.401424] WTware 5.8.88/RPi session manager.
[ gm] [ 13.401889] Add keyboard event5: LITE-ON Technology USB NetVista Full Width Keyboard..
[ gm] [ 13.470171] EV_REL flag found. Add mouse event4: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.470278] Add keyboard event3: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.470369] Add keyboard event2: Microsoft Microsoft Nano Transceiver 1.1 System Control.
[ gm] [ 13.470461] Add keyboard event1: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control.
[ gm] [ 13.470557] Add keyboard event0: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.470665] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 13.767274] Framebuffer device found.
[ gm] [ 13.767319] LINELENBYTES 7680
[ gm] [ 13.767355] VLEN 8294400
[ gm] [ 13.768427] Use /lib/ui32.so.
[ gm] [ 13.851052] Run '/sbin/resolver 0x2164da8 dns [rds.xxx-xxxxxx.de]', log '', env '', pid ''.
[ pfac] [ 13.851193] Run /sbin/resolver 0x2164da8 dns [rds.xxx-xxxxxx.de].
[ gm] [ 13.851244] Nobody can control terminal by VNC.
[ pfac] [ 13.851525] Ok, PID 823.
[ gm] [ 13.859399] rds.xxx-xxxxxx.de => 192.168.33.15.
[ pfac] [ 13.859884] Process pid 823 terminated, status 00000000.
[ KERNEL] [ 14.714684] usb 1-1.1: new high-speed USB device number 5 using xhci_hcd
[ KERNEL] [ 14.851837] usb 1-1.1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 1.05
[ KERNEL] [ 14.851851] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 14.851861] usb 1-1.1: SerialNumber: 23A516A7
[ gm] [ 26.482784] Free ram before fork terminal client /sbin/rdpclient (session 1): 3942004 Kb.
[ pfac] [ 26.482951] Run /sbin/rdpclient 1.
[ gm] [ 26.483004] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 26.483225] Ok, PID 831.
[ rdpclient 831] [ 26.495456] RDP Terminal Client, WTware 5.8.88/RPi, pipe 1, pid 831.
[ rdpclient 831] [ 26.499846] Use /lib/ui32.so.
[ rdpclient 831] [ 26.500767] Make RDP session with 192.168.33.15, port 3389.
[ rdpclient 831] [ 26.500847] Username: "myusername".
[ rdpclient 831] [ 26.500889] Password: present.
[ rdpclient 831] [ 26.500929] No PIN.
[ rdpclient 831] [ 26.500967] Domain: "xxx".
[ rdpclient 831] [ 26.501005] No shell.
[ rdpclient 831] [ 26.501042] No directory.
[ rdpclient 831] [ 26.501080] Window: 1856x1080@24.
[ rdpclient 831] [ 26.501119] PFlags 0x0000002F.
[ rdpclient 831] [ 26.501157] Keyboard 00000409:00000000.
[ rdpclient 831] [ 26.501195] My hostname "wtwDCA63241EA20".
[ rdpclient 831] [ 26.501233] TCP: connecting to 192.168.33.15:3389.
[ rdpclient 831] [ 26.505289] TCP: connection with 192.168.33.15:3389 established.
[ rdpclient 831] [ 26.505350] Turn keepalive on.
[ rdpclient 831] [ 26.505822] Free ram after buffers allocation: 3941492 KB.
[ rdpclient 831] [ 26.522481] Reconnect with TLS/SSL enabled.
[ rdpclient 831] [ 26.522600] TCP: reconnecting to 192.168.33.15:3389.
[ rdpclient 831] [ 26.526679] TCP: connection with 192.168.33.15:3389 established.
[ rdpclient 831] [ 26.526779] Turn keepalive on.
[ rdpclient 831] [ 26.550355] Server supports GFX Pipeline.
[ rdpclient 831] [ 26.550484] TLS.
[ rdpclient 831] [ 26.550610] SSL/TLS.
[ rdpclient 831] [ 26.644729] Enable font smoothing and Desktop Composition.
[ rdpclient 831] [ 26.838690] GFX codec.
[ rdpclient 831] [ 27.790149] Run 4 tile threads.
[ rdpclient 831] [ 28.675038] TS_STATUS_FINDING_DESTINATION
[ gm] [ 28.675173] Do not display state after connection.
[ rdpclient 831] [ 28.681236] TS_STATUS_LOADING_DESTINATION
[ rdpclient 831] [ 28.684927] TS_STATUS_REDIRECTING_TO_DESTINATION
[ rdpclient 831] [ 28.718630] TS_STATUS_BRINGING_SESSION_ONLINE
[ rdpclient 831] [ 28.726761] TS_STATUS_VM_LOADING
[ rdpclient 831] [ 28.833358] Server Redirection flags 0x00000b1d.
[ rdpclient 831] [ 28.833490] Server 192.168.33.16.
[ rdpclient 831] [ 28.833588] User "myusername".
[ rdpclient 831] [ 28.833683] Domain "xxx".
[ rdpclient 831] [ 28.833779] Password present.
[ rdpclient 831] [ 28.833874] Send Disconnect Provider Ultimatum.
[ gm] [ 28.847738] TSClient (sessionId 1, pid 831) gracefully end.
[ pfac] [ 28.848903] Run /sbin/rdpclient 2.
[ gm] [ 28.848972] Free ram before fork terminal client /sbin/rdpclient (session 2): 3919628 Kb.
[ pfac] [ 28.849073] Ok, PID 838.
[ gm] [ 28.849117] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 28.854269] Process pid 831 terminated, status 00000009.
[ rdpclient 838] [ 28.856708] RDP Terminal Client, WTware 5.8.88/RPi, pipe 2, pid 838.
[ rdpclient 838] [ 28.857019] Use /lib/ui32.so.
[ rdpclient 838] [ 28.857419] Make RDP session with 192.168.33.16, port 3389.
[ rdpclient 838] [ 28.857468] Username: "myusername".
[ rdpclient 838] [ 28.857509] Password: present.
[ rdpclient 838] [ 28.857547] No PIN.
[ rdpclient 838] [ 28.857585] Domain: "xxx".
[ rdpclient 838] [ 28.857623] No shell.
[ rdpclient 838] [ 28.857661] No directory.
[ rdpclient 838] [ 28.857699] Window: 1856x1080@24.
[ rdpclient 838] [ 28.857737] PFlags 0x0000002F.
[ rdpclient 838] [ 28.857775] Keyboard 00000409:00000000.
[ rdpclient 838] [ 28.857813] My hostname "wtwDCA63241EA20".
[ rdpclient 838] [ 28.857850] TCP: connecting to 192.168.33.16:3389.
[ rdpclient 838] [ 28.861484] TCP: connection with 192.168.33.16:3389 established.
[ rdpclient 838] [ 28.861527] Turn keepalive on.
[ rdpclient 838] [ 28.862017] Free ram after buffers allocation: 3939740 KB.
[ rdpclient 838] [ 28.862066] Empty Balance Info.
[ rdpclient 838] [ 28.877679] Reconnect with NLA enabled.
[ rdpclient 838] [ 28.877721] TCP: reconnecting to 192.168.33.16:3389.
[ rdpclient 838] [ 28.881528] TCP: connection with 192.168.33.16:3389 established.
[ rdpclient 838] [ 28.881643] Turn keepalive on.
[ rdpclient 838] [ 28.881740] Empty Balance Info.
[ rdpclient 838] [ 28.897829] Server supports GFX Pipeline.
[ rdpclient 838] [ 28.897962] NLA.
[ rdpclient 838] [ 28.898086] SSL/TLS.
[ rdpclient 838] [ 28.965387] NLA errorCode 0xc000006d.
[ rdpclient 838] [ 28.965449] Logon failed. Wrong username or password.
[ gm] [ 28.965552] Final message: Logon failed. Wrong username or password.
[ pfac] [ 28.966016] Process pid 838 terminated, status 00000009.
[ gm] [ 30.403409] Run '/sbin/resolver 0x2164da8 dns [rds.xxx-xxxxxx.de]', log '', env '', pid ''.
[ pfac] [ 30.403557] Run /sbin/resolver 0x2164da8 dns [rds.xxx-xxxxxx.de].
[ pfac] [ 30.403992] Ok, PID 839.
[ gm] [ 30.412025] rds.xxx-xxxxxx.de => 192.168.33.15.
[ pfac] [ 30.412701] Process pid 839 terminated, status 00000000.
Please try this: http://wtware.com/testing/202001161552.zip
And show me the same log.
jonathan
Post by jonathan »
Thank you so much!
Now everything seems to work!
WTware v.5.8.89/RPi
WTware 5.8.89/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 4.19.93-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #5 SMP Thu Jan 16 15:47:15 UTC 2020
[ KERNEL] [ 0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ KERNEL] [ 0.000190] Console: colour dummy device 80x30
[ KERNEL] [ 0.000208] console [tty0] enabled
[ KERNEL] [ 0.000241] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ KERNEL] [ 0.000254] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000376] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000393] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000884] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001185] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001576] Setting up static identity map for 0x200000 - 0x20003c
[ KERNEL] [ 0.001676] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002175] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.002756] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003415] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.004049] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004137] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004146] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ KERNEL] [ 0.004153] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004159] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004621] devtmpfs: initialized
[ KERNEL] [ 0.012755] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ KERNEL] [ 0.013044] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.013060] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 0.014596] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.015511] NET: Registered protocol family 16
[ KERNEL] [ 0.017652] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.021513] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.058458] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ KERNEL] [ 0.060771] vgaarb: loaded
[ KERNEL] [ 0.061242] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.061333] usbcore: registered new interface driver hub
[ KERNEL] [ 0.061394] usbcore: registered new device driver usb
[ KERNEL] [ 0.080201] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-12-11 15:09, variant start
[ KERNEL] [ 0.090053] raspberrypi-firmware soc:firmware: Firmware hash is f6ae361f091fe2c1b8a2e7d6fa7ae80237884fc3
[ KERNEL] [ 0.101593] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.113079] NET: Registered protocol family 2
[ KERNEL] [ 0.113513] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ KERNEL] [ 0.113530] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.113583] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.113642] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.113743] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.113770] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.113894] NET: Registered protocol family 1
[ KERNEL] [ 0.113919] PCI: CLS 0 bytes, default 64
[ KERNEL] [ 1.833836] Initialise system trusted keyrings
[ KERNEL] [ 1.833950] workingset: timestamp_bits=30 max_order=20 bucket_order=0
[ KERNEL] [ 1.869997] Key type asymmetric registered
[ KERNEL] [ 1.870011] Asymmetric key parser 'x509' registered
[ KERNEL] [ 1.870111] bounce: pool size: 64 pages
[ KERNEL] [ 1.870181] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ KERNEL] [ 1.870194] io scheduler noop registered
[ KERNEL] [ 1.870388] io scheduler cfq registered (default)
[ KERNEL] [ 1.922573] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ KERNEL] [ 1.922593] brcm-pcie fd500000.pcie: could not get clock
[ KERNEL] [ 1.922641] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ KERNEL] [ 1.922671] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ KERNEL] [ 1.981620] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ KERNEL] [ 1.981841] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ KERNEL] [ 1.981854] pci_bus 0000:00: root bus resource [bus 00-01]
[ KERNEL] [ 1.981868] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ KERNEL] [ 1.981900] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ KERNEL] [ 1.981988] pci 0000:00:00.0: PME# supported from D0 D3hot
[ KERNEL] [ 1.984917] PCI: bus0: Fast back to back transfers disabled
[ KERNEL] [ 1.984933] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ KERNEL] [ 1.985128] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ KERNEL] [ 1.985235] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ KERNEL] [ 1.985501] pci 0000:01:00.0: PME# supported from D0 D3cold
[ KERNEL] [ 1.988419] PCI: bus1: Fast back to back transfers disabled
[ KERNEL] [ 1.988435] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ KERNEL] [ 1.988470] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.988486] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ KERNEL] [ 1.988547] pci 0000:00:00.0: PCI bridge to [bus 01]
[ KERNEL] [ 1.988559] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 1.988725] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.988880] pcieport 0000:00:00.0: Signaling PME with IRQ 51
[ KERNEL] [ 1.989018] pcieport 0000:00:00.0: AER enabled with IRQ 51
[ KERNEL] [ 1.989169] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 1.989642] bcm2708_fb soc:fb: FB found 2 display(s)
[ KERNEL] [ 2.031950] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 2.043184] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ KERNEL] [ 2.074917] bcm2708_fb soc:fb: Registered framebuffer for display 1, size 1920x1080
[ KERNEL] [ 2.076816] iproc-rng200 fe104000.rng: hwrng registered
[ KERNEL] [ 2.077015] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 2.077603] vc-sm: Videocore shared memory driver
[ KERNEL] [ 2.078099] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ KERNEL] [ 2.079037] zram: Added device: zram0
[ KERNEL] [ 2.081529] libphy: Fixed MDIO Bus: probed
[ KERNEL] [ 2.082649] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.082690] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 2.127758] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ KERNEL] [ 2.128127] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 52
[ KERNEL] [ 2.128496] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ KERNEL] [ 2.128513] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.128522] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 2.128533] usb usb1: Manufacturer: Linux 4.19.93-v7l xhci-hcd
[ KERNEL] [ 2.128552] usb usb1: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.129538] hub 1-0:1.0: USB hub found
[ KERNEL] [ 2.129619] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 2.130329] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 2.130359] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 2.130378] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ KERNEL] [ 2.130818] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ KERNEL] [ 2.130828] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 2.130838] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 2.130848] usb usb2: Manufacturer: Linux 4.19.93-v7l xhci-hcd
[ KERNEL] [ 2.130867] usb usb2: SerialNumber: 0000:01:00.0
[ KERNEL] [ 2.131732] hub 2-0:1.0: USB hub found
[ KERNEL] [ 2.131802] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 2.133410] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 2.133611] dwc_otg: FIQ enabled
[ KERNEL] [ 2.133619] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 2.133625] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 2.133683] Module dwc_common_port init
[ KERNEL] [ 2.144754] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 2.145875] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 2.146100] bcm2835-cpufreq: min=600000 max=1500000
[ KERNEL] [ 2.146899] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 2.146906] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 2.147416] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ KERNEL] [ 2.147864] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 2.149277] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 2.150390] usbcore: registered new interface driver usbhid
[ KERNEL] [ 2.150395] usbhid: USB HID core driver
[ KERNEL] [ 2.151071] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ KERNEL] [ 2.154377] [vc_sm_connected_init]: start
[ KERNEL] [ 2.165042] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 2.165586] NET: Registered protocol family 17
[ KERNEL] [ 2.165686] Registering SWP/SWPB emulation handler
[ KERNEL] [ 2.165977] Loading compiled-in X.509 certificates
[ KERNEL] [ 2.168719] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ KERNEL] [ 2.168978] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ KERNEL] [ 2.169272] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 2.169275] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ KERNEL] [ 2.194672] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ KERNEL] [ 2.213217] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ KERNEL] [ 2.214749] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.216282] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.219025] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ KERNEL] [ 2.220557] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ KERNEL] [ 2.228675] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ KERNEL] [ 2.229010] of_cfs_init
[ KERNEL] [ 2.229091] of_cfs_init: OK
[ KERNEL] [ 2.254212] Freeing unused kernel memory: 6144K
[ KERNEL] [ 2.293191] random: fast init done
[ KERNEL] [ 2.317363] Run /init as init process
[ KERNEL] [ 2.321235] mmc1: new high speed SDIO card at address 0001
[ KERNEL] [ 2.369507] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ KERNEL] [ 2.369909] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ KERNEL] [ 2.371815] mmcblk0: p1
[ hotplug] [ 2.371801] Block device 179:0. No action.
[ hotplug] [ 2.371943] Block device 179:1. No action.
[ hotplug] [ 2.441239] Block device 254:0. No action.
[ KERNEL] [ 2.501675] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ pfac] [ 2.629271] Run /sbin/initrd.
[ pfac] [ 2.629592] Ok, PID 744.
[ initrd] [ 2.635157] WTware 5.8.89/RPi shell.
[ initrd] [ 2.635540] Load font 'ter-c32b.psf', console 120x33.
[ initrd] [ 2.658366] HDD/MMC/SD boot.
[ KERNEL] [ 2.684213] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ KERNEL] [ 2.684218] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 2.684222] usb 1-1: Product: USB2.0 Hub
[ KERNEL] [ 2.685684] hub 1-1:1.0: USB hub found
[ KERNEL] [ 2.685974] hub 1-1:1.0: 4 ports detected
[ KERNEL] [ 3.011627] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 3.150304] usb 1-1.2: New USB device found, idVendor=045e, idProduct=07fd, bcdDevice= 3.15
[ KERNEL] [ 3.150317] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.150327] usb 1-1.2: Product: Microsoft Nano Transceiver 1.1
[ KERNEL] [ 3.150336] usb 1-1.2: Manufacturer: Microsoft
[ KERNEL] [ 3.161550] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:07FD.0001/input/input0
[ KERNEL] [ 3.232780] hid-generic 0003:045E:07FD.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.2/input0
[ KERNEL] [ 3.240560] input: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:045E:07FD.0002/input/input1
[ KERNEL] [ 3.301993] input: Microsoft Microsoft Nano Transceiver 1.1 System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:045E:07FD.0002/input/input2
[ KERNEL] [ 3.302289] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:045E:07FD.0002/input/input3
[ KERNEL] [ 3.302905] hid-generic 0003:045E:07FD.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.2/input1
[ KERNEL] [ 3.308917] input: Microsoft Microsoft Nano Transceiver 1.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:045E:07FD.0003/input/input4
[ KERNEL] [ 3.309514] hid-generic 0003:045E:07FD.0003: input,hidraw2: USB HID v1.11 Mouse [Microsoft Microsoft Nano Transceiver 1.1] on usb-0000:01:00.0-1.2/input2
[ initrd] [ 3.422511] Success: /dev/mmcblk0p1 mounted to /bootmedia.
[ KERNEL] [ 3.421626] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #arm_freq=800
| disable_splash=1
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| max_framebuffers=2
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| #[HDMI:0]
| # hdmi_group=2
| # hdmi_mode=42
| #[HDMI:1]
| # hdmi_group=2
| # hdmi_mode=58
[ initrd] [ 3.441808] Do not cache package files.
[ initrd] [ 3.441917] WTpassword present: 01ad7dc359caccf3c8de80cb1b9f05a4.
[ initrd] [ 3.477030] USB: 2109:3431 VIA Labs, Inc. Hub.
[ initrd] [ 3.477086] USB: 045e:07fd Microsoft Corp. Nano Transceiver 1.1.
[ KERNEL] [ 3.747526] usb 1-1.3: New USB device found, idVendor=413c, idProduct=a503, bcdDevice= 1.10
[ KERNEL] [ 3.747538] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 3.747548] usb 1-1.3: Product: Dell AC511 USB SoundBar
[ KERNEL] [ 3.747558] usb 1-1.3: Manufacturer: Dell
[ KERNEL] [ 3.764822] input: Dell Dell AC511 USB SoundBar as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.3/0003:413C:A503.0004/input/input5
[ KERNEL] [ 3.831921] hid-generic 0003:413C:A503.0004: input,hidraw3: USB HID v1.00 Device [Dell Dell AC511 USB SoundBar] on usb-0000:01:00.0-1.3/input3
[ KERNEL] [ 4.231628] usb 1-1.4: new low-speed USB device number 5 using xhci_hcd
[ KERNEL] [ 4.371109] usb 1-1.4: New USB device found, idVendor=04b3, idProduct=3025, bcdDevice= 1.09
[ KERNEL] [ 4.371121] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 4.371132] usb 1-1.4: Product: USB NetVista Full Width Keyboard.
[ KERNEL] [ 4.371142] usb 1-1.4: Manufacturer: LITE-ON Technology
[ KERNEL] [ 4.384169] input: LITE-ON Technology USB NetVista Full Width Keyboard. as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:04B3:3025.0005/input/input6
[ KERNEL] [ 4.452669] hid-generic 0003:04B3:3025.0005: input,hidraw4: USB HID v1.10 Keyboard [LITE-ON Technology USB NetVista Full Width Keyboard.] on usb-0000:01:00.0-1.4/input0
| clientIP = *
| config = local
| setupPassword = 01ad7dc359caccf3c8de80cb1b9f05a4
[ initrd] [ 5.378930] Load Ethernet drivers.
[ initrd] [ 5.379168] modprobe genet.
[ KERNEL] [ 5.388219] bcmgenet fd580000.genet: failed to get enet clock
[ KERNEL] [ 5.388228] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ KERNEL] [ 5.388234] bcmgenet fd580000.genet: failed to get enet-wol clock
[ KERNEL] [ 5.388242] bcmgenet fd580000.genet: failed to get enet-eee clock
[ KERNEL] [ 5.388256] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 5.388385] unimac-mdio unimac-mdio.-19: DMA mask not set
[ KERNEL] [ 5.411593] libphy: bcmgenet MII bus: probed
[ KERNEL] [ 5.465002] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ KERNEL] [ 5.467786] bcmgenet: Skipping UMAC reset
[ KERNEL] [ 5.561969] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ KERNEL] [ 6.631775] bcmgenet fd580000.genet eth0: Link is Down
[ KERNEL] [ 10.791752] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ initrd] [ 10.869063] WTpassword present: 01ad7dc359caccf3c8de80cb1b9f05a4.
[ initrd] [ 11.922987] dhcp: 328 bytes from 192.168.34.1.
[ initrd] [ 11.923139] 00000000:000001340000000000110000C0A80E01C0A80E4B004300440134000002010600 ...4..............K.C.D.4......
[ initrd] [ 11.923273] 00000020:67458B6B0000000000000000C0A80E4B0000000000000000DCA63241EA200000 gE.k...........K..........2A. ..
[ initrd] [ 11.923402] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.923529] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.923655] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.923781] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.923906] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.924033] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 11.924159] 00000100:0000000000000000638253633501023604C0A80E01330400014DB90104FFFFFF ........c.Sc5..6.....3...M......
[ initrd] [ 11.924285] 00000120:000304C0A80E010608C0A80E01C0A80E020F076A6F792E6C616EFF0000000000 ...................xxxx.lan......
[ initrd] [ 11.924406] 00000140:0000000000000000 ........
[ initrd] [ 13.100177] dhcp: 328 bytes from 192.168.34.1.
[ initrd] [ 13.100316] 00000000:000001340000000000110000C0A80E01C0A80E4B004300440134000002010600 ...4..............K.C.D.4......
[ initrd] [ 13.100447] 00000020:67458B6B0000000000000000C0A80E4B0000000000000000DCA63241EA200000 gE.k...........K..........2A. ..
[ initrd] [ 13.100573] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.100699] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.100824] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.100949] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.101074] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.101199] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.101324] 00000100:0000000000000000638253633501053604C0A80E01330400014DB70104FFFFFF ........c.Sc5..6.....3...M......
[ initrd] [ 13.101449] 00000120:000304C0A80E010608C0A80E01C0A80E020F076A6F792E6C616EFF0000000000 ...................xxxx.lan......
[ initrd] [ 13.101570] 00000140:0000000000000000 ........
[ initrd] [ 13.140094] [DHCP] DHCP server address 192.168.34.1.
[ initrd] [ 13.140216] [DHCP] IP 192.168.34.75 mask 255.255.255.0.
[ initrd] [ 13.140339] [DHCP] Default gateway 192.168.34.1.
[ initrd] [ 13.140454] [DHCP] DNS 192.168.34.1.
[ initrd] [ 13.140567] [DHCP] DNS 192.168.34.2.
[ initrd] [ 13.140680] [DHCP] Domain xxxx.lan.
[ initrd] [ 13.140795] [DHCP] TFTP = DHCP 192.168.34.1.
[ initrd] [ 13.140908] [DHCP] TFTP 192.168.34.1.
[ initrd] [ 13.141020] [DHCP] No boot file from DHCP.
[ initrd] [ 13.141135] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
[ pfac] [ 13.143654] Run /sbin/httpd.
[ initrd] [ 13.143733] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 13.143873] Ok, PID 832.
[ initrd] [ 13.143924] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 13.146034] /bootmedia/configs/config.wtc -> /tmp/config.wtc, 104 bytes copied.
[ initrd] [ 13.146138] Common local disk config:
| server=rds.xxxx-xxxxxxxxxxxxx.de
| ask_password=on
| ask_password=on
[ initrd] [ 13.148197] Hostname: "wtwDCA63241EA20".
[ httpd] [ 13.153501] Internal HTTP Server, WTware 5.8.89/RPi
[ initrd] [ 13.390276] [NTP] 42 DHCP option is not set.
[ httpd] [ 13.396646] Reread settings.
[ httpd] [ 13.396848] Everyone can control terminal by HTTP.
[ initrd] [ 13.397004] Unpack /bootmedia/packages/pi2-f.
[ KERNEL] [ 13.517743] random: crng init done
[ gm] [ 13.519023] WTware 5.8.89/RPi session manager.
[ gm] [ 13.519560] Add keyboard event6: LITE-ON Technology USB NetVista Full Width Keyboard..
[ gm] [ 13.519641] Add keyboard event5: Dell Dell AC511 USB SoundBar.
[ gm] [ 13.580118] EV_REL flag found. Add mouse event4: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.580319] Add keyboard event3: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.580501] Add keyboard event2: Microsoft Microsoft Nano Transceiver 1.1 System Control.
[ gm] [ 13.580685] Add keyboard event1: Microsoft Microsoft Nano Transceiver 1.1 Consumer Control.
[ gm] [ 13.580862] Add keyboard event0: Microsoft Microsoft Nano Transceiver 1.1.
[ gm] [ 13.581147] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 13.581314] M2 mode: 1920x1080, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 13.885704] Framebuffer device found.
[ gm] [ 13.885771] LINELENBYTES 7680
[ gm] [ 13.885825] VLEN 8294400
[ gm] [ 13.885936] Second framebuffer device found.
[ gm] [ 13.885991] LINELENBYTES 7680
[ gm] [ 13.886043] VLEN 8294400
[ gm] [ 13.887255] Use /lib/ui32.so.
[ gm] [ 14.006699] Run '/sbin/resolver 0x1503dc8 dns [rds.xxxx-xxxxxxxxxxxxx.de]', log '', env '', pid ''.
[ pfac] [ 14.007141] Run /sbin/resolver 0x1503dc8 dns [rds.xxxx-xxxxxxxxxxxxx.de].
[ gm] [ 14.007290] Nobody can control terminal by VNC.
[ pfac] [ 14.007436] Ok, PID 834.
[ pfac] [ 14.014450] Process pid 834 terminated, status 00000000.
[ gm] [ 14.018529] rds.xxxx-xxxxxxxxxxxxx.de => 192.168.33.15.
[ gm] [ 27.818765] Free ram before fork terminal client /sbin/rdpclient (session 1): 3931768 Kb.
[ gm] [ 27.818971] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 27.819243] Run /sbin/rdpclient 1.
[ pfac] [ 27.819553] Ok, PID 835.
[ rdpclient 835] [ 27.831952] RDP Terminal Client, WTware 5.8.89/RPi, pipe 1, pid 835.
[ rdpclient 835] [ 27.832859] Use /lib/ui32.so.
[ rdpclient 835] [ 27.833992] Make RDP session with 192.168.33.15, port 3389.
[ rdpclient 835] [ 27.834059] Username: "xxxx\myusername".
[ rdpclient 835] [ 27.834141] Password: present.
[ rdpclient 835] [ 27.834182] No PIN.
[ rdpclient 835] [ 27.834220] No domain.
[ rdpclient 835] [ 27.834258] No shell.
[ rdpclient 835] [ 27.834296] No directory.
[ rdpclient 835] [ 27.834335] Window: 1856x1080@24.
[ rdpclient 835] [ 27.834373] Second monitor: [1856:0..3711:1079].
[ rdpclient 835] [ 27.834411] PFlags 0x0000002F.
[ rdpclient 835] [ 27.834448] Keyboard 00000409:00000000.
[ rdpclient 835] [ 27.834486] My hostname "wtwDCA63241EA20".
[ rdpclient 835] [ 27.834533] TCP: connecting to 192.168.33.15:3389.
[ rdpclient 835] [ 27.838990] TCP: connection with 192.168.33.15:3389 established.
[ rdpclient 835] [ 27.839070] Turn keepalive on.
[ rdpclient 835] [ 27.840093] Free ram after buffers allocation: 3931256 KB.
[ rdpclient 835] [ 27.859417] Reconnect with TLS/SSL enabled.
[ rdpclient 835] [ 27.859482] TCP: reconnecting to 192.168.33.15:3389.
[ rdpclient 835] [ 27.864197] TCP: connection with 192.168.33.15:3389 established.
[ rdpclient 835] [ 27.864305] Turn keepalive on.
[ rdpclient 835] [ 27.878858] Server supports GFX Pipeline.
[ rdpclient 835] [ 27.878991] TLS.
[ rdpclient 835] [ 27.879115] SSL/TLS.
[ rdpclient 835] [ 27.984812] Enable font smoothing and Desktop Composition.
[ rdpclient 835] [ 28.138415] GFX codec.
[ rdpclient 835] [ 28.214246] Graphics output buffer 3712x1080, 2 monitors.
[ rdpclient 835] [ 28.214349] Monitor 0: 0.0-1855.1079 primary.
[ rdpclient 835] [ 28.214389] Monitor 1: 1856.0-3711.1079.
[ rdpclient 835] [ 29.127906] Run 4 tile threads.
[ rdpclient 835] [ 29.129924] RDPGFX_CMDID_DELETEENCODINGCONTEXT.
[ rdpclient 835] [ 29.741001] TS_STATUS_FINDING_DESTINATION
[ gm] [ 29.741138] Do not display state after connection.
[ rdpclient 835] [ 29.743446] TS_STATUS_LOADING_DESTINATION
[ rdpclient 835] [ 29.743764] TS_STATUS_REDIRECTING_TO_DESTINATION
[ rdpclient 835] [ 29.769941] RDPGFX_CMDID_DELETEENCODINGCONTEXT.
[ rdpclient 835] [ 30.775403] TS_STATUS_BRINGING_SESSION_ONLINE
[ rdpclient 835] [ 30.778670] TS_STATUS_VM_LOADING
[ rdpclient 835] [ 31.429489] Server Redirection flags 0x00000b1d.
[ rdpclient 835] [ 31.429629] Server 192.168.33.17.
[ rdpclient 835] [ 31.429726] User "myusername".
[ rdpclient 835] [ 31.429824] Domain "XXX".
[ rdpclient 835] [ 31.429918] Password present.
[ rdpclient 835] [ 31.430049] Send Disconnect Provider Ultimatum.
[ gm] [ 31.465037] TSClient (sessionId 1, pid 835) gracefully end.
[ gm] [ 31.465238] Use password from previous session.
[ gm] [ 31.465279] Free ram before fork terminal client /sbin/rdpclient (session 2): 3893012 Kb.
[ gm] [ 31.465320] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 31.465358] Run /sbin/rdpclient 2.
[ pfac] [ 31.465462] Ok, PID 842.
[ pfac] [ 31.470209] Process pid 835 terminated, status 00000009.
[ rdpclient 842] [ 31.470835] RDP Terminal Client, WTware 5.8.89/RPi, pipe 2, pid 842.
[ rdpclient 842] [ 31.471187] Use /lib/ui32.so.
[ rdpclient 842] [ 31.471593] Make RDP session with 192.168.33.17, port 3389.
[ rdpclient 842] [ 31.471640] Username: "myusername".
[ rdpclient 842] [ 31.471682] Password: present.
[ rdpclient 842] [ 31.471720] No PIN.
[ rdpclient 842] [ 31.471759] Domain: "XXX".
[ rdpclient 842] [ 31.471797] No shell.
[ rdpclient 842] [ 31.471835] No directory.
[ rdpclient 842] [ 31.471872] Window: 1856x1080@24.
[ rdpclient 842] [ 31.471910] Second monitor: [1856:0..3711:1079].
[ rdpclient 842] [ 31.471949] PFlags 0x0000002F.
[ rdpclient 842] [ 31.471987] Keyboard 00000409:00000000.
[ rdpclient 842] [ 31.472025] My hostname "wtwDCA63241EA20".
[ rdpclient 842] [ 31.472063] TCP: connecting to 192.168.33.17:3389.
[ rdpclient 842] [ 31.475974] TCP: connection with 192.168.33.17:3389 established.
[ rdpclient 842] [ 31.476015] Turn keepalive on.
[ rdpclient 842] [ 31.476534] Free ram after buffers allocation: 3931180 KB.
[ rdpclient 842] [ 31.476578] Empty Balance Info.
[ rdpclient 842] [ 31.497403] Reconnect with NLA enabled.
[ rdpclient 842] [ 31.497517] TCP: reconnecting to 192.168.33.17:3389.
[ rdpclient 842] [ 31.501612] TCP: connection with 192.168.33.17:3389 established.
[ rdpclient 842] [ 31.501716] Turn keepalive on.
[ rdpclient 842] [ 31.501811] Empty Balance Info.
[ rdpclient 842] [ 31.521485] Server supports GFX Pipeline.
[ rdpclient 842] [ 31.521626] NLA.
[ rdpclient 842] [ 31.521767] SSL/TLS.
[ rdpclient 842] [ 31.595731] Redirected Session ID 0x00000000.
[ rdpclient 842] [ 31.650325] Enable font smoothing and Desktop Composition.
[ rdpclient 842] [ 31.656900] RDP4 encryption.
[ rdpclient 842] [ 31.831504] GFX codec.
[ rdpclient 842] [ 31.900200] Graphics output buffer 3712x1080, 2 monitors.
[ rdpclient 842] [ 31.900331] Monitor 0: 0.0-1855.1079 primary.
[ rdpclient 842] [ 31.900372] Monitor 1: 1856.0-3711.1079.
[ rdpclient 842] [ 32.198628] SessionId 0x00000003: XXX\myusername.
[ rdpclient 842] [ 34.044032] Run 4 tile threads.
[ rdpclient 842] [ 34.121038] RDPGFX_CMDID_DELETEENCODINGCONTEXT.
[ rdpclient 842] [ 34.173447] RDPGFX_CMDID_DELETEENCODINGCONTEXT.
[ rdpclient 842] [ 34.185982] RDPGFX_CMDID_DELETEENCODINGCONTEXT.
Home WTware diskless client.
