Raspberry Pi 4 Network Boot EEPROM
johniot
Post by johniot »
Is the WTware Configurator able to generate a "Programming SD Card" that updates the EEPROM bootloader of the Raspberry Pi 4 to perform a network boot without requiring an SD Card?
Raspberry Pi4 bootloader - network boot support - BETA
https://www.raspberrypi.org/forums/view ... p?t=252501
Raspberry Pi4 network boot (BETA)
https://github.com/raspberrypi/rpi-eepr ... ot_beta.md
Thank you,
John
Re: Raspberry Pi 4 Network Boot EEPROM
No, wtware is not able now.
Did you try network boot on Pi4?
johniot
Post by johniot »
I will hopefully be getting delivery of my Raspberry Pi 4's later this week. I will attempt network booting and let you know. From the forum post it looks promising though.
johniot
Post by johniot »
UPDATE:
I am able to successfully network boot the Raspberry Pi 4.
You need to update the firmware and bootloader, configure the bootloader for network boot and then write the bootloader to the EEPROM as described here https://github.com/raspberrypi/rpi-eepr ... ot_beta.md.
Note, I used a newer version of the bootloader (2019-11-18) than the one used in the instructions.
