Power LED indicator
Power LED indicator
Can I plug in additional LEDs when turning on raspberry pi 4 and turning off the LED when raspberry pi 4 is turned off? I want the additional LED on to recognize that the Raspberry pi 4 is on. Is it possible to encode to config?
Re: Power LED indicator
How do you turn raspberry pi 4 off?
raspberry switches to turn off, but the LED indicator remains on the switch still on, does not go out. Can you program it into Gpio on some pin? In order to switch to turn of, the LED in the switch will turn off
it can be programmed to
the wtware to poweroff ... from 3.3V to 0V... and it would switch to 3.3V when turned on...now when it is still on 3.3V goes still fan ... when transitioning wtware to poweroffturnoffmenu= power off
- kSo96fYwdrfQKSvALMKqzc-1200-80.png (229.99 KiB) Viewed 14256 times
