Raspberry Pi 4 - Latest Firmware
Cobra_Phil
Post by Cobra_Phil »
Does the latest version of WTware (5.8.76) incorporate the latest Raspberry Pi 4 firmware as indicated in the link below? Or is there a way to install it on the latest version of WTware. It appears it will help with elevated temperatures.
https://www.hackster.io/news/newly-rele ... b398270685
Re: Raspberry Pi 4 - Latest Firmware
WTware will not rewrite your EEPROM.
As far as I understand, the simplest method to update/recover Pi4 EEPROM is to boot once from recovery SD. Recovery SD Image is oficially available here:
https://www.raspberrypi.org/downloads/
Recovery SD image link name now with keywords vl805 and 000137ab : "https:// static.raspberrypi.org/files/rpi-boot-eeprom-recovery-2019-09-10-vl805-000137ab.zip".
Cobra_Phil
Thanks. I confirmed that this does work and it lowered my temps by 8-10 degrees C. No other apparent issues. WTWare runs great.
cwt
Post by cwt »
I detected that RPi 4s with the newest firmware have improved graphics when working in RDP sessions with more complex details or 3D objects. It seems they have reworked their drivers/code with their new developer team (I read something about a change in the developer team).
